Drives: Toyota gt86 my19
Takeda momentum Dyno test
Hi
My Dyno test gt86 my19 with takeda momentum. After various tests, max hp is 200 and good torque, but to wheel down 40cv. There is no difference between stock and with takeda, something went wrong? It has been installed in a workshop specialized in Racing and reprogramming
Drives: Bone stock
Was this tuned for you're car using ecutek?
Sent from my SM-N960U using Tapatalk |
Was only tested before with stock and after with takeda, without ECU. Tomorrow will be known what hp get with ECU.
Drives: brz 2017 hksv2
there is no difference, because that intake doesn t provide gains compared to stock intake
it s that simple it s not an upgrade from stock, as stock is already a cold air intake |
| The Following 3 Users Say Thank You to tomm.brz For This Useful Post: |
Rust bucket enthusiast
As others have said, the intake alone really doesn't do anything for this engine
but that intake, ensures to give peaks of 9cv and 10nm. Why do they say something that is a lie?
because they know how to trick dyno plots to make false advertisment and sell things
often with stock tunes, if you change airbox and maf position, it offset the AFR leaning it out that brings more power in the immediate After a while LTFT can correct it and the gains are gone Tuned cars then can show even less differences because the tuner scales the maf for the intake installed so the final result is the same as with stock airbox only differemt thing is intake sound maybe, and worse maf voltage signal stability bringing out lack of smoothness |
| The Following User Says Thank You to tomm.brz For This Useful Post: | alphasaur (06-24-2020) |
Drives: JRSC BRZ SOLD
Thank you for taking the time to do so and share.
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | Yoshoobaroo (06-24-2020) |
#10 |
Drives: Bone stock
So far I think only GrimmSpeed or Mishimoto shows gains but tbh for the gain it's not worth the money. Unless mod bug kicks in or you just want the sound and bling under the hood. Drop in filter and call it a day.
#11 |
TRACKBREAD
I'm curious if the tune allows you to extract more power from it. Eagerly awaiting the dyno with the ECU flash.
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Joveen (06-24-2020) |
#12 | |
mishimoto cold air i really like it because of the position but umfortunately it can t fit my hks v2 All these aftermarket intakes will somewhat make random results while on stock tune, and when tuned they tend to give just a little bit more airflow at high rpm with speeds density they work better, if Speed density is well scaled |
#13 |
Drives: Subaru BRZ
I have the same CAi with a tune. The car does feel snappier, smoother and freer revving. Not dyno'd, the workshop was keen to get it tested but I haven't had the time to go back..
#14 |
TRACKBREAD
| Takeda afe momentum Intake | Kengo | Engine, Exhaust, Bolt-Ons | 4 | 01-21-2020 04:48 AM |
| FS: (NC) aFe Takeda Momentum Intake | Jaw2218 | Engine, Exhaust, Bolt-Ons | 1 | 02-07-2019 10:46 PM |
| WTB GReddy momentum / Takeda momentum | MagicznyKamil | Want-To-Buy Requests | 0 | 02-07-2017 08:57 AM |
| FS: Takeda Momentum Intake | Vlady | Engine, Exhaust, Bolt-Ons | 10 | 12-14-2013 04:27 PM |
| FS: Takeda Momentum Pro Dry S Air Intake ***SOLD*** | JPxM0Dz | Canada Classifieds | 11 | 09-10-2013 12:16 PM |
