#393 | |
Drives: 2015 BRZ Limited
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
#394 | |
2013 Series 10 FRS #553
#395 | |
Side note, this isn't mentioned anywhere, nor could I find any instructions or forum posts about it, but I tried to find if the coolant capacity was greater for this tank. The OEM tank is 1 gallon, the JR radiator takes like, ~1.5 gallons.
| The Following User Says Thank You to FunnyGopher For This Useful Post: | jflogerzi (07-13-2020) |
#396 | |
#398 |
Drives: Halo 860
Just ran my first event with this installed and I am really impressed with its performance! Previously at Waterford Hills I would hit 255-260 after two hot laps and have to cool down for another lap and a half or so to get it under 240. Yesterday was around 90F ambient and I think the highest temp I actually confirmed was 233. It was sitting at 230 almost every time I looked at it and dropped from there much quicker as soon as I would back off. I was able to get so much more out of my track time running flat out for my entire heats.
I do have one question involving my installation however. I seem to be getting some minor rubbing/melting on the back of my air box against the closer AN fitting. I compared my positioning to a friend at the track who had also just installed the cooler and while the clearance looked to be the same they weren't getting any contact. I'm going to try to reposition the adapter plate and fitting for a little more clearance but I'm not sure how much more I can really get. |
#399 | |
Weight Weenie
Drives: 15 FR-S
If it's just touching the small plastic "reinforcing tabs" you can grind them down a bit. Last edited by new2subaru; 07-18-2020 at 02:43 PM. |
#400 |
Weight Weenie
Drives: 15 FR-S
Pic. looks like it could use more work
#401 |
Drives: Halo 860
My clearance is very tight down there, but that's not actually what I was referring to. The contact I'm seeing is at the top of air box against the AN fittings coming off of the sandwich plate.
#402 |
Weight Weenie
Drives: 15 FR-S
#403 |
Weight Weenie
Drives: 15 FR-S
You can see the gap here
#404 |
Drives: 2014 BRZ Limited, Satin White Pearl
Just move your upper bracket forward
Simply move your 2 upper radiator brackets forward for an extra half inch of clearance. You will end up putting 1 bolt in each bracket. Move the bracket forward and align the rear bracket hole with the front hole in the support.
I did this to create a little extra room with my turbo setup and the Jackson dual radiator. Here is a crappy pic I just took showing it moved forward and utilizing just 1 bolt. For some dumb reason the pic is showing upside down.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
| The Following User Says Thank You to Tonrogs For This Useful Post: | new2subaru (07-18-2020) |
#405 |
Drives: Halo 860
Ah, I have a 2017 car with the new airbox, it's considerably larger than the older ones and doesn't have that little angle on the corner near the oil filter and cap.
Oh interesting! I hadn't considered this at all, I'll have to look at it. |
#406 |
My update! The new radiator let the airbox fit much better. I'll attach a couple pics of both of them from fairly the same angle. The one installed in the car is the bad one. A good point of reference for the pictures is the fan shroud bolt.
I did not take any pictures. I was focused on getting it done before the next morning!
| The Following 2 Users Say Thank You to FunnyGopher For This Useful Post: | ls1ac (07-18-2020), new2subaru (07-18-2020) |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler | Jackson Racing | Engine, Exhaust, Bolt-Ons | 0 | 04-25-2016 05:35 PM |
| Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. | OkieSnuffBox | Engine, Exhaust, Bolt-Ons | 5 | 01-12-2016 11:26 AM |
| Jackson Racing Supercharger and JR Oil Cooler | bobsacamenoh | Engine, Exhaust, Bolt-Ons | 20 | 12-12-2014 02:00 AM |
| Jackson Racing oil cooler for NA vs FI | ayau | Engine, Exhaust, Transmission | 1 | 05-29-2014 11:04 AM |
