Old 07-28-2020, 11:44 PM   #1
frostyfrs
Drives: Supercharged 2013 Scion FR-S
2013 rev matching?
So I have had my frs for about a week now, and when downshifting, If I am holding the brake, press in the clutch, and downshift, the car rev matches by itself. It only does it when around 30-40 and only when the brake is engaged. Is this something that all of them do or did the person previous to me make it do this?
frostyfrs is offline   Reply With Quote
The Following User Says Thank You to frostyfrs For This Useful Post:
humfrz (07-28-2020)
Old 07-29-2020, 12:03 AM   #2
Originally Posted by frostyfrs View Post
So I have had my frs for about a week now, and when downshifting, If I am holding the break, press in the clutch, and downshift, the car rev matches by itself. It only does it when around 30-40 and only when the break is engaged. Is this something that all of them do or did the person previous to me make it do this?
First off, the car part is called a "brake" not a "break" -
Second off, it's not customary to push on the brake when downshifting.
My 2013 MT FR-S does not rev match (unless I make it do that).
Old 07-29-2020, 12:23 AM   #3
GCFSA
Drives: Toyota 86
afaik the 86 doesn't auto revmatch. What I've notice happen though is sometimes when I brake and clutch in at lower rpms it'll automatically give it a bit of gas/rev up a little.
I think it's just to prevent stalling because in lower gears (not sure about higher ones) I've noticed during heavy traffic it'll actually still keep moving even if I'm not giving it any gas at very low speeds (10-15kmph?)
GCFSA is offline   Reply With Quote
Old 07-29-2020, 12:51 AM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
It might have a tune on the ECU?
If it has an Ecutek tune on it, it might have auto-blip enabled for downshifting. It has occurs under very specific conditions: 1. must be braking, 2. must be above 3k rpm, 3. only occurs when clutch pedal is depressed
EndlessAzure is offline   Reply With Quote
The Following 7 Users Say Thank You to EndlessAzure For This Useful Post:
frostyfrs (07-29-2020), FRSBRZGT86FAN (08-04-2020), gravitylover (07-29-2020), ls1ac (07-29-2020), soundman98 (07-29-2020), Spuds (08-01-2020), strat61caster (07-29-2020)
Old 07-29-2020, 02:49 AM   #5
Brz-123
It has an ecu tune most likely by ECUTek. The easiest way to know if it has or not is pull your cruise control stalk towards you and the rev counter will move to 1,2,3 or4K RPMs indicating the tune options.
The above post is correct on when its activated but during tune, the tuner can set it to come above a certain RPM or more commonly above a certain speed , say 30 Kmph.
Sent from my SM-G970F using Tapatalk
Brz-123 is offline   Reply With Quote
The Following 3 Users Say Thank You to Brz-123 For This Useful Post:
frostyfrs (07-29-2020), FRSBRZGT86FAN (08-04-2020), Spuds (08-01-2020)
Old 07-29-2020, 06:38 AM   #6
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
I read somewhere that all these tunes do is open the throttle when the conditions are met, but they don't "aim" for a certain RPM based on target gear and speed like some modern cars do. It's up to the driver to "catch" the RPM at the right level.
Is that correct?
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
Old 07-29-2020, 07:12 AM   #7
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Pretty sure that's not a stock feature. I have a 2013 as well,but it's NA. I heel-toe downshift and throttle blip all the time,and I can tell you,there is no auto rev matching.
As others have said,it has to be your tune.
Th3rdSun is offline   Reply With Quote
The Following User Says Thank You to Th3rdSun For This Useful Post:
Old 07-29-2020, 07:52 AM   #8
Grady
Grady's Avatar
Is that correct?
Correct, it is called down shift blip, not rev matching. You have to shift quickly in order for it to work good.
The Following User Says Thank You to Grady For This Useful Post:
alex87f (07-29-2020)
Old 07-29-2020, 12:23 PM   #9
dnieves
Drives: FR-S 10 Series
It keeps moving/creeping without hitting the gas pedal and brake (like an ATX) especially when the car is on an incline.
dnieves is offline   Reply With Quote
Old 07-29-2020, 12:29 PM   #10
frostyfrs
After some further inspection, I learned that when I pull the cruise control, the rpms switch from between 1-4. Im assuming the previous owners had an ECUTEK
Old 07-29-2020, 01:11 PM   #11
Grady
Grady's Avatar
Yep you are tuned. Look around in the car for the dongle. It will look like a USB flash drive. You will not have to buy a license if you ever want to change your tune You will just need a computer and the interface. If the owner tuned it it will not be locked and you can tweak it. If it is professionally tuned you will be locked out and have to load back factory and start from scratch or buy another tune.
Old 07-29-2020, 01:27 PM   #12
ls1ac
ls1ac's Avatar
Did you buy it privately? Maybe you can find the previous owner.
Old 07-29-2020, 06:43 PM   #13
EndlessAzure
Wheels for Brains
Is that correct?
I'm not sure, but a tuner can also tweak the parameters to improve performance across the range if I'm not mistaken. The autoblip on my car is pretty reliable at any RPM and gear.
Old 07-30-2020, 05:33 AM   #14
nicholaswhj
nicholaswhj's Avatar
Drives: Toyota 86
all auto will move when engaged in D bro.
nicholaswhj is offline   Reply With Quote
Matching the new WRB...possible! Dan37BRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 02-02-2017 02:27 PM
What Is Rev Matching JPxM0Dz Other Vehicles & General Automotive Discussions 7 02-16-2016 02:32 PM
Matching HID's and DRL's red_ZN6_4_you Cosmetic Modification (Interior/Exterior/Lighting) 16 11-24-2014 02:09 PM
rev matching twoodcc BRZ First-Gen (2012+) — General Topics 86 11-06-2013 01:03 PM
Rev Matching Selvedge Engine, Exhaust, Transmission 17 11-11-2012 05:48 PM
