Old 08-02-2020, 08:59 AM   #15
svnintl
Drives: scion frs
So, make sure you have your cranks dowel aligned with your crank plate. My awesome tuner (guess that's why you pay the professionals) suggested that after reading everything else was correct on the ecutek loggin, did I check the crank dowel. Evidently I installed it 180 degree opposite of its hole. Had to order new crank plate.
I'm still reinstalling everything but will give final update if that's the culprite
https://www.ft86club.com/forums/atta...1&d=1596372915
svnintl is offline   Reply With Quote
Old 08-02-2020, 11:47 AM   #16
Gloonge
Drives: 2013 frs raven
Ayyy I got it right with the trigger wheel. Been there done that bud, good luck on the reassembly!
Gloonge is offline   Reply With Quote
Old 08-02-2020, 07:17 PM   #17
svnintl
Drives: scion frs
Yup you got it. And it was exactly the reluctor wheel. Car fired up today. So recap: if you don't have any trouble codes, all fuses checked, and battery is charged; check your reluctor wheel, crank sensor, and fuel pressure.
Old 08-02-2020, 08:27 PM   #18
Gloonge
I wish mine was so simple. Just installed the edelbrock supercharger today and no start. I think the tune I got from Open Flash has the map sensor set out of range, I still show -1.6 psi with the car off.
Just waiting on a response from them in the next day or so. Glad you're back on the road!
Car cranks but wont start yablonskiy11 Issues | Warranty | Recalls / TSB 15 01-02-2019 12:18 PM
Won't start after clutch change RenegadeReaper Issues | Warranty | Recalls / TSB 21 09-19-2018 09:21 PM
Edelbrock Supercharger Install - Will not start, Cranks forever. I'm out of ideas. WinterWolf Issues | Warranty | Recalls / TSB 12 05-26-2018 07:12 AM
Edelbrock Supercharger Install - Will not start, Cranks forever. I'm out of ideas. WinterWolf Forced Induction 2 05-16-2018 04:38 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
