| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Scion FR-S 2013
P0352 ignition coil “B” primary/secondary circuit
Wondering if any has had his code pop up and what did y’all do to fix it?
#2 |
Señor Member
I see that this is your first post so welcome to the forums. Misfires are a common issue with our motors. If you do a search you will see there are many threads on it. The TL/DR is sooner or later you will need to replace the coil. In the short term if you swap around a coil from the opposite side of the motor you will probably find it wont trip a CEL for a period of time.
1974 TA22 Celica
2013 86 GT |
#3 | |
Thanks for the welcome and thanks for the advice will do! Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Palehispano For This Useful Post: | Turdinator (08-19-2020) |
| CEL P0351 Ignition Coil "A" Primary Control Circuit/Open | romin | Engine, Exhaust, Transmission | 468 | 11-26-2021 04:05 PM |
| Coil Pack question (P0351/P0352 Codes) | KN0W | Engine, Exhaust, Transmission | 2 | 10-10-2019 03:33 PM |
| P0352 - Coil Pack or Actual Curse? | thE_iyE | Issues | Warranty | Recalls / TSB | 11 | 04-20-2019 07:33 AM |
| Has anyone resolved their ignition coil CEL issues? (P0351, P0352, etc.) | edward | Issues | Warranty | Recalls / TSB | 41 | 11-06-2017 07:48 AM |
| CEL P0351 Ignition Coil "A" Primary Control Circuit/Open | Rossi | AFRICA | 18 | 02-02-2016 05:26 PM |
