First 86 Driver Baby!
Drives: FR-S, Flex
Trying to decide on Coilovers
Like the title says, I’m trying to decide on coilovers for my car. I’ve narrowed it down to Revel and Meister R Zeta coilovers. I don’t track my car, but do some spirited driving (I DD my car). I’ve had Eibach Pro Springs in my car (OEM struts) for over 70k miles and am looking for a change. I’m not looking for a super slammed stance. I’d like to keep it about the same height as the Eibachs. I appreciate any firsthand feedback and advice on these two options.
And yes I’ve searched. |
| The Following User Says Thank You to kmbkk For This Useful Post: | mswbrz (08-01-2020) |
#2 |
Wes
Don't get the Zeta, damping isn't great and they're too softly sprung imo. Set it towards soft and there is too much compression over dips and weird lateral movement in the constant radius corners like on-ramps, set it on hard and it handles sharper but the ride becomes brutal, only suitable for pool table smooth roads
Instagram: @gt86ws
#3 | |
Not saying that's the only option, but it's an easy and good one at decent price. - Andrew |
#4 |
Be Kind
Drives: 2020 86
Find some local ones in 86 groups for sale/cheap.
I grabbed a set of Tein Flex Zs with only 15k miles on them for four hundred bucks.
| The Following User Says Thank You to Wally86 For This Useful Post: | kmbkk (07-29-2020) |
#5 |
Drives: FR-S, Flex
#6 | |
Drives: FR-S, Flex
#8 |
Purist
Drives: 2013 FRS - Hot Lava
Fortune 500
Apexi EXV RSR Sports ST Suspension
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#9 |
The damper in the Bilstein B6 is much better than anything you'll find under $1k. No height or damping adjustability, but it's just a better overall part.
If you're happy with your current ride height, it makes a lot of sense especially for a DD. I would consider coilovers if you have a little more in your budget and/or you track or auto-x your car. There are coilovers that are plenty good for a daily driver, but IMO not under $1k. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Ohio Enthusiast (07-30-2020) |
#10 |
Drives: 2016 Toyota 86
You didn't say how much you want to spend?
If you want to go the cheapest route I think BC Racing BR coilovers are the best for under $1,000. If you can, I would suggest spending about $1,500 and getting RCE SS-1. Last edited by Mike_ZN6; 07-30-2020 at 01:56 PM. |
#11 | |
Drives: Crapcan
I don't see the point in running coilovers unless you are doing AutoX, track days, or you are just looking to slam your car. Don't cheap out to just end up with a worse ride and no performance gain.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Wally86 (07-30-2020) |
#12 |
OP - I am at 52k and plan on doing suspension at 80k (about 2 years from now). My plan after much research was to lower car slightly with RCE yellows and B6 struts for DD and spirited driving. Most advice from other threads has been this is a better option than cheaper coilovers. It appears you need to spend more than 1k to get better dampening in the available coilovers. Since I don’t track, I don’t see the need to spend more for coilovers. But I will reassess in 2 years, maybe opinions will change.
| The Following 2 Users Say Thank You to Ernest72 For This Useful Post: | kmbkk (07-30-2020), Racecomp Engineering (07-30-2020) |
#13 |
Drives: 2016 HyperBlue
The B6 are ~$800 and RCE Yellow are ~$340, so total cost is ~$1140. (and you should probably add new strut tops all around)
For me that is really close (~30% more) to move up to $1500 for the RCE SS-1 which also gives you new tops in the front. Andrew can you give a more detailed comparison between the two and when you would choose one over the other? |
#14 | |
Maximum compliance while getting you the cornering response you want. |
| please help me decide | brzultra | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 08-04-2019 05:49 PM |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 12:09 PM |
| New here, looking to decide on coilovers. | dito | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-27-2015 08:38 AM |
| Looking to buy TOM'S but can't decide !!! | Pish | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 06-17-2014 01:26 PM |
| Help me decide | Decoy68 | Other Vehicles & General Automotive Discussions | 0 | 06-18-2012 08:29 PM |
