Old 07-10-2020, 01:42 PM   #211
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by bmacfrs View Post
Some of these may do it.
https://www.amazon.com/dp/B01M6238ZD..._HXicFbGYZSW40
Sent from my SM-G960U using Tapatalk
i killed 2 birds with 1 stone. i got 5mm spacers that convert to 76.1mm bore for my 6uls
Old 07-20-2020, 11:42 AM   #212
Breadman
Breadman's Avatar
i'm starting to think that i need more camber. im only a few events in and starting to feather what looks pretty bad
this is my first year on REs is this normal or should i go up to like -3.5?
Old 07-20-2020, 11:47 AM   #213
e1_griego
e1_griego's Avatar
Drives: Many
What are you at now? -3.5* is prob the minimum I would run for a competitive STX car. Most of us are at -4.5* at this point, I think.
e1_griego is online now   Reply With Quote
Old 07-20-2020, 11:55 AM   #214
Breadman
Breadman's Avatar
im at -3.1 since i DD it. my daily indy500s are doing fine but it looks like im shredding my REs. Maybe I'll go to -4 if i can? I cant see DDing any more. my back at -2.6 seems to be pretty spot on which is the only real thing saving my tires
Old 07-20-2020, 11:58 AM   #215
e1_griego
e1_griego's Avatar
Drives: Many
I played around on the alignment rack and moved camber in front from 2.6 to 4.5* and the toe barely changed at all, maybe a tenth of a degree. I wanted to see if I could knock out the camber for longer freeway trips (e.g. to Crow's Landing).
Could always align for more and just take out the camber for street driving.
Old 07-20-2020, 12:03 PM   #216
Breadman
Breadman's Avatar
So what you are saying is i can essentially just max the camber plate at the event and dd at -3 and i wont have wonky toe out?
Old 07-20-2020, 12:51 PM   #217
RRslip
Drives: Black BRZ - STX
That much camber change is definitely going to have an effect on your toe. More negative camber yields toe in.
RRslip is offline   Reply With Quote
Old 07-20-2020, 12:53 PM   #218
e1_griego
e1_griego's Avatar
Drives: Many
On my car it didn't effect it enough for me to worry.
You might check on the alignment rack, but I'm not going to worry about big camber sweeps for my car to transit the car to far events.
Old 07-20-2020, 01:54 PM   #219
Breadman
Breadman's Avatar
i might just ask them to max the plates and set slight toe out, then move it down until 0 toe to DD on
Old 07-20-2020, 04:25 PM   #220
racingfool
racingfool's Avatar
Drives: Miata
You sure?
racingfool is offline   Reply With Quote
Old 07-20-2020, 07:08 PM   #221
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
That is a completely normal wear pattern for an RE71R. Flip 'em one event prior to your next major one and go at it again from the other side.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 07-20-2020, 08:00 PM   #222
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Shit those don't even look broken in yet.
ineedyourdiddly
Old 07-20-2020, 08:01 PM   #223
Breadman
Breadman's Avatar
huh? do you mean remount them? the season just started, if that is what you mean ill wait until at least 1/2 way in
Old 07-20-2020, 08:02 PM   #224
Breadman
Breadman's Avatar
ok cool, ive never run them before and noticed the fronts feather way more than the back so ive been moving my front to back and back to front. also the graining mostly wore off on the drive home
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 10:05 PM
