Old 07-15-2020, 02:53 AM   #169
Zer0
Drives: 2015 frs
I was inspired to switch up my front suspension by Joel's BRZ - Low Budget Time Attack Build.
I will be using a ND Miata/ Fiat 124 front suspension setup to build a jig to build a subframe that will bolt into the frs. I will use the arms to build a jig to make adj. upper control arms. I may use the Mazda lower control arms or build new adj lowers as well. The less time I have to work on it the more time I have to rethink things. Double edged sword.
Zer0 is offline   Reply With Quote
The Following 4 Users Say Thank You to Zer0 For This Useful Post:
DIY (07-15-2020), DustinS (01-29-2021), MrSkubi (07-31-2020), Stonehorsw (05-24-2021)
Old 07-30-2020, 06:20 AM   #170
Zer0
Drives: 2015 frs
I have received the front crossmember, and suspension. I measured it out. The mounting holes for the crossmember are slightly narrower than the frs unit. This was expected because the width of the frame rails to fit the flat 4 in the frs. The crossmember is also taller from where it attaches to the chassis to the lower control arm mounting point. If it were a closer fit I was going to prop it up under the car for some pictures. I will need to take more measurements, so I can start building jigs for the control arms, and crossmember when I get time. I dont count on it being to soon. I work to much
The Following 2 Users Say Thank You to Zer0 For This Useful Post:
DIY (07-31-2020), DustinS (01-29-2021)
Old 05-22-2021, 02:53 AM   #171
TripleTapHK
TripleTapHK's Avatar
Drives: 2016 Subaru BRZ Series Hyper-Blue
Are you still working on this build friend? Was really pumped to see all the work you were doing.
TripleTapHK is offline   Reply With Quote
Old 08-06-2022, 03:57 AM   #172
Zer0
Drives: 2015 frs
Yep still on it when and if I get the time.
Andy0323's Back To Basics Build Thread <Long Term Project> andy0323 Member's Car Journals 15 02-02-2018 12:16 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Long term Bt216 Scion FR-S / Toyota 86 GT86 General Forum 3 06-06-2013 11:58 PM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
