Old 07-29-2020, 11:52 PM   #29
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by solidsnake11 View Post
lightweight pulleys......= extra stress on engines........not recommended
Turbos.......................= no extra stress on engines.......recommended
Superchargers............= no extra stress on engines.......recommended
you've got some explaining to do!
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (07-29-2020), jflogerzi (07-30-2020)
Old 07-30-2020, 01:53 AM   #30
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by nikitopo View Post
Lol. Funny that people think FI doesn't put any stress to the engine.
My engine puts stress on my FI
Old 07-30-2020, 05:38 AM   #31
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by henry.haden View Post
Been looking at getting a lightweight crank pulley. Which one do you all recommend?
Anyway, here is an opinion from a person who has tried this mod. I tried a lightweight pulley kit and I noticed a small difference, BUT it was a kit meaning that I had to change additionally the alternator pulley and the water pulley. Overall, a lightweight crank pulley won't help much alone. You need a kit with different pulley diameters to under drive the peripherals. Does it worth the effort and the cost? It depends. If it is your daily driver, then I wouldn't bother to change them.
Old 07-30-2020, 08:16 AM   #32
solidsnake11
Drives: brz
You can double hp and that's fine but if you use an aluminum pulley its going to beat your bearings out.
Millions and millions of air cooled VWs had no harmonic balancer.
solidsnake11 is offline   Reply With Quote
Old 07-30-2020, 08:55 AM   #33
86TOYO2k17
That is a completely different mod. Under driving the water/alt pulleys using Toda kit or Fensport pulleys is not at all the same as a lightweight pulley and shouldn't even be grouped in the same category.
Old 07-30-2020, 09:21 AM   #34
mrg666
pessimistic skeptic
mrg666's Avatar
That is probably cost savings for VW, not performance enhancement.
The Following User Says Thank You to mrg666 For This Useful Post:
soundman98 (07-30-2020)
Old 07-30-2020, 09:26 AM   #35
mrg666
pessimistic skeptic
mrg666's Avatar
When people cannot prove any power improvement, they claim throttle response since it is not measurable. Either someone posts a legitimate dyno or 0-60 test or we call the bs. Light-weight crank pulley is bs. That is the fact.
ddevl_86 (03-30-2021)
Old 07-30-2020, 10:04 AM   #36
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I think light weight pulleys only make sense if you already have light weight flywheel, carbon drive shaft, lighter wheels, and 2-piece brake rotors. I'm certain you would be able to feel the difference when you have removed that much rotational mass from the drivetrain.
Mike_ZN6 is offline   Reply With Quote
Old 07-30-2020, 10:09 AM   #37
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I had all that except an aluminum drive shaft and I couldn't tell.
Old 07-30-2020, 10:12 AM   #38
Ernest72
It looks nicer at least.
Old 07-30-2020, 10:16 AM   #39
solidsnake11
Drives: brz
Hp is mass, distance and time.
If hp is the same and you reduce mass you get less time or more distance.
Simple physics.
Does it take more power to spin a 10lb disc than it does a 1lb disc to 7400rpms from 750?
And not only that but you also have to accelerate the extra 9 lbs with the car.
So you get less centrifugal mass plus less overall mass.
The lighweight pulley works two different ways on acceleration.
Old 07-30-2020, 11:02 AM   #40
mrg666
pessimistic skeptic
mrg666's Avatar
Simple physics.
Engine crank is mechanically connected to many parts with rotating mass; flywheel, driveshaft, differential, wheels, tires, rotors, and who know what I forgot to move a car that weighs 2800 lbs. Rotating a pulley of few pounds lighter weight that actually rotates other pumps, alternators, compressors will not make any measurable difference. That is why there is no data.
Subsonic (07-30-2020)
Old 07-30-2020, 11:49 AM   #41
solidsnake11
Drives: brz
Every little bit adds up and the pulleys,flywheel, battery and driveshaft is a huge weight savings and relatively cheap. Around 50lbs
Old 07-30-2020, 12:34 PM   #42
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes I agree.
[GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt reeves Engine, Exhaust, Bolt-Ons 0 08-22-2018 07:01 PM
FS: OEM CRANK PULLEY SET gt86ser Engine, Exhaust, Bolt-Ons 0 07-10-2018 01:45 PM
What is best crank pulley? Mixlplix Engine, Exhaust, Transmission 49 10-28-2017 05:44 PM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
