Old 08-17-2020, 07:36 AM   #15
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
The Fumoto Valve is also very useful and makes the oil change on these cars hassle free.
SUSPECT_BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to SUSPECT_BRZ For This Useful Post:
Flarpswitch (09-05-2020), Magyarman (08-22-2020)
Old 08-17-2020, 07:57 AM   #16
wbradley
Sarcastic SOB
wbradley's Avatar
Personally, I'd call the dealer and tell them that according to the dipstick, they overfilled your oil. Now, either they drain/fill to correct level or tell you it's ok, and ask them to email you that reply so they are responsible.
Using 0W20 oil, overfilling will allow the crank to dip into the oil pan as the car moves, possibly causing the oil to foam up. Not sure otherwise what is the detriment but that is added resistance inside the engine.
The Following User Says Thank You to wbradley For This Useful Post:
Windycitystig (08-17-2020)
Old 08-17-2020, 01:54 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You would have to go quarts over for the level to hit the crank in this engine. Just FYI.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
Magyarman (08-22-2020), soundman98 (08-17-2020), strat61caster (08-21-2020), thomasmryan (09-01-2020)
Old 08-17-2020, 02:06 PM   #18
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Another thing to keep in mind is 0w20 is so thin, it’s easy for it to move up and down on the dipstick. So I’ve found it’s difficult to get an accurate read. If it’s a little above the highest fill mark I wouldn’t worry. Mine pretty much always reads that way. I usually check after I’ve been driving for a while, turn off the car, and wait 5-10 minutes before checking the level.
I also don’t lose very much oil at all between changes, which is surprising with such thin oil.
I use either the Toyota/Subaru 0w20 or Mobil1
JesseG is offline   Reply With Quote
The Following User Says Thank You to JesseG For This Useful Post:
indio22 (09-01-2020)
Old 08-17-2020, 08:47 PM   #19
JesseG
JesseG's Avatar
I take that back OP, your first picture makes it look like it’s WAY overfilled. That wouldn’t be a good thing, and I would drain some oil to be safe. And check the oil level again before you drive. Typically my car reads just slightly above the highest fill mark, or right at the line.
Old 08-22-2020, 08:20 PM   #20
indio22
Drives: 2014 BRZ
I'm going to change the oil myself, just to be sure and because I recently bought the car. Start with a clean slate.
I read through the oil threads in this forum and man, lots of differing opinions on oil brands, lol. I'll try "Mobil 1 Advanced Fuel Economy Full Synthetic Motor Oil 0W-20" from Walmart 5.8qts.
Reading various discussion here, seems like most people recommend using a Subaru oil filter rather than aftermarket. But there might be two kinds, blue and black (latter supposedly from Japan).
Should I just go to a Subaru dealer and have them give me the correct filter, or is that too pricey? Where do people usually get their filter? I saw this on Amazon for the black version:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
indio22 is offline   Reply With Quote
The Following User Says Thank You to indio22 For This Useful Post:
JesseG (08-30-2020)
Old 08-22-2020, 10:05 PM   #21
AJ32162
Drives: 2019 BRZ with Performance Package
They are listed on eBay for less.
AJ32162 is offline   Reply With Quote
Old 08-22-2020, 10:16 PM   #22
WildCard600
WildCard600's Avatar
Drives: 2020 86
I got a three pack with washers for the drain plug.
https://www.ebay.com/itm/OEM-Subaru-...53.m2749.l2649
WildCard600 is offline   Reply With Quote
Old 08-22-2020, 10:22 PM   #23
soundman98
ProCrastinationConsultant
soundman98's Avatar
opinion and preference. it's all just opinion and preference.
i believe every single oil that is sold in america must have a label about how it conforms with the SAE and API standards. from the bargain-bin 'walmart' oil, to the premium products like royal purple.
scroll down to 'motor oil designations', and API/ILSAC "starburst":
https://www.pennzoil.com/en_us/educa...ended-use.html
by those standards, the bargain walmart oil offers no difference in performance than the most premium of oils. any choice in oil over the store-brand stuff is purely for your personal comfort.
and filters aren't all that different either. while more premium filters do in fact offer some other filtering options, as someone once told me, "even chicken wire can filter 0.1 micron particles if you test it right".
change it at the required intervals, live your life. anything beyond that is pedantic for the interest of being pedantic.
i personally use castrol synthetic, and purolator boss filters, but it's solely to make myself feel better, and only deny that to myself.
WildCard600 (08-22-2020)
Old 08-26-2020, 02:33 PM   #24
indio22
Drives: 2014 BRZ
I ended up ordering one of the black genuine Subaru oil filters online - and it arrived today dented. Not badly dented, but two dents on the top nevertheless. I don't particularly feel like putting a dented oil filter on my BRZ.
So now I've got to return that dented filter, and I don't want to wait around for another one in the mail. I can go to Subaru dealer and buy a genuine oil filter (probably the blue version people don't seem to recommend). Or go 3rd party filter.
I've read that genuine Subaru filter matters - and that it does not. What a pain just to change some oil. I never cared much about oil or filter with my older 4x4s. Just used whatever.
Old 08-26-2020, 02:41 PM   #25
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
My local dealer stocks the black filter for the BRZ.
The Following User Says Thank You to dragoontwo For This Useful Post:
Old 08-27-2020, 04:49 PM   #26
indio22
Drives: 2014 BRZ
Thanks for the tip. Called my local dealer and yep they had the black filters - so I picked up two. Also got the little drain plug crush ring. I had been planning to re-use the existing ring. This is first time I recall any of my vehicles having a drain plug crush ring.
Old 08-28-2020, 11:28 AM   #27
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Regarding the oil level, my car has been serviced at Toyota Brussels and at the most knowledgeable (and only!) 86 specialist in France, and both of them always fill the car to about the level shown by OP.
I've come to believe this is more or less standard procedure for oil changes on these cars.
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
JesseG (08-29-2020)
Old 08-28-2020, 02:20 PM   #28
ls1ac
ls1ac's Avatar
If you really care, you can buy a cheep pump driven by a drill that has a 1/4 in line for the inlet. You put it down the dip stick hole. It is sold at most auto parts stores for draining inboard boat motors. I think under $20. They are kind of a one time pump. The rubber vanes seem to fail no matter what i flush with.
Dipstick leak ? Geex Issues | Warranty | Recalls / TSB 7 12-17-2019 03:43 AM
Dipstick removal Geex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 03-06-2019 01:55 PM
Oil level on dipstick... Da Brz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 11-21-2016 06:44 PM
oil on dipstick but not on hole ZionsWrath Engine, Exhaust, Transmission 2 09-08-2014 07:46 PM
Show me your dipstick.... Trashed675 Engine, Exhaust, Transmission 6 01-03-2014 01:09 AM
