#10935 | ||
Drives: SWP BRZ
https://photos.app.goo.gl/ZGDF7gk8jBha5qBV7 https://photos.app.goo.gl/mWh7fjk8tBXC3s2J9 Quote:
also isnt shipping expensive since it's rally heavy?? |
#10936 | |
Drives: Hot lava FRS Monogram Charizard
Sent from my GM1915 using Tapatalk |
#10937 | |
#10938 | |
Drives: SWP BRZ
Sent from my SM-N950U1 using Tapatalk |
#10939 | |
#10940 | |
Drives: SWP BRZ
but when i engage it, volt meter did not move at all. hope everything is ok Thanks man~! i will update the thread once i test it |
#10941 |
#10942 |
Drives: SWP BRZ
I opened controller unit and fuse is fine.
i think one of cable in controller is not activating the throttle switch. which means, one of the cable may be damaged... i posted it on sale anyway..i guess time to go with real F/I i like to thank you for look into this for me
#10943 | |
#10944 |
Drives: SWP BRZ
#10945 | |
Drives: they all have 4 wheels
| The Following User Says Thank You to CY86 For This Useful Post: | 86TOYO2k17 (08-17-2020) |
#10946 | |
#10947 |
So quick update.....I did a few things to try and bring temps down. Now while I really didn't make my charge temps lower I did notice operating temps went down roughly 5 degrees. So before during normal driving after driving around town temps would sit right around 130 (stoplight) at idle then while cruising go down to about 115 and under boost go back up to 120. This time around in similar 95-100 degree weather I noticed idle temps were around 125 would drop to around 110 and under boost go up to 115.
In 75 degree weather. Idle temps sat around 105 drop to 95 under cruising and back up to 109 under boost. Now in comparison with other conventional boost applications. 120 charge temps seems to be normal and for me on hot summer days seems to be my max given without an intercooler. So it's safe to safe I'm good to run without one. So a few of the things I did was wrap the pipes with gold heat wrap. Added a filter heat shield to the in bay filter. Added a heatsink on the maf sensor. And installed these fin pipes in place of where an intercooler would sit. those pipes act almost like a large heatsink. ![]() ![]() ![]() Sent from my GM1915 using Tapatalk |
| The Following 4 Users Say Thank You to BlOody_BoOger For This Useful Post: |
#10948 |
Drives: 2017 Toyota 86
Do the fins go inside the pipes as well, or just on the outside?
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
