Drives: 2013 BRZ premium
So about a month ago I took my 2013 BRZ (automatic) in to my local Subaru dealership to finally get the valve springs replaced and when I got the car back my CEL and traction control lights were on and the car jerks just before I come to a complete stop (happens around 1000-1500 RPM and only happens when on automatic trans and not when in "manual"). I took it back immediately and after a few days the dealership called me back and claimed this was happening due to carbon buildup and that I needed to have the camshaft position sensor and oil control valve replaced and it'll cost me $1,200 with parts and labor. They claimed it was due to lack of maintenance even though I only use 93 octane and I get full synthetic oil changes every 4,000-5,000 miles diligently, so I wasn't having it. I got on the phone with Subaru corporate and after some back and forth they were willing to pay for 100% of the repairs as long as it didn't exceed $1,200. Another week went by and my car was ready for pickup. When I picked it up it was driving fine for about a day or 2, then the CEL and traction control lights came back on and the car once again jerked upon coming to a complete stop. I took it back a 3rd time, they had it for another 2-3 days and then called me and said they ran codes, diagnostics and what not and said nothing seemed to be wrong and it could've just been a hiccup. I go to pick it back up yesterday and no lights are on and it's driving fine....for about 30 minutes and as soon as I get home sure enough it all happens AGAIN. I'm taking it back in a few hours here but I just wanted some input from anyone here if this happened to you and/or what could be causing this. This will now be my 4th time back and even though they're nice at the dealership, I don't think I can trust them anymore unfortunately. I apologize that this is lengthy but I wanted to make sure I covered everything. I'm not too knowledgeable when it comes to motors/engines so I appreciate any help. Thanks.
EDIT: code I’m getting is P0011 - intake camshaft position timing Last edited by Lord Akbar; 08-07-2020 at 11:28 AM. |
#2 |
Drives: '14
Can you get the codes read yourself and let us know what it is? My car does the same thing as yours. Car jerks when braking ONLY when the CEL and slippery lights are on. Once I clear them, the jerking stops which leads me to believe that the jerking is a safety measure the car does for some weird reason.
It doesn't happen when you put the car in neutral when stopping though. It's so weird. Some people will say it's limp mode, but I can go well above 3k RPM with my CEL and slip light on. |
#3 | |
#4 | |
Drives: 2013 brz limited / galaxy blue
Any updates ? What dealer is this ? Sent from my iPhone using Tapatalk |
#5 | |
Drives: 2017 toyota 86
#6 | |
Drives: '14
I've experienced real limp mode before on a previous tune and with that limp mode, I couldn't go above 2.5k. |
#7 |
Make sure you call Subaru with this information. You already have a case file as you called them before. DO IT NOW.
Dealer should have entered your VIN each time you went to the dealership. |
#8 |
Cam position sensor is an easy job to do yourself and cost between $50-$150 for the sensor depending on whether you buy OEM or not. Lots of threads on here about it.
Sent from my SM-G975U using Tapatalk |
#9 |
CEL and traction control lights on after valve spring recall work
Can can some one post a diagram or pic that shows which bank or valve is which , A, b ect
I had this similar cell recently , had my boy swap the valve over to chase it and change if necessary , my cell has went away but every now and then I get a non symptomatic traction light appear Sent from my iPhone using Tapatalk |
#10 |
![]() Here is a pic of what dash does with no cell Atm . After I kill the car and start her up again it goes away . Sent from my iPhone using Tapatalk |
#11 |
| Results of the Valve Spring Recall Work | Magoo | Issues | Warranty | Recalls / TSB | 241 | 01-13-2022 02:38 PM |
| ABS and Traction Control lights after taking clock spring out. | ProjectMidnight86 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-03-2021 12:24 AM |
| Valve spring recall - where did you get it done? satisfied with the work? | fiveoneoh | Northern California | 103 | 09-25-2020 02:10 PM |
| J02 valve spring recall, Toyota will not work on car | drz400dude | Issues | Warranty | Recalls / TSB | 30 | 08-18-2020 02:15 PM |
| valve spring recall/ additional work performed when engine is out | swfrs | Issues | Warranty | Recalls / TSB | 172 | 07-31-2019 12:10 AM |
