Old 08-03-2020, 04:32 PM   #18607
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Went to AutoX Saturday
Thanks @turtlesharkshooter for the awesome pics!
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
MJones_RB (08-04-2020), norcalpb (08-04-2020)
Old 08-03-2020, 10:25 PM   #18608
aaron_latimer
aaron_latimer's Avatar
Drives: 2017 Toyota 86
Polished and Waxed my car for the first time.
Honestly was super nervous to polish/wax my car. Thankfully the compound I used isnt too aggresive. So it helped a novice like me. One day I'll be pro at it haha. Check it out.
aaron_latimer is offline   Reply With Quote
The Following User Says Thank You to aaron_latimer For This Useful Post:
Old 08-04-2020, 01:50 PM   #18609
6ixbrz
6ixbrz's Avatar
Drives: 2017 Subaru BRZ
Made a video cleaning my wheels.
I may have gone a little over board here, but I deep cleaned my stock wheels and put a protective coating on them to help with future washes and brake dust.
6ixbrz is offline   Reply With Quote
The Following 2 Users Say Thank You to 6ixbrz For This Useful Post:
Busybee (09-13-2020), MJones_RB (08-04-2020)
Old 08-04-2020, 10:45 PM   #18610
soundman98
ProCrastinationConsultant
soundman98's Avatar
we've got a few threads for this, both showing off, and asking questions!
couple notes for the future:
yeah, it usually takes me about 1-2 full days to do a car-- i'll usually try washing/claying the night before, and then it leaves the entire day for buffing and waxing, with time to clean up the interior while the wax is setting up in the end. last time i did my car, i was doing it at 4-5hr stints at night, it took me a full week.
did you use the same bucket/soap/mitt on the wheels as you did on the rest of the car?
did you clay bar the car after washing but before buffing? claying the car makes for the best paint setup-- it will strip off any contaminants in the paint, which means you need to do less work with the buffer to get a nice finish.
i use the larger 'professional' buffer from HF(harder to learn with, but can offer better technique in certain circumstances, you got the right one for starters), i usually leave it at about halfway on the speed, but then bump the trigger to dial in the speed i really want the pad to spin at..
it looks like you did most of it outside, car detailing is best done in the shade. for that, i usually empty out the garage and park it in the middle of the two bays, or set up some canopies over the car. the reason it's best done in the shade is that it keeps the paint and body panel temperatures consistent across panels. buffing heats up the paint and 'moves' it around on the car-- all things equal, if you're buffing a scratch that goes across an area that's in the shade, but also in the sun, the same force/time spent into the buffer to correct the scratch in the shaded area will be 2-4 times more force/time than the sunny area will need.
i've also found that working outside doesn't have the greatest of light-- i strapped a 4' led work light to a hand truck so i could see the blemishes in every panel. in the past, i've used halogen lights sitting on the floor, or those drop-down 'work lights' to see where blemishes are and how far i need to correct them. it becomes very easy to miss parts of the body that you regret later not addressing!
one of the techniques that i always try to teach people is to treat the paint as a very firm clay that you're smearing around on the car body. pushing in one direction and then pushing the opposite direction can help balance and fill in blemishes that just straight moving from one side to the other won't fix. for me, it also helps understand that if you put way too much pressure in, it can cause damage to the surface, just as sticking your finger into the side of a clay pot
and lastly, i don't really ever use all 3 steps. i vary everything based on how bad it really looks. compound is the most abrasive, polish is least abrasive.
for things like bird poop stains, and scratches that are very obvious but can't be felt with a fingernail, a compound is really needed, or double the work with polish (i usually just either put some compound on a towel and work it by hand, or will use the machine and do a double-pass with polish to get the same effect). for water spots, and scratches that can be just barely be seen, the polish is all you need.
you're going to notice this in about 2-3 days now, but painters tape is your friend. any black textured plastic pieces that you might have accidentally bumped with the buffer pad and the compound/polish are going to turn white in those spots(i haven't met anyone that can do a whole car and not hit a few of them). so before you start, it's best to cover over all those spots with blue painters tape to minimize the damage(and blue painters tape doesn't like to release if it's been out in the sun for a while, another reason to do it in the shade!). those pieces can be brought back by mothers Back To Black, or similar products, but it's really a pain to use-- it requires multiple recoatings, and seems to wear off very fast.
and lastly, i hope you had fun! there's ways to do it faster, and there's ways to do it slower. but the most important thing to take away from it is that there's a million different ways, techniques, and products to do it, and they all end up with the same result!
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
SkyeHack (08-25-2020), wolffbite (08-18-2020)
Old 08-06-2020, 09:57 PM   #18611
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Changed the oil for upcoming track days. First time doing it myself on this car, easiest oil change I've ever done - no engine covers, no cartridge filters (my Saab had).
N_Raged is offline   Reply With Quote
The Following User Says Thank You to N_Raged For This Useful Post:
soundman98 (08-09-2020)
Old 08-07-2020, 09:36 AM   #18612
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
I drove it to work, owned it for almost two months and there is only 600KM on the clock...
SUSPECT_BRZ is offline   Reply With Quote
The Following User Says Thank You to SUSPECT_BRZ For This Useful Post:
MJones_RB (08-07-2020)
Old 08-09-2020, 06:12 PM   #18613
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Spent the weekend prepping the ol' Turbo kit for sale. Just waiting on a couple of replacement silicone couplers to arrive. Hope it will bring just enough to let me finish my other engine build. :P
The Following User Says Thank You to Kiske For This Useful Post:
Old 08-10-2020, 05:26 AM   #18614
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Got this. Now it's off to ceramic coating. Can't wait to finally install it
MrSkubi is offline   Reply With Quote
The Following 4 Users Say Thank You to MrSkubi For This Useful Post:
JonAvalon (08-25-2020), MJones_RB (08-10-2020), soundman98 (08-10-2020), weederr33 (08-10-2020)
Old 08-10-2020, 07:04 AM   #18615
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
nice pipes.
flushed the clutch system with fresh fluid. it needed it.
thomasmryan is offline   Reply With Quote
The Following User Says Thank You to thomasmryan For This Useful Post:
MrSkubi (08-10-2020)
Old 08-11-2020, 01:37 PM   #18616
N_Raged
New pads and fluid
MJones_RB (08-11-2020)
Old 08-15-2020, 02:56 PM   #18617
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Changed my rear brake pads after 52k miles. Man, I love how easy it is on the Brembos!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
spike021 (08-17-2020)
Old 08-16-2020, 10:01 AM   #18618
JD001
JD001's Avatar
Drives: Subaru BRZ
Can you see the state of pads without taking the wheels?
The Following 3 Users Say Thank You to JD001 For This Useful Post:
NoHaveMSG (08-17-2020), soundman98 (08-16-2020), spike021 (08-17-2020)
Old 08-16-2020, 12:50 PM   #18619
weederr33
weederr33's Avatar
Actually yes! I can get a good idea of how low they are. If you peek at the top or bottom of the caliper you can see. Of course, not for the inside pad though.
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
JD001 (08-16-2020), soundman98 (08-16-2020)
Old 08-16-2020, 01:16 PM   #18620
JD001
JD001's Avatar
Drives: Subaru BRZ
Brilliant design!! It'd make quite a few forum members very happy..
The Following 2 Users Say Thank You to JD001 For This Useful Post:
