Old 08-07-2020, 07:04 AM   #1
Lord Akbar
Lord Akbar's Avatar
Drives: 2013 BRZ premium
Angry CEL and traction control lights on after valve spring recall work
So about a month ago I took my 2013 BRZ (automatic) in to my local Subaru dealership to finally get the valve springs replaced and when I got the car back my CEL and traction control lights were on and the car jerks just before I come to a complete stop (happens around 1000-1500 RPM and only happens when on automatic trans and not when in "manual"). I took it back immediately and after a few days the dealership called me back and claimed this was happening due to carbon buildup and that I needed to have the camshaft position sensor and oil control valve replaced and it'll cost me $1,200 with parts and labor. They claimed it was due to lack of maintenance even though I only use 93 octane and I get full synthetic oil changes every 4,000-5,000 miles diligently, so I wasn't having it. I got on the phone with Subaru corporate and after some back and forth they were willing to pay for 100% of the repairs as long as it didn't exceed $1,200. Another week went by and my car was ready for pickup. When I picked it up it was driving fine for about a day or 2, then the CEL and traction control lights came back on and the car once again jerked upon coming to a complete stop. I took it back a 3rd time, they had it for another 2-3 days and then called me and said they ran codes, diagnostics and what not and said nothing seemed to be wrong and it could've just been a hiccup. I go to pick it back up yesterday and no lights are on and it's driving fine....for about 30 minutes and as soon as I get home sure enough it all happens AGAIN. I'm taking it back in a few hours here but I just wanted some input from anyone here if this happened to you and/or what could be causing this. This will now be my 4th time back and even though they're nice at the dealership, I don't think I can trust them anymore unfortunately. I apologize that this is lengthy but I wanted to make sure I covered everything. I'm not too knowledgeable when it comes to motors/engines so I appreciate any help. Thanks.
EDIT: code I’m getting is P0011 - intake camshaft position timing
Lord Akbar is offline   Reply With Quote
Old 08-07-2020, 07:14 AM   #2
kev0
Drives: '14
Can you get the codes read yourself and let us know what it is? My car does the same thing as yours. Car jerks when braking ONLY when the CEL and slippery lights are on. Once I clear them, the jerking stops which leads me to believe that the jerking is a safety measure the car does for some weird reason.
It doesn't happen when you put the car in neutral when stopping though. It's so weird. Some people will say it's limp mode, but I can go well above 3k RPM with my CEL and slip light on.
kev0 is offline   Reply With Quote
Old 08-07-2020, 07:48 AM   #3
Lord Akbar
Lord Akbar's Avatar
I don't have the tool to run the scan myself so I'll go to Autozone when they open and have them run it for me and I'll write down the codes then I'll post them here. And yes I also read that the car puts itself in limp mode to prevent damage, we'll see what the verdict is. Thanks for your reply!
Old 08-07-2020, 08:26 PM   #4
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Any updates ? What dealer is this ?
mswbrz is offline   Reply With Quote
Old 08-07-2020, 08:51 PM   #5
86TOYO2k17
Drives: 2017 toyota 86
You can go well above 3k in limp mode. Can you still manually shift when cel and traction light turn on because of this issue? Pretty sure Limp mode disables manual shifting with an auto.
Old 08-07-2020, 09:21 PM   #6
kev0
Drives: '14
Yup, I can still manually shift whenever I want. My CEL and slips are on but I don't think I'm in limp mode.
I've experienced real limp mode before on a previous tune and with that limp mode, I couldn't go above 2.5k.
Old 08-07-2020, 10:03 PM   #7
ls1ac
ls1ac's Avatar
Make sure you call Subaru with this information. You already have a case file as you called them before. DO IT NOW.
Dealer should have entered your VIN each time you went to the dealership.
Old 08-08-2020, 12:41 AM   #8
p1l0t
p1l0t's Avatar
Cam position sensor is an easy job to do yourself and cost between $50-$150 for the sensor depending on whether you buy OEM or not. Lots of threads on here about it.
mswbrz (08-09-2020)
Old 08-09-2020, 02:56 AM   #9
mswbrz
mswbrz's Avatar
Can can some one post a diagram or pic that shows which bank or valve is which , A, b ectName:  IMG_2114.jpg
I had this similar cell recently , had my boy swap the valve over to chase it and change if necessary , my cell has went away but every now and then I get a non symptomatic traction light appear
The Following User Says Thank You to mswbrz For This Useful Post:
p1l0t (08-10-2020)
Old 08-09-2020, 02:59 AM   #10
mswbrz
mswbrz's Avatar
Here is a pic of what dash does with no cell Atm . After I kill the car and start her up again it goes away .
Old 08-10-2020, 10:29 PM   #11
p1l0t
p1l0t's Avatar
EDIT: oops was thinking of someone else. Did you figure out which sensor it was?
Results of the Valve Spring Recall Work Magoo Issues | Warranty | Recalls / TSB 241 01-13-2022 03:38 PM
ABS and Traction Control lights after taking clock spring out. ProjectMidnight86 Cosmetic Modification (Interior/Exterior/Lighting) 7 02-03-2021 01:24 AM
Valve spring recall - where did you get it done? satisfied with the work? fiveoneoh Northern California 103 09-25-2020 03:10 PM
J02 valve spring recall, Toyota will not work on car drz400dude Issues | Warranty | Recalls / TSB 30 08-18-2020 03:15 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 01:10 AM
