Old 07-25-2020, 03:48 PM   #1
emerahl86
Drives: GT86
Loud misfires, loud bangs, stock car, no CEL
Hey, I need help.
My 86 has a nasty misfire on nearly every startup and also under load (partial throttle to full throttle), mostly between 2500 and 3300 RPM.
Only when I accelerate really slowly and carefully the car doesnt do it.
It sounds like this :
Not my video but same noise and under load its even louder, scarier and very frequent.
Has anyone experienced something similar or knows someting about this issue?
Thx
emerahl86 is offline   Reply With Quote
The Following User Says Thank You to emerahl86 For This Useful Post:
humfrz (07-25-2020)
Old 07-25-2020, 04:02 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Could be a coilpack. Check the coilpack closest to the passenger's side headlight. And by check, I mean replace.
Old 07-25-2020, 04:05 PM   #3
Originally Posted by emerahl86 View Post
Hey, I need help.
Thx
Hello emerahl86 and welcome to our forum -
Have you hooked up an OBD reader up to see if it shows and codes?
Does your car have any power mods?
What was the last thing that you did to the engine?
Come back.
Old 07-25-2020, 07:04 PM   #4
ls1ac
ls1ac's Avatar
If new take it to the dealer.
Old 07-26-2020, 10:01 AM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Even if there is no CEL, the car is still counting the misfires and storing them in a counter somewhere in memory, the CEL will light up when that counter reaches the correct value for a trouble code to set, but you can still read the counter before there is a trouble code.
It's in MODE $6, and you're not going to get to it with a cheapo code reader. So I suggest you bring it to a trusted mechanic.
You CAN throw parts at it like suggested above, but I'll always advocate investigation over playing darts with parts.
The Following 4 Users Say Thank You to RZNT4R For This Useful Post:
DarkPira7e (07-26-2020), humfrz (07-26-2020), jcw99 (07-26-2020), Tcoat (07-27-2020)
Old 07-26-2020, 05:23 PM   #6
emerahl86
Drives: GT86
Thanks for the replies so far.
I will replace the coilpack as suggested.
I also already opened the engine and found a different Issue:
The long screws which hold the two engine blocks together, (on the left side, besides the cylinders, way down there) are rusted and there is oil sludge around them. Looks like they dont seal properly so oil from the crankcase seeps in. Anyone experienced this issue ? I will take a picture/s next time I'm at the Garage.
To answer some questions: Car is from 2013; just bought the car 2 months ago; only mods are K&N Filter and a catback exhaust, no engine tune afaik, but I'm the 6th owner so - no idea; didn't try a proper OBD reader yet, but will do that.
I will report back if I fix it or break it further.
Anyone have some suggestions on what to look for, now that the engine is out?
Or useful Mods ? Small stuff, like oil cooler maybe?
Thank you
humfrz (07-26-2020)
Old 07-26-2020, 06:10 PM   #7
moliver
Drives: FR-s
sweet, some people pay money for bangs and fire.
moliver is offline   Reply With Quote
Old 07-26-2020, 06:36 PM   #8
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Originally Posted by RZNT4R View Post
. . . playing darts with parts.
I gotta remember that one. Thanks!
LimitedSlip is offline   Reply With Quote
Old 07-26-2020, 07:06 PM   #9
Thank you
Change the spark plugs.
LimitedSlip (07-26-2020)
Old 07-27-2020, 02:23 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Possible DI seal failure.
Old 07-27-2020, 10:33 AM   #11
Sweet lord there could be almost anything that was done and then removed.
Probably a reason it has changed hands so often.
Old 07-27-2020, 11:56 AM   #12
emerahl86
Drives: GT86
Did that already, forgot to mention that.
humfrz (07-27-2020)
Old 07-27-2020, 02:39 PM   #13
gravitylover
Thank you
I'd break it further but that's just the way those things go.
So you did the plugs already, now change the serpentine belt and maybe the idler pulley/tensioner. I'd also change the throwout bearing and clutch fork. Put in a Fumoto valve before you refill the oil.
perrin catback resonated - loud enough or too loud? theflathead Engine, Exhaust, Transmission 33 01-22-2018 05:46 PM
Too loud! booher Engine, Exhaust, Transmission 7 12-06-2017 07:07 PM
Loud misfires upon cold start connorlug Issues | Warranty | Recalls / TSB 42 03-31-2016 04:43 PM
Invidia catless font pipe with stock exhaust. Will it be too loud? chicagokid Engine, Exhaust, Transmission 5 08-04-2014 06:50 PM
How loud can the car get with the stock muffler? BlueDubbinTDI Engine, Exhaust, Transmission 8 09-15-2013 09:16 PM
