Old 08-27-2020, 10:42 AM   #15
StraightOuttaCanadaEh
Wes
SARD wing, when paintmatched, looks fantastic. Used to get compliments from other drivers every single day, sometimes more than once.
This one is not my car but just another example of how good it looks.
The compliments basically stopped the day I got rid of it.
Then I got the Leg style duck wing.
I got bored of it very quickly, it's meh. Flew off on the highway anyway
The best wing available currently, in my personal opinion, is the Artisan Spirits one, which is what I'm saving for now.
They really nailed this one I think
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
stefoo (09-02-2020)
Old 08-27-2020, 10:44 AM   #16
Wes
Originally Posted by SUSPECT_BRZ View Post
Sorry to highjack the thread but are these spoilers attached with factory holes and bolts or with 3M tape?
The FIVE:AD uses tape. As long as you get a genuine item, and install it correctly, it will not fall off. Had mine on for 2 years. Even though some of the areas never stuck on the trunk, I had a lot of difficulty pulling it off.
Instagram: @gt86ws
Old 08-27-2020, 05:28 PM   #17
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
I guess it's all a question of preference. I think big wings look terrible on these cars UNLESS there a full body kit to go with it like the rocket bunny for example. Just the wing makes the car look unbalanced in my opinion.
I'm the total opposite, I really like the duck tail. Simple, clean, classic.
SUSPECT_BRZ is offline   Reply With Quote
Old 08-27-2020, 05:29 PM   #18
SUSPECT_BRZ
Thanks for that information! Wasn't sure they held up very good but did some research myself and apparently they do!
The Following User Says Thank You to SUSPECT_BRZ For This Useful Post:
StraightOuttaCanadaEh (08-27-2020)
Old 08-27-2020, 10:28 PM   #19
stefoo
Drives: 2017 Toyota 86 AUTOMATIC.
@SUSPECT_BRZ
I believe most are with 3m tape unless u get the bigger wings then youll need to drill your own holes.. which are around 4 holes on each side i believe
stefoo is offline   Reply With Quote
The Following User Says Thank You to stefoo For This Useful Post:
SUSPECT_BRZ (08-29-2020)
Old 08-31-2020, 05:00 PM   #20
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
@SUSPECT_BRZ
I just redid my spoiler for the 3rd time. First time bodyshop (started to come off after a year), 2nd time was my first attempt ever and and I just cleaned the trunk and stook the wing on as per most YouTube video tutorials.
This time, I alcohol cleaned the surface; heat gunned the trunk a little bit and then heat gun the spoiler after it's stuck on the trunk to help the 3M double sided tape mold to the surface, and left the trunk open all night with clamps and masking tape all over the spoiler to let it really squeeze it on tight for 24 hours.
kevaughan is offline   Reply With Quote
Old 08-31-2020, 05:04 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Grady View Post
Stock with risers for looks, Verus duckbill and wing for function.
Running a duckbill and wing is so overkill unless you have a lot of HP to push it and a lot of front aero to balance it.
Old 08-31-2020, 07:44 PM   #22
Wes
This is very true, can confirm.
I ran the SARD wing with a FIVE:AD trunk lip and I would get front end lift at speeds higher than 110-120 km/h (65-75 mph)
Instagram: @gt86ws
NoHaveMSG (09-01-2020)
Old 09-01-2020, 08:47 AM   #23
Grady
Grady's Avatar
Verus does not agree with you. When adding their wing you get a small increase in drag with a large increase in downforce.
Old 09-01-2020, 09:17 AM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s 58% increase in downforce with another 30% in drag, their numbers with the high efficiency wing. Those are not insignificant numbers. For me the drag was only another 3-4mph but the increased downforce caused the car to understeer like a pig since I didn’t have endplates or dive planes on the front. You can reference all you want, but you need to try it and feel the difference.
EDIT:Correction, 10% increase in drag.
Old 09-01-2020, 01:03 PM   #25
Grady
Grady's Avatar
I did try it. But to your point I did do the entire Ventus 3 package. You can mechanically tighten up the front for less understeer also.
Old 09-01-2020, 01:23 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I tried. Flipped my rear sway to the stiffest setting and went up in compression in the rear. I think with endplates minimum it would be acceptable. Right now the front end is just not there in high speed corners.
Old 09-01-2020, 03:30 PM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
NoHaveMSG: vented hood? IIRC another way to add slight dowforce (or rather lift reduction) to front in addition to cooling ..
Old 09-01-2020, 03:39 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes. Been running one for a while.
WTB: 2017+ Stock Toyota 86/BRZ wheels. HachiRokuX Want-To-Buy Requests 3 12-16-2019 01:05 PM
2017 Toyota 86 Trunk Lid GrayFox_27 Want-To-Buy Requests 0 06-23-2018 01:48 PM
TRADE: 2017 BRZ trunk and wing for wingless trunk?? Moto CANADA 0 05-19-2018 04:21 PM
STOCK Toyota 86 2017 6 speaker set Cam1990/86 Audio/Visual, Electronics, Infotainment, NAV 0 04-05-2018 09:20 AM
Anyone know where I can get a Trunk Lid Liner for a 2017 Toyota 86? SB-86 Scion FR-S / Toyota 86 GT86 General Forum 18 09-07-2017 09:35 PM
