#15 |
Have you driven anything running high boost (30+ psi) and significant intercooling before? It's not about how quick you shift. Pressure has to be rebuilt. Alternatively, you can just live with destroying turbos regularly and/or blowing off charge pipes (and by default losing the pull).
#16 | |
I'd guess the BRZ would need to be north of 600whp with a corresponding transmission, driveshaft, differential, and axles, along with drag radials, just to be even with the Supra. Even then, those would be very abusive shifts, anti-lag, etc. |
#17 | |
2. The Supra is a better value, even at more than 2x the price, if and only if you plan on modding it. 600+hp with less than $2000 put in is very real with the Supra. |
#18 |
#19 | |
Quite the build there!
Compare MAF vs MAP readings to validate actual flow. |
#20 |
#21 |
Dismember
Drives: 2013 Red Scion FR-S
600HP sounds great. Cruising at 60 then drop the hammer. How long until the boost kicks in, yo? How long until the acceleration hits hard? A second? Downshift, revs build, boost builds, then blam?
#22 | |
I also have rolling launch, so I have full boost without accelerating, and can launch with zero spoolup time. |
#23 |
is it possible to make that much power carb legal on an a90? I just sold my brz for a c6 to make that kind of power...still have the elise though
Drive upgrades. Don't buy them.
#24 |
The only CARB legal power is stock. However, you can make maybe 20hp less on a stock cat compared to catless... and still pull on a C6Z with ease.
#25 |
Drives: Subaru Brz
Would the stock exhaust system (with cat deleted ) of the brz affect much in terms of both performance and reliability standpoint?
#26 |
Drives: 2017 BRZ (Sold), 2023 GR86
Which car is more fun to drive and why?
#27 | |
Dismember
#28 |
Dismember
Stock top gear 50 to 70 is 2.8 seconds. Model y is 2 seconds. Do mods knock a half second off that, or is it a lot of shift time?
| Vaping in cars+other vape related | Packofcrows | Off-Topic Lounge [WARNING: NO POLITICS] | 22 | 07-09-2015 01:33 PM |
| New 97 non turbo supra front rotors x 2 | njccmd2002 | Miscellaneous | 0 | 08-07-2013 09:55 PM |
| Toyota 86 GT & Single Turbo Supra Shoot :) | RZ86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 08-13-2012 02:32 AM |
