Old 07-28-2020, 02:12 PM   #1
norcalpb
norcalpb's Avatar
Brake pad goop
Hi all,
Did a track day with my new DTC-30 brake pads yesterday. After my first session I noticed a liquid goop on the pad backing plate. I don’t use any grease since these are race pads, but I’m wondering if this goop is residual from my oem pads which I took out this past Saturday.
I know I should’ve gone with the DTC-60s, but I’m wondering what this is and if it’s safe to run these still.
This picture was taken today so the goop has solidified.
TIA
Passenger side:
Old 07-28-2020, 02:39 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Might have been the protective coat/original cosmetic finish on the pads themselves?
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
norcalpb (07-28-2020), spike021 (07-29-2020)
Old 07-28-2020, 02:43 PM   #3
norcalpb
norcalpb's Avatar
This is what I’m hoping. Hawk makes great products so I can’t imagine them structurally failing after 1 run.
I used to track with Yellowstuffs and Carbotech AX6 which absolutely sucked on the track, but they never fell apart on me.
Old 07-28-2020, 03:32 PM   #4
Grady
Grady's Avatar
Looks like the paint bubbling off. I would not worry about it.
The Following 5 Users Say Thank You to Grady For This Useful Post:
new2subaru (07-28-2020), norcalpb (07-28-2020), RToyo86 (07-29-2020), spike021 (07-29-2020), strat61caster (07-29-2020)
Old 07-28-2020, 08:22 PM   #5
new2subaru
Weight Weenie
Drives: 15 FR-S
^This
The Following User Says Thank You to new2subaru For This Useful Post:
Old 07-28-2020, 09:05 PM   #6
new2subaru
Weight Weenie
Drives: 15 FR-S
Just to give you an idea they will look like this after it's all burned off. These are DTC 30
Old 07-28-2020, 11:37 PM   #7
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Maybe this is what @HueyLooie actually meant when he said "your dadda's hot goopey goop"?
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
spike021 (07-29-2020), tobin (07-29-2020)
Old 07-29-2020, 01:42 AM   #8
spike021
spike021's Avatar
I'm guessing you just got enough heat in them for that. You could always double-check the spec for the acceptable temperature range, but I dunno how you'd test how hot they got after the fact.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
norcalpb (07-29-2020)
Old 07-29-2020, 12:19 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
that's entirely paint.
my E39 540i valve cover looks like that, but it's taken years for the paint to bubble.
FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings fc3s_johnny Brakes, Suspension, Chassis 11 10-05-2020 10:26 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
