Old 08-16-2020, 01:41 PM   #18621
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Brilliant design!! It'd make quiet a few forum members very happy..
Except 1 particular member who's name shall not be used. It's never good enough for them.
MS, CSCS, TSAC-F, CPT
The Following 3 Users Say Thank You to weederr33 For This Useful Post:
JD001 (08-16-2020), soundman98 (08-16-2020), spike021 (08-17-2020)
Old 08-17-2020, 07:06 PM   #18622
spike021
spike021's Avatar
I'm a software engineer that works with a lot of metrics, monitoring tools, and that sort of thing.
So lately I've gotten a bit tired of the 2017+ digital gauge cluster. As nice as the coolant temp/oil temp/battery voltage screen is, it reeeally sucks because it doesn't show exact numbers, and it turns monitoring your car vitals into a guessing-game, which isn't safe while in-motion.
While I do have an Ecutek Connect and a really nice app for it on my phone to make custom dashboards to monitor all kinds of metrics, I didn't really want to use that approach for full-time monitoring because it can be distracting if notifications pop up or if someone calls me, etc., since I have a work pagerduty app and all matters of things that can interrupt the screen.
So anyway, I wanted to start building out some additional monitoring that I can keep an eye on as needed.
I decided to go with a P3 gauge in the AC vent since I can connect it to my OBD for power/ground/data + 2 analog inputs if I ever want to do that, and it can present any data available from the ECU. So for now that'll give me my oil temp as an exact number, but also allow me to switch to other data if I'm so inclined.
I ordered that and should receive it this week; the install looks super easy.
After seeing @Ultramaroon and others mention it in threads that popped up while doing gauge/pod research I ordered a dash-vent block8head pod last night. And then I'll likely be ordering the Defi DF Red Racer N2 Pressure Gauge for oil pressure.
I was thinking about going with two regular gauges on the dash, but I think for now this should be enough, especially since the P3 can show multiple metrics.
I don't need to see _everything_ at once, and I'm only NA so no boost to keep track of so I figured that will all be sufficient!
I'll post when everything is installed! Or maybe the P3 first since that'll arrive first.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 4 Users Say Thank You to spike021 For This Useful Post:
MrSkubi (08-18-2020), soundman98 (08-17-2020), tehShirt (08-18-2020), Ultramaroon (08-17-2020)
Old 08-17-2020, 07:44 PM   #18623
Chuckls
Moutain Runner
Powdercoated my wheels
Chuckls is offline   Reply With Quote
Old 08-17-2020, 11:41 PM   #18624
You are going to love it. IMO, position and orientation are dead on.
spike021 (08-18-2020)
Old 08-18-2020, 01:04 AM   #18625
spike021
spike021's Avatar
I'm excited!
The Following User Says Thank You to spike021 For This Useful Post:
Ultramaroon (08-18-2020)
Old 08-18-2020, 11:22 AM   #18626
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Originally Posted by Kiske View Post
Spent the weekend prepping the ol' Turbo kit for sale. Just waiting on a couple of replacement silicone couplers to arrive. Hope it will bring just enough to let me finish my other engine build. :P
Attachment 191205
You have a buyer yet?
CincyJohn is offline   Reply With Quote
Old 08-18-2020, 02:26 PM   #18627
norcalpb
norcalpb's Avatar
Hit 150,000 miles and did a celebratory drive through car wash.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
MJones_RB (08-19-2020), NoHaveMSG (08-18-2020)
Old 08-18-2020, 02:29 PM   #18628
spike021
spike021's Avatar
Apparently it may not be quite so easy. Has anyone in here installed this and have tips on how to secure the OBD2 "control box" and cabling? The P3 install video literally says something like "next, secure the box and cables" and then completely skips that part, and almost every video on YT does the same thing lol. So I'm guessing everybody has a hard time and is to embarrassed to show it on video, except one dude who has a 1 hour video on his whole process, but even he has trouble.
@Kaotic Lazagna and I were thinking of removing the dash panel under the steering wheel, which would free up space to maneuver the cables through the vent opening and down to the footwell, then figure out where to ziptie the cables, and then use velcro/command strips to stick the control box to the back of that panel, then re-install it.
if you have any tips that would be helpful
Old 08-18-2020, 02:46 PM   #18629
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't have a car wash I fit in local to me
Old 08-18-2020, 02:58 PM   #18630
norcalpb
norcalpb's Avatar
Is that because you are too low? The one I use has a relatively high walled “wheel chock” you need to drive into and I barely clear with my STi springs. I bet my car looks so funny slowly rolling over that thing.
Old 08-18-2020, 03:49 PM   #18631
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, too low. I think it would be tight for a stock car at the places close to me. There is one about 15 miles away that doesn't have the wheel chock, you drive through it with your pace directed by lights. I hit it every time I go by.
Old 08-19-2020, 10:59 PM   #18632
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Killed a crap ton of grasshoppers and put another couple cycles on the Yoko's at the Top Gun event in Montana.
Breezio is offline   Reply With Quote
The Following 4 Users Say Thank You to Breezio For This Useful Post:
MJones_RB (08-20-2020), norcalpb (08-20-2020), OrangeGuitar (08-20-2020), tehShirt (08-20-2020)
Old 08-20-2020, 05:02 PM   #18633
Chuckls
Moutain Runner
I'd like to see that video!
Old 08-20-2020, 11:28 PM   #18634
Breezio
Breezio's Avatar
Sure.
Unfortunately all my runs on Saturday were dirty, so here is my best scratch run.
Sunday I did get some good clean runs, unfortunately no video of the fastest, but here is the second best. This was .8 second slower then my best, which was good enough to get me 9th PAX out of 140 drivers.
The Following User Says Thank You to Breezio For This Useful Post:
dpfarr (08-21-2020)
