Old 07-24-2020, 10:10 PM   #1
solidsnake11
Drives: brz
Highest pulse width
What is the highest port injection pulse width that has been logged at 7000rpm and above
I hit around 11.53 and it seems to not want to go higher from 7000 to 8400. Below 7000 it will hit mid 13s
I think I'm going to have to go larger on one set of my injectors.
Maf limit at 800 and load limit at 8
K24 80mm turbo 1150cc port 440 direct @23lbs
Ecutek RR sd in boost.
solidsnake11 is offline   Reply With Quote
Old 07-25-2020, 04:43 AM   #2
tomm.brz
Drives: brz 2017 hksv2
until 14.5-15ms is all ok
solidsnake11 (07-25-2020)
Old 07-25-2020, 07:57 AM   #3
solidsnake11
Drives: brz
I don't really understand your question.
I think highest I have seen is 13ms but that was below 7000rpm.
Old 07-25-2020, 08:20 AM   #4
tomm.brz
wasnt a question
simply, with stock PI injectors, around 15ms they start to max out and lean afr out
i've seen many times , with FI and stock injectors and PI% too high, a pulse width of over 18ms, and afr was leaning out
Old 07-25-2020, 09:07 AM   #5
solidsnake11
Drives: brz
wasnt a question
I see it now.
Thanks, I thought i might be hitting a limit of some kind.
I have enough fuel to bog it from 5500rpm then it hits hard as it leans out and spools.
Old 07-26-2020, 04:06 PM   #6
solidsnake11
Drives: brz
From all I can figure is that I have hit a load limit even though i have both tables set at 8. Injector pulse width climbs till I hit 4 then it never increases even though maf gs are (limited) at 1000 and sd maf is showing 1600g
I know It isnt using 1600 gs but the injectors should be wide open and they are not.
Has anybody went over 4g load successfully?
Old 07-26-2020, 04:22 PM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by solidsnake11 View Post
From all I can figure is that I have hit a load limit even though i have both tables set at 8. Injector pulse width climbs till I hit 4 then it never increases even though maf gs are limited at 1000 and sd maf is showing 1600g
All 3 load limit tables changed?
.: Stealth 86 :.
Kodename 47 DJ:
solidsnake11 (07-26-2020)
Old 07-26-2020, 04:36 PM   #8
solidsnake11
Drives: brz
I hope there is another load table but I haven't found it.
Old 07-26-2020, 04:53 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Attachment 190676
2 of the tables are showing max 4?
.: Stealth 86 :.
Kodename 47 DJ:
solidsnake11 (07-29-2020)
Old 07-26-2020, 05:00 PM   #10
solidsnake11
Drives: brz
Yes the top right is supposed to replace them from my understanding.
Ecutek says "Replaces OEM load limit maps to allow limit > 4"
Old 07-28-2020, 09:19 PM   #11
solidsnake11
Drives: brz
Do you think it could be output min/max (total fuel quantity)? it is set at 400 default.
I cannot find any info on output min/max for the custom maps.
I am not using a custom map for fuel but I was wondering if the sd is using it?
fuel quantity stops at 311ul
engine load is 7.78 last flash
Old 07-29-2020, 11:42 AM   #12
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you're not hitting 400 then it won't be that limit. Is there any way you can map in a custom map to control fuel at max boost and see if you can raise the fueling - perhaps using TPS vs RPM and output as fuel quantity minimum for example.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-29-2020, 05:15 PM   #13
solidsnake11
Drives: brz
I was going to do that next it just seemed like a band aid fix.
The 400 is only a value it does not have a measurement unit specified.
Old 07-29-2020, 05:33 PM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
it's what the custom maps are there for though, IMO. Other ECUs use TPS based load maps, so is not a crazy thing to do, maybe make it combine with a MAP/RPM map. Works well to smooth out the fuel delivery on boosted FA20s that get MAP fluctuations. If you really wanted to trouble shoot you could put it on one map mode and then use another to keep testing so you know you have a safe mode for when you need it.
.: Stealth 86 :.
Kodename 47 DJ:
How to lower direct pulse width below .88 solidsnake11 Software Tuning 2 03-29-2020 12:34 AM
Pulse P3 Lithium Ion battery in Evasive's FR-S Evasive Motorsports Tracking / Autocross / HPDE / Drifting 15 07-11-2013 05:03 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
Simple Safety Upgrade (3rd brakelight pulse) jpit Electronics | Audio | NAV | Infotainment 7 08-08-2012 05:32 AM
