#10893 | |
Drives: 2017 toyota 86
You using a new MAP sensor now? are you still using the intercooler? You tracking your IATs? |
#10894 | |
Drives: Hot lava FRS Monogram Charizard
Sent from my GM1915 using Tapatalk |
#10895 | |
You can always hook it up just for comparison purposes. The tune once made safe without intercooler should be safe with the intercooler since boost will drop. I would try to keep the external conditions as similar as possible. like testing it same day back to back test the intercooler 2nd see how much it drops boost and drops temps to see if its worth it. I still think a water to air setup would be ideal for this application for a total net gain in just about any scenario. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | BlOody_BoOger (08-07-2020) |
#10896 | |
![]() Sent from my GM1915 using Tapatalk |
| The Following User Says Thank You to BlOody_BoOger For This Useful Post: | CY86 (08-17-2020) |
#10897 |
@BlOody_BoOger
Oh yeah 120-140 is pretty normal for IATs drawing air from inside engine bay, and engine temps heat soaking MAF being so close. I thought you meant IAT was 120 when WOT under boost. If it’s steadily consistently dropping under boost when it shifts to pulling from the bumper filter that’s a good sign; and good indicator you don’t need an intercooler. I’d be more concerned if it went up or didn’t change. I think your setup is probably fine. You can ask your tuner, but i don’t think the tune makes any major adjustments based on IAT temps it’s more just for seeing what they are as cooler air is denser air for more potential power. So it doesn’t really matter too much what they are cruising around just at WOT when max performance matters. You can gold heat wrap all the intake pipes in the engine bay leading up to throttle body. Proven to help at least a little. A more extreme measure would be water meth injection. I’ve been running that 1.5yrs no problems. Even a tiny 75-100cc nozzle of 100% water just for cooling purposes would be have no risk since your not increasing octane. Just add lots of cooling. Or run 150-200cc nozzle 50/50 mix to get cooling and rough equivalent to E45 for octane boost/power gain. |
#10898 | |
#10899 |
Looking forward to some pulls and videos
2013 Series 10 FRS #553
#10900 |
So after speaking to my tuner he said that 120 temps are still safe. He said that where he lives in Australia 120 temps is pretty normal and hes not boosted so if my temps are 120 when driving normally and don't really change underboost I should be fine. The car might pull some timing but he thinks the intercooler is really not needed. I wonder what kind of charge temps other conventional FI systems are producing
#10901 |
I can give you some numbers with my setup if you want. Pretty warm in SOCAL ATM. Boosted with an liquid IC and flex fuel.
#10902 |
#10903 |
Sprintex 210+69nm pulley.
#10904 |
#10905 | |
#10906 |
My mechanical boost gauge shows a solid 12.5psi peak with the 69mm pulley. And my WMI shows the same. Although they are T’d off the same point on the map plate so should show the same.
But problem with IAT reading with a PD charger (like sprintex) is unless you relocate the IAT to post blower the MAF is pre blower, so we don’t know our real IAT especially when boosted, but It should be a similar comparison reading though comparing off boost/cruising. Which mine is always +/- 5F from ambient drawing from behind bumper. You really need to hit up people with centrifugal chargers and ask them their IAT. But yeah 120f isn’t that bad for cruising since you’re pulling from engine bay and it’s probably heat soaking the MAF housing plate, and i have a feeling your air once pulling from behind bumper even after blower/ when boosted is cooler than the air pulling from engine bay, but the MAF housing and MAF are probably heatsoaked and your boosted pull isn’t long enough to cool it down to get a more accurate lower reading. If you really want to add an intercooler the small water to air with only a .1-.2psi drop would be plenty, the bigger air to air probably do more harm than good with all the pressure drop. |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
