Old 07-24-2012, 04:12 PM   #1387
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I think he means that the PARTS are capable of 650HP, not that the car will make that.
I'm not saying you won't be able to make that in the car, but IMO it'll be awhile before that's happening. Lots of new parts and a lot more tuning time before we see anything like that. Honestly, it's too much for anything but a drag car for RWD platforms anyways.. well and dyno queens. 650HP in a 2700lb car is not needed on the street.
he says he reached it. :X
its not just theory according to him
Old 07-24-2012, 04:37 PM   #1388
Don@Accelerated
Don@Accelerated's Avatar
No i'm saying that I have sorted the hardware to be capable of 650hp in its current packaging location and fitment.
Sorry didn't want that to be misleading.
Don@Accelerated is offline   Reply With Quote
The Following User Says Thank You to Don@Accelerated For This Useful Post:
Bonburner (07-24-2012)
Old 07-24-2012, 04:38 PM   #1389
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by Don@Accelerated View Post
I've been working on updates today for the system. I've reached 650HP now w/ no cutting under the car. The front bumper support will need to be notched for the larger intercooler.
Upgrading from the std kit to the 650hp Setup will be roughly $1200. If that was too much we could also accomodate 500,550, setups as well w/ the same thing.
Don
What was.done to get this much power!?!?!? You going to make a new thread for the more powerful Turbo set? 650whp!?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 07-24-2012, 04:39 PM   #1390
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
LOL read above you.
TouchMyHonda is offline   Reply With Quote
Old 07-24-2012, 04:39 PM   #1391
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by carbonBLUE View Post
what?! lol i was there too...
Well I had the White FR-S. I wasn't there very long though. Someone told me there was a 2JZ FR-S there but I didn't see it.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-24-2012, 04:42 PM   #1392
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That's not what he meant. I saw the car and was in it yesterday so I understood what he meant instead of how it read.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 07-24-2012, 04:42 PM   #1393
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
No problem, thanks for explaining.
I'd just like to know why the air intake for the turbo (I think that's what it is) is in the back of the engine bay and not next to the front on the other side of the intake - considering how this car can be made to mirror the intake on the other side.
Would that be a bad set up?
I really don't know much regarding turbo/turbo set up schematics - hoping to learn ~
What's that metal tube closest to the bottom for?
Thanks ~
Old 07-24-2012, 04:43 PM   #1394
SkullWorks
Drives: SSM LT MT BRZ
TiAl V-band housings are designed so that the housings are interchangable in form factor between GT25 all the way to GT37
he just hung a bigger Turbo and stuffed a bigger intercooler. (hopefully a MV-R wastegate also)
Old 07-24-2012, 04:46 PM   #1395
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Thanks ~
We talked about that yesterday. IIRC he could run it like that if the OEM strut tower brace is removed.
The metal tubes are intercooler piping. On the left side (of the car, right side of the pic) is the pipe coming from the IC to the TB and on the right side of the car (left side of pic) is from the turbo to the intercooler.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Bonburner (07-24-2012), tripjammer (07-24-2012)
Old 07-24-2012, 04:51 PM   #1396
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Thanks for the explanation!
Have there been any in motion/field temperature measurements taken from where the rear intake is?
I'm curious how much heat the d-4s makes back there
I see there isn't much room for an aftermarket strut that hits the side and back center :/
Old 07-24-2012, 04:51 PM   #1397
Synack
Boosted
Synack's Avatar
Drives: Sideways
Thanks ~
Well one thing is piping ON TOP of other piping, clutter. And placement doesn't really matter as long as water can't reach it because it's going to go through the intercooler anyway, which chills the air.
The Following User Says Thank You to Synack For This Useful Post:
Old 07-24-2012, 05:10 PM   #1398
rusty959
Drives: DGM BRZ limited
As stated before, this is false. An intercooler isn't 100% efficient. It may cool hotter air more than cooler air due to efficiency and the laws of cooling and all, but hotter air will still be hotter after the intercooler than cooler air will be after the intercooler. It may or may not be enough to make a difference, but it will still be there.
As far as why the intake is there, I doubt 3" piping will fit above the engine, but it might. Even if it would, Im not sure the air temp infront of the engine would be all that much better than where the filter is there. It would definitely be a lot of work.
rusty959 is offline   Reply With Quote
Old 07-24-2012, 05:14 PM   #1399
Synack
Boosted
Synack's Avatar
Drives: Sideways
Yes this I agree on. It's likely not enough to be a difference.
Old 07-24-2012, 05:55 PM   #1400
Don@Accelerated
Originally Posted by 86design View Post
very nice! so when is this kit ready to buy?
Are you looking to purchase the kit? If so PM me to work out the details!
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
