Old 07-14-2020, 06:16 PM   #183
Vatabot
Drives: GR86 base model Neptune blue
Originally Posted by Evan55 View Post
Lotus center caps?!
Yes. I found the Sparco sticker of the center caps a little too shiny to my taste and wanted something more discrete.
Searched for black ones on the internet and found out that the Lotus dealer of my town sells exactly the right size (49 mm).
Drove 5 minutes, paid 15 euros for all 4 and was happy with the end results.
After all, Lotus uses Toyota engines, so why not put a Lotus logo on the wheels of my Toy
Vatabot is offline   Reply With Quote
Old 07-15-2020, 08:40 AM   #184
djmasterg
Drives: blue jdm brz
Originally Posted by timurrrr View Post
Thanks for the info!
Do they require 5mm spacers? Or do they fit with just 3mm spacers? Without spacers?
See this thread: https://www.ft86club.com/forums/showthread.php?t=109786
I will check that out - Just need to wait for a better weather and a day off work. I will post it here and keep you updated. The spacers - I have put them on the car when I bought these wheels, before I swapped the brakes.
Thank you for that link. I should have looked prior to asking.
djmasterg is offline   Reply With Quote
Old 07-15-2020, 05:44 PM   #185
Vatabot
Some other pics of my Sparcos Assetto Gara 17x7.5 ET35.
Fit the car quite good. I am really happy with the design.
Old 07-15-2020, 10:56 PM   #186
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Here's my experience with Brembo clearance to the OZ Ultraleggera 17x8 +48.
https://www.ft86club.com/forums/show...2&postcount=99
N_Raged is offline   Reply With Quote
Old 07-17-2020, 09:25 AM   #187
pslater
Drives: 2017 Golf R
ahh, you picked up that set that was for sale in kitchener? i'd been eyeing those for a while. just not the right offset for me, but they look great on your car!
pslater is offline   Reply With Quote
Old 07-17-2020, 09:58 AM   #188
N_Raged
Yes it was from him.
Old 07-22-2020, 06:29 PM   #189
Enti.Moose
Drives: 2020 BRZ Sport-Tech RS
Hey Timurrrr, just wanted to give you a massive thanks for this thread.
I have another set of wheels to add to the list:
Enkei TFR 17x8 +45 (White BRZ - stock suspension) - will clear Brembos
Enkei TFR 17x9 +45(Series Gray? - stock suspension) - will clear Brembos but I believe tires will will rub at full lock on a grade. (5mm spacer recommended.)
Credits to CC and TK from a BRZ/FRS/86 FB group.
Enti.Moose is offline   Reply With Quote
Old 07-27-2020, 09:34 AM   #190
pslater
Drives: 2017 Golf R
I am sure it was assumed, but 17x8 ET35 OZ Ultraleggera fit as well - tons of clearance.
Old 07-27-2020, 02:25 PM   #191
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Enti.Moose View Post
Enkei TS9 17x9 +45(Series Gray? - stock suspension) - will clear Brembos but I believe tires will will rub at full lock on a grade. (5mm spacer recommended.)
Thanks for helping find more info!
Yeah, 17x9 +45 is known to be too close for factory suspension. I personally wouldn't run any 17x9 wheel with offset higher than +40. See also this post.
Old 07-28-2020, 01:17 AM   #192
S0crates
Drives: 2017 BRZ Limited PP
@pslater, Looking good! What tire type/size did you go with? Lowered or Camber adjusted?
S0crates is offline   Reply With Quote
Old 07-28-2020, 08:06 AM   #193
pslater
Drives: 2017 Golf R
Is that posed to me or someone earlier?
Old 07-28-2020, 01:28 PM   #194
S0crates
@pslater, it was for you. Sorry, went back and adjusted my original text.
Old 07-28-2020, 01:51 PM   #195
pslater
Drives: 2017 Golf R
No worries!
The tires are 225/45/17 hankook evo2’s... they came with the wheels, and are almost dead. I likely will be replacing them with some RE71R’s, same size.
The suspension is RCE Tarmac 0 coilovers. About -2* camber in the front via the slotted upper holes in the RCE strut bodies. Rear camber is around -2* as well. I just installed the coilovers and am waiting for some adjustable rear LCAs to arrive.
The car is lowered about 25mm from stock. I did have to replace the front sway bar endlinks with adjustable ones as they were contacting the front LCA.
Old 08-02-2020, 11:48 AM   #196
Zacharary
Drives: 2018 Subaru BRZ
Was trying to find info on WRX STI rims on PP BRZs because I saw this one for sale on cars.com. Don’t have any info, so can’t say if they just fit or need anything.
Zacharary is offline   Reply With Quote
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
