#29 |
TRACKBREAD
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | BuckTheStallion (07-11-2020) |
#30 | |
I might have gotten really lucky, but so far with 150 miles on it, there been no chatter. My stock flywheel would sometimes make a marbles in a can rattle sound at idle with the ac on, but I haven't heard it at all with this setup. The only significant noise I hear is a cabin resonance on deceleration from 3500-2500 RPM in 5th gear. That might be caused by my whiteline diff cradle bushings though, as the sound seems to come from the rear and is similar to the sound they make, just amplified with the new flywheel. Other than that, this setup is very quiet. I think what helps is the Exedy flywheel isn't too light and the clutch has inner springs to absorb shocks and vibrations (and is full-faced). It's also easy to drive. I'd highly recommend it (so far).
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Mike_ZN6 (07-10-2020) |
#31 |
Drives: 2019 Toyota 86 - Asphalt
Well I guess it's not technically an OEM+ build then? I mean, my whole point was that I want light customizations to make everything work the best it can without compromising the OEM balance and experience. I'm not chasing a high dyno number or an impressive widebody setup, just a slightly tuned up stock experience, better suited to my region. I wouldn't be considering vents and a cooler if it weren't for living in one of the hottest places on earth. Haha. If vents and an oil cooler qualify me for a build, then I guess it's, at minimum, an extremely diet build. Haha.
But I digress, this thread has been extremely helpful so far, and if you want to keep the ideas coming, I'd appreciate it. It's really helping me focus in on the stuff I need and want. But if anyone is done and just wants to let the thread die, then that's perfectly fine too. Thanks for your ongoing help!
2019 Toyota 86
| The Following User Says Thank You to BuckTheStallion For This Useful Post: | nikitopo (07-11-2020) |
#32 |
Drives: 2017 Toyota 86
Another minor and cheap thing: emblems. You can get good quality ones from eBay for cheap. I got matte black ones for the front, back, and sides:
https://www.ft86club.com/forums/show...77&postcount=3 |
#33 | |
2019 Toyota 86
#34 |
pessimistic skeptic
I would just forgo OEM+ idea and get a supercharger and oil cooler first (since you are in Arizona). That transforms your car. The rest are just incremental modifications. Spend the money for the rest of the modifications based on your taste and supporting the supercharger. You will end up spending that much money anyway even without the supercharger and nowhere near the performance of FI.
With the supercharger, you probably won't care about the carbon fiber drive shaft which is almost 1/3 price of supercharger kit, need the final drive trick, or header and additional tune. Just my experience. |
#35 |
Drives: '15 BRZ RA
Yes that's true. OEM+ is about staying close to the design of the manufacturer and about installing parts that were tested by the factory on the particular platform. A good FI kit is a much easier way to improve performance, but not really an OEM or OEM+ option. So, it is always a matter of decisions and priorities.
| The Following User Says Thank You to nikitopo For This Useful Post: | mrg666 (07-11-2020) |
#36 | |
Drives: '24 GR86
Only way I’d suggest the hood vents is if you were adamant about tracking the car during the summer months; but many of the events here in AZ start at like 4am during the summer and go to like noon, just to beat the heat.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | mrg666 (07-11-2020) |
#37 | |
Drives: RX-7 / BRZ
Technically TRD did do an OEM+ Supercharger for this platform. :P
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#38 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Well according to this thread my car build is not OEM+
Damn.
#39 | |
As for the Supercharger option a few have mentioned, I can't find any reference to a TRD one, not available at least, but I think I read about them testing one a long time ago. I'd probably go with an HKS SC if I was going forced induction, and I might eventually TBH, but not for a while still. 250whp seems like it would be absolutely a dream in this car, but I don't know how much extra engine stress it would cause, especially with this heat.
2019 Toyota 86
#40 |
Drives: Scion FR-S 10 Series
You will need an oil cooler. That is the next thing I am doing to the car now that I live in Vegas. Even driving on the street after a couple of light pulls you can get temps fairly high. I have seen nearly 230 just cruising on days with high ambient temps.
#41 | |
Drives: '24 GR86
But you’ll be fine without. Modern cars are pretty well designed. There are plenty of people who are driving these cars fairly hard in conditions just as rough. You can do it if you want, and the temps will definitely be managed; but I think the time and money would be better spent elsewhere. There is no TRD option available to the public. If looking at an SC kit, Jackson Racing is pretty popular and has plenty of track time R&D behind it. They also offer a CARB version that comes with an ECU tune and is Cali CARB compliant. I would probably go that route, personally. But that’ll also contribute to increased heat.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | nikitopo (07-13-2020) |
#42 | |
As for heat management, an oil cooler looks like it'll probably be in the cards for me, but I'll get an oil temp monitoring system set up before I decide to go that route. Same thing with a hood, I'm hoping to find a partout hood in the same color (asphalt) to cut and install, but I personally don't have an issue with the looks of the factory hood plus vents. They're functional. I like function. Most aftermarket hoods I've seen don't seem to have very functional extraction setups, and focus more on looks. I could be mistaken and there might be some well designed ones out there, but I haven't seen them. (Mind you I haven't been looking very hard either though.)
2019 Toyota 86
| First time FRS build looking for advice/ideas | FT86Hypnotic | Mid-Atlantic | 31 | 12-10-2015 03:18 PM |
| Mod ideas? | _anthonygd | BRZ First-Gen (2012+) — General Topics | 42 | 09-08-2015 06:28 PM |
| New Here Need Ideas | FRStrent | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-10-2014 10:22 PM |
| In Need Of Ideas!! | bh7990 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 05-19-2014 12:14 PM |
| iv got 12's and need ideas | Top-Secret | Electronics | Audio | NAV | Infotainment | 10 | 05-05-2014 10:15 PM |
