Old 08-26-2020, 02:41 PM   #1
SakuraEightySix
Drives: JDL Turbo Twin
Coolant
Hey guys,
What type of coolant do you run? I have a JDL turbo 86 and I just used "Peak" brand coolant for "asian vehicles", its blue, I don't know about the FA motors but my buddy with an EJ207 wrx told me he's going to use Subaru's Coolant because he's heard other coolants can eat away at head gaskets.
Just curious if anyone has more insight on this.
SakuraEightySix is offline   Reply With Quote
The Following User Says Thank You to SakuraEightySix For This Useful Post:
humfrz (08-27-2020)
Old 08-26-2020, 03:09 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I have several jugs of coolant from the Toyota dealership. I stick with OEM coolant, but mostly because I don't know what would work best, so I leave that judgment in the hands of the OEM.
Magyarman (08-27-2020)
Old 08-27-2020, 02:37 AM   #3
Originally Posted by SakuraEightySix View Post
Hey guys,
Welcome to the gang, there SakuraEightySix -
To be safe, I suggest you stick with the OEM blue stuff.
Old 08-27-2020, 11:07 AM   #4
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
OEM is most of the time the way to go regarding coolant. My previous vehicle was highly modified and it still had the original coolant running at perfect engine temperature. What you used is probably similar, but double check to be on the safe side.
SUSPECT_BRZ is offline   Reply With Quote
Old 08-30-2020, 07:56 PM   #5
mrg666
pessimistic skeptic
mrg666's Avatar
I used Zerex blue when I replaced the radiator with JR dual radiator oil cooler. I was using Pentofrost A3 before that. They both work fine and compatible to mix with stock coolant.
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 02:09 AM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 09:37 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
Where did my coolant go? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 1 11-02-2013 12:46 PM
