Old 08-11-2020, 07:02 PM   #43
ElijahF
Not funny
ElijahF's Avatar
Drives: 2019 Subaru BRZ Premium
2019 around 15k miles, 93 octane, and I get crickets. You can hear it if you stand in front of the car, but it's not obnoxious. But I mean what do you expect? It's a car. It makes noises.
Originally Posted by Yoniyama View Post
To me, the FT-86 is a 85% complete package. The driver is supposed to fit the last few items in accordance with his personal preference. As stock, it shows potential, but distinctly deficient and cries out for the 'finishing touch'.
ElijahF is offline   Reply With Quote
The Following User Says Thank You to ElijahF For This Useful Post:
JesseG (08-11-2020)
Old 08-11-2020, 10:44 PM   #44
AlexBRZ2
Drives: 2020 BRZ Blue Pearl
Originally Posted by Chamaco View Post
2014 here and mine doesn't chirp. Now, if I go to a specific gas station, it starts to chirp.
I realize you likely have some different gas stations in Puerto Rico than I may have in Florida, but which ones make it chirp vs. which ones don’t make it chirp for curiosities sake?
AlexBRZ2 is offline   Reply With Quote
Old 08-11-2020, 11:28 PM   #45
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Originally Posted by LimitedSlip View Post
So it does have some difference, and from what others have said the additives in the fuel might be more important than octane. When it comes to silencing the crickets.
I swear as soon as the gas stations around here start switching to “winter” fuel the crickets start chirping. And I’ve had much better luck with Top Tier fuel.
JesseG is offline   Reply With Quote
Old 08-11-2020, 11:30 PM   #46
JesseG
JesseG's Avatar
I agree, the twins aren’t meant to be a Rolls Royce. Still, the fuel pump can get loud on the twins. Almost to the point of being distracting. But I love the heck out of my car.
The Following 2 Users Say Thank You to JesseG For This Useful Post:
beltax90 (08-11-2020), ElijahF (08-12-2020)
Old 08-11-2020, 11:49 PM   #47
beltax90
beltax90's Avatar
Drives: 2010 corolla
yeah it took a while to get used to the tractor sounds that this engine makes. I hardly notice them now.
beltax90 is offline   Reply With Quote
Old 08-12-2020, 01:46 AM   #48
Neurytic
Neurytic's Avatar
Drives: 2013 Asphalt FR-S
MY2018 BRZ Here. I drove 14k on Costco 91 Gas. Not a single chirp. JUst switched to e85. Now it CHIRPS LOUD. Reminds me of my MY13.
Neurytic is offline   Reply With Quote
Old 08-13-2020, 10:37 AM   #49
Chamaco
Drives: Silver FR-S
I used to go to one that is called Puma (1 of the very few with 93oct) and they (like the other 95% of gas stations here) use 10%-15% ethanol in there fuels. A friend (he works with gas pumps and testing fuel grades) recommended Ecomaxx (which has no ethanol content) because he found out that Puma was not consistent with their 93oct grade fuel sometimes measuring a little under 93oct. When he tests Ecomaxx 93 he usually gets that or a bit above 93, so I started using it and within the 1st fill up the crickets starting fainting away. By the 2nd tank they were completely gone. After Hurricane Maria ran us over, getting picky with fuel brands was no option, so I started using whatever 93 or 91 was available (or could find) and the crickets came back as soon as I use other gas other than Ecomaxx with no ethanol in it.
In short; I believe is the ethanol that makes the pump chirp, but that's me with my own experience.
Chamaco is offline   Reply With Quote
The Following 3 Users Say Thank You to Chamaco For This Useful Post:
AlexBRZ2 (08-21-2020), bcj (08-13-2020), JesseG (08-17-2020)
Old 08-17-2020, 08:34 PM   #50
JesseG
JesseG's Avatar
I need to become friends with a fuel tester in my area! That is very interesting stuff! I’ve always wondered how good the QC was for gasoline octane levels and additives.
Old 03-22-2021, 02:09 AM   #51
ClevelandFRS
ClevelandFRS's Avatar
Drives: Scion FRS 2013
Running a 2013 FRS. I've tried every fuel type under the sun. Some are far worse with chirping after emptying the tank and trying something else. Some are very moderate, some are very light with chirps but absolute none really got rid of them entirely.
ethanol content % didn't matter. E0 didn't matter. It chirps no matter what.
ClevelandFRS is offline   Reply With Quote
Old 03-22-2021, 06:46 AM   #52
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Same experience in Europe.
95-10 (equivalent to US 91 w/ max 10% ethanol) make the pump chirp
95-5 (same with max 5% ethanol) does too, possibly to a lesser extent
98-5 (equivalent to US 93-94, w/ max 5% ethanol) doesn't at all, no matter the brand
Consensus is that the higher ethanol content causes the pump to chirp. It's one of the things that kept me away from an E85 conversion.
Also, I saw or felt no performance difference whatsoever between any of these fuels. Car's stock and is a daily, YMMV (literally & figuratively) if you track a modded car.
alex87f is offline   Reply With Quote
Old 03-23-2021, 02:36 PM   #53
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Crickets love cheap gas. Higher quality fuel shuts them up.
MJones_RB is offline   Reply With Quote
Old 03-24-2021, 06:35 AM   #54
There is no consensus on this subject. There are just as many people that have crickets on higher octane fuel as ones that don't have them on lower. Same applies for ethanol content.
It is pretty much an individual experience and what works for you may not for the next guy.
Old 03-24-2021, 07:01 AM   #55
alex87f
Meow
alex87f's Avatar
Call it the European consensus then, our fuels may be a little more tightly regulated as far as Ethanol content, and since they're quite taxed, fuel providers probably try to cram as much Ethanol as they possibly can in any liter of fuel they sell.
This results in there being an availability of fuel with an almost-fixed 5% ethanol and one with a similarly almost fixed 10% content. And our -admittedly relatively small- user base seems to have found a correlation between eth content and chirping.
Old 03-24-2021, 07:20 PM   #56
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I can get almost straight ethanol, no crickets.
PetrolioBenzina is offline   Reply With Quote
2020, fuel, gt86, noise, tinder
Fuel Pump and clutch issues on 2017 fixed? sfdai0 Issues | Warranty | Recalls / TSB 8 05-05-2017 08:24 PM
OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu ndreim Engine, Exhaust, Bolt-Ons 5 11-23-2016 11:36 PM
Driver Seat Bolster Worn/ Fuel Pump Chirp QuagmireBRZ Issues | Warranty | Recalls / TSB 11 04-20-2016 11:18 PM
two years now, is there a fuel pump doesn't chirp yet? chenshuo CANADA 41 07-18-2014 11:07 AM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 02:40 PM
