Old 08-19-2020, 08:55 PM   #295
AFRichZC6
AFRichZC6's Avatar
Spec Lugod
AFRichZC6 is offline   Reply With Quote
Old 08-19-2020, 10:56 PM   #296
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Originally Posted by Roadphantom View Post
Does anyone have corner balancing corner weights to share?
This is where I currently am with 400/400 springs.
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
Roadphantom (08-20-2020)
Old 08-20-2020, 06:53 AM   #297
steverife
Drives: 2016 Scion FRS
Anybody planning to do the new Bristol Tour?
steverife is offline   Reply With Quote
Old 08-20-2020, 08:22 AM   #298
M0nk3y
Originally Posted by AFRichZC6 View Post
Spec Lugod
That guy doesn't know what he's talking about...
Kyle H. - #89 STX
Old 08-20-2020, 10:28 AM   #299
racingfool
racingfool's Avatar
Drives: Miata
Is that with you in the driver's seat?
racingfool is offline   Reply With Quote
Old 08-20-2020, 11:30 AM   #300
M0nk3y
Unless he has the lightest STX legal FRS in the world, no.
Kyle H. - #89 STX
Old 08-20-2020, 02:18 PM   #301
racingfool
racingfool's Avatar
Drives: Miata
Yeah, I did the math.
I just can't imagine corner weighting the car without driver.
Maybe he always races with a passenger.
Old 08-20-2020, 02:42 PM   #302
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
I had my car corner weighted with me in it, and looked at the cross weights and front to back percentages, and then got out of the car to see how much difference it made. It was less than a percent.
The right to left percentages were changed by 5%, though.
With me in the car:
LF 815 RF 743
LR 650 RR 577
My co-driver weighs about the same as me.
I have 7k front springs and 9k rear.
Sent from my SM-G973U using Tapatalk
sifl is offline   Reply With Quote
The Following 2 Users Say Thank You to sifl For This Useful Post:
racingfool (08-20-2020), Roadphantom (08-21-2020)
Old 08-20-2020, 10:04 PM   #303
steverife
Maybe he just weighed the car. Put car on scales, weigh car. People do it all the time.
Old 08-20-2020, 11:31 PM   #304
Breezio
Breezio's Avatar
Here is the weight/balance with 160 lbs. ballast in the driver seat. Not quite as good, but not far enough off for me to worry about screwing with it.
Old 08-21-2020, 04:39 PM   #305
colobrio
Drives: 2013 BRZ, 6MT, WR Blue
Originally Posted by steverife View Post
Are all the people discussed on the 5k/9k setup running a Giken?
I'm on 5k/8k and stock diff, but it's not by design. I bought tigermack's car in January, after he'd sold the Giken. This is the first substantially modified car I've driven, so I don't have much frame of reference. The one thing that's disappointed me with the handling has been that it seems looser on corner exit than I expected (although maybe less so since I just switched to Yokos). I'm sure that's due mostly to my mediocre skills, but would this setup be contributing? I'm thinking about squaring up the springs this winter.
colobrio is offline   Reply With Quote
Old 08-21-2020, 04:59 PM   #306
Roadphantom
Drives: FR-S - STX
Pretty normal it is a bit too loose on power IMO. I am on stock lsd and ran 5k/8k shortly as well, now on 350/450 and really happy with the Karcepts front sway bar and softer than oem rear sway bar.
Roadphantom is offline   Reply With Quote
Old 08-21-2020, 06:09 PM   #307
ka-t_240
I have 500/lb springs all the way around on RCE T2, car has always been loose, I am fine with oversteer, but know it kills the tires/looses some time. I am at -2.5* camber in the rear, so guess I am less than most with dedicated STX setups.
ka-t_240 is offline   Reply With Quote
Old 08-21-2020, 06:30 PM   #308
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If you've got a few events under your belt (or at least a solid TnT) just change something. More front spring or bar might help you build confidence in the car. Hell even just dropping the rear ride height or upping the front tire pressures, maybe a few clicks on the rear damper. You can always backtrack if you don't like it.
Alignment can play a pretty big role as well but you probably got decent specs to start with.
ineedyourdiddly
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 10:05 PM
