Old 06-24-2020, 12:07 PM   #15
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by Yoshoobaroo View Post
This is the real gain with a free-er flowing intake, I noticed it on the first drive with my TRD intake. The throttle response is better, and you get a little different sound.
My wife (as a passenger) noted that the car was smoother, I had the sound tube blocked (plumbing is still in place). The next big difference in how the car feels was through the STi engine and transmission mounts.
All in, I'm pleased with the mods I have had done.. next upgrade will be tyres, toying with Cup 2 Vs Pilot 4? We can't get 4S in the UK in OEM fitmet.
Old 06-26-2020, 03:55 AM   #16
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
Alastor is offline   Reply With Quote
Old 07-07-2020, 03:47 PM   #17
Alastor
Alastor's Avatar
Hello again
I have not yet obtained the ecu. I'm waiting for the mechanic to find a way to unlock my map.
In the intake instructions, it indicates that you have to remove the snorkel, they never removed it. Could it be the reason why it does not throw more power?
Translated by google translator, I hope you can understand it.
Old 07-07-2020, 07:41 PM   #18
Kodename47
Kodename47's Avatar
Drives: UK GT86
It might make slightly more power, but nothing noticeable.
OFT or EcuTek is all you need for the ECU, no fancy unlocking needed.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-13-2020, 03:38 PM   #19
Alastor
Alastor's Avatar
Hello guys
I have gone to another workshop to get more power.
Knowing that supposedly the takeda intake did not give any extra hp in the shop where it was installed, we did a stock test and then it was given more hp.
I upload the images so that you can check the result.
Old 08-13-2020, 04:07 PM   #20
PulsarBeeerz
Drives: JRSC BRZ SOLD
Between the dark and lighter lines which is OEM and which is the intake?
PulsarBeeerz is offline   Reply With Quote
Old 08-13-2020, 04:48 PM   #21
pallen
pallen's Avatar
Drives: 2017 Toyota 86
If I'm reading it right, both have the intake, but the higher one is with a tune.
pallen is offline   Reply With Quote
Old 08-14-2020, 10:43 AM   #22
Alastor
Alastor's Avatar
Yes to are right. Sorry for my translator English
Old 08-14-2020, 10:56 AM   #23
86TOYO2k17
Drives: 2017 toyota 86
Hello guys
For stock test did you let IAM get up to 1 before testing?
Old 08-14-2020, 04:48 PM   #24
Alastor
Alastor's Avatar
What means IAM?
Old 08-14-2020, 06:22 PM   #25
86TOYO2k17
What means IAM?
Ignition advanced multiplier. Stock tune is set to .7 on ignition start and needs to see certain parameters met while driving around before going up eventually to 1.
Difference between stock tune at .7 vs 1 is about 3-4% or 5-6whp.
The difference between stock tune at 1 IAM and a stage 1 OTS tune at 1 IAM is about 3-4% or 5-6whp.
So the difference between stock tune at .7 IAM and a stage 1 tune at 1 IAM is roughly 10-12WHP.
If you and your tuner don’t know about this and don’t properly monitor the IAM and get it up to 1 before the tune most likely your baseline was with IAM at .7 but your tune is probably set to start at 1 by default.
Very good chance you need to subtract 10-12whp from before and after dyno runs to account for IAM and tune. And whatever WHP gain is left over or maybe even missing now is most likely what your “CAI” achieved/contributed.
Old 08-14-2020, 08:46 PM   #26
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
So is the low run with a tune also?
Old 08-14-2020, 09:38 PM   #27
86TOYO2k17
I think his last dyno he posted was stock tune with intake vs custom tune with intake.
Old 08-15-2020, 12:42 AM   #28
x808drifter
LMGTFY
Yeah, that's what I am thinking.
So we have no idea how much of the gain is from an intake vs the tune.
I'm willing to bet.
Tuned with stock intake vs tuned with the aftermarket one will have less than 5hp gain on the top with everything else being nearly identical.
Takeda afe momentum Intake Kengo Engine, Exhaust, Bolt-Ons 4 01-21-2020 03:48 AM
FS: (NC) aFe Takeda Momentum Intake Jaw2218 Engine, Exhaust, Bolt-Ons 1 02-07-2019 09:46 PM
WTB GReddy momentum / Takeda momentum MagicznyKamil Want-To-Buy Requests 0 02-07-2017 07:57 AM
FS: Takeda Momentum Intake Vlady Engine, Exhaust, Bolt-Ons 10 12-14-2013 03:27 PM
FS: Takeda Momentum Pro Dry S Air Intake ***SOLD*** JPxM0Dz Canada Classifieds 11 09-10-2013 11:16 AM
