-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Brake pad goop (https://www.ft86club.com/forums/showthread.php?t=141661)
norcalpb 07-28-2020 02:12 PM
Brake pad goop
Hi all,
Did a track day with my new DTC-30 brake pads yesterday. After my first session I noticed a liquid goop on the pad backing plate. I don’t use any grease since these are race pads, but I’m wondering if this goop is residual from my oem pads which I took out this past Saturday.
I know I should’ve gone with the DTC-60s, but I’m wondering what this is and if it’s safe to run these still.
This picture was taken today so the goop has solidified.
TIA
https://i.imgur.com/OhdBeIn.jpg
Passenger side:
https://i.imgur.com/3jG5TYh.jpg
EndlessAzure 07-28-2020 02:39 PM
Might have been the protective coat/original cosmetic finish on the pads themselves?
norcalpb 07-28-2020 02:43 PM
This is what I’m hoping. Hawk makes great products so I can’t imagine them structurally failing after 1 run.
I used to track with Yellowstuffs and Carbotech AX6 which absolutely sucked on the track, but they never fell apart on me.
Grady 07-28-2020 03:32 PM
Looks like the paint bubbling off. I would not worry about it.
new2subaru 07-28-2020 08:22 PM
^This
new2subaru 07-28-2020 09:05 PM
Just to give you an idea they will look like this after it's all burned off. These are DTC 30
Clipdat 07-28-2020 11:37 PM
Maybe this is what @HueyLooie actually meant when he said "your dadda's hot goopey goop"?
spike021 07-29-2020 01:42 AM
I'm guessing you just got enough heat in them for that. You could always double-check the spec for the acceptable temperature range, but I dunno how you'd test how hot they got after the fact.
mav1178 07-29-2020 12:19 PM
that's entirely paint.
my E39 540i valve cover looks like that, but it's taken years for the paint to bubble.
