Old 08-04-2020, 03:00 PM   #15
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Did you try unplugging it and plugging it back in.
Old 08-04-2020, 05:24 PM   #16
Originally Posted by WNDSRFR View Post
You have folding mirrors?
Anything can be done if you want it bad enough. Not cheap I would guess
Actually what I would like is a feature my Suburban has, auto-backup adjustments on the side mirrors.
When I put the Suburban in reverse the side mirrors adjust down so you have a better view of the ground around you. This is great for us because of where we park the Suburban (top of our driveway) and having to back to the street, down a decent incline. It angles them perfectly so I can keep the left side of the driveway just in the driver's side mirror.
This should be a standard safety feature but like rear view cameras.
Technically, that should be doable since we have electrically adjustable mirrors and it doesn't involve folding.
Old 08-05-2020, 10:11 AM   #17
V9Rs
Drives: BRZ & M2
Another update:
Started car this evening and played around with the mirror switch.
managed to get driver side fully working again!
Passenger side is still stuck with horizontal adjustment
V9Rs is offline   Reply With Quote
Old 08-05-2020, 01:01 PM   #18
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Originally Posted by V9Rs View Post
Another update:
Contact cleaner in the switch.
PetrolioBenzina is offline   Reply With Quote
Old 08-05-2020, 03:41 PM   #19
V9Rs
Drives: BRZ & M2
Can I spray directly onto the switch?
Old 08-05-2020, 08:09 PM   #20
Yes.
Fender mounted wing mirrors Khorne Cosmetic Modification (Interior/Exterior/Lighting) 15 12-18-2020 10:34 PM
Removing the side wing mirrors Step by Step Video tweedbean DIY (Do-It-Yourself) Guides 0 05-13-2020 04:09 AM
Wing Mirrors Folding Sync Issue FRS2017 DIY (Do-It-Yourself) Guides 26 08-23-2018 02:36 AM
Carbon Effect Wing Mirrors faz1 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-25-2012 10:12 PM
Do the wing mirrors fold in?? stevo_12v AUSTRALIA 26 06-27-2012 11:09 PM
