Old 08-21-2018, 04:42 PM   #85
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Originally Posted by Hags86 View Post
240 rear wheel Kw - say 400 flywheel horsepower - on a water to air intercooled turbo using e85. Engine had 60,000km before being boosted and had 4 bent rods 7,000km later with only some spirited driving and one track day I used to shakedown the turbo install.
Built engine being done now.
Was that with your Coyoda fitted? Find the reason for the rods being bent?
Bodalenko is offline   Reply With Quote
Old 06-29-2020, 08:13 PM   #86
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I want to revive this to see how people are faring! My car was about 2k miles on 330whp (17psi turbo) before s timing chain guide let go. Completely unrelated to the turbo, my car has a history. Considering rebuilding or buying another used stock engine
Old 07-03-2020, 07:38 PM   #87
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I’m over 80k boosted miles, with over 82k total. I just finished an E85 tune so I’m on it now, but haven’t dynoed it yet to see how much power it’s putting down.
kmbkk is offline   Reply With Quote
The Following 2 Users Say Thank You to kmbkk For This Useful Post:
airrick (10-01-2020), TRAKRAVN (07-12-2020)
Old 07-09-2020, 07:51 AM   #88
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
I'm sitting at around 10,000 miles with a Sprintex 210 SPS + flexfuel kit.
I look after my car really well - and so far no problems!
I like driving!
86 South Africa is offline   Reply With Quote
Old 07-09-2020, 10:42 AM   #89
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
10k miles so far. I don't get on it every day but I do some hard pulls and speed up on the highway sometimes.
Clueless
YamahaR86 is offline   Reply With Quote
Old 07-11-2020, 09:17 AM   #90
mrg666
pessimistic skeptic
mrg666's Avatar
I am around 35K miles (52K total) now with JRSC. I had to replace the valve springs which might be related to FI (or not). JRSC kit and everything else are working fine so far with factory tune without any other major trouble.
Old 07-12-2020, 04:49 AM   #91
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
only around 24xxx over the last 4 years.
malubawla is offline   Reply With Quote
Old 07-12-2020, 08:09 AM   #92
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
Glad to hear some people put quite a lot of mileage on their FI setup!
SUSPECT_BRZ is offline   Reply With Quote
Old 07-12-2020, 01:36 PM   #93
mrg666
pessimistic skeptic
mrg666's Avatar
Maybe more than mechanical reliability, I am also glad I didn't do anything crazy to total the car. These cars are seriously fast with the FI power.
Old 07-12-2020, 03:58 PM   #94
SUSPECT_BRZ
Do you mind sending me a PM regarding your JRSC kit and the supporting mods and tune you used? I'm highly interested in this kit down the road (I just bought a 2020 TS). You obviously did it right with that kind of mileage. Thanks for your time.
Old 07-12-2020, 04:28 PM   #95
mrg666
pessimistic skeptic
mrg666's Avatar
There are only two supporting mods for the C30 kit I have.
- 2017+ improved header (with stock cat) and HKS dual resonator front pipe (catless) to increase exhaust flow and decrease exhaust back pressure. Since you have a 2020 model, you already have the improved header if it is manual transmission.
- Jackson Racing dual radiator and oil cooler (I used STI OEM oil cooler before this)
I use Jackson Racing factory tune.
That is all.
The Following User Says Thank You to mrg666 For This Useful Post:
SUSPECT_BRZ (07-12-2020)
Old 07-12-2020, 05:42 PM   #96
SUSPECT_BRZ
That is all.
Were you satisfied with the base ecutek tune or did you do some back and forth data logging? Also did you use the C38-81 or C30-94? Thanks!
The Following User Says Thank You to SUSPECT_BRZ For This Useful Post:
mrg666 (07-12-2020)
Old 07-12-2020, 08:03 PM   #97
mrg666
pessimistic skeptic
mrg666's Avatar
I chose c30 kit since I wasn't planning to increase the boost. I have been using the base tune JR provided which is CARB certified. No additional modifications were done on the tune. It is a very good tune.
Old 07-13-2020, 11:33 AM   #98
SUSPECT_BRZ
Thank you sir! Much appreciated! Definitely a great build
mrg666 (07-13-2020)
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
Alpine's Boosted BRZ Thread alpine Member's Car Journals 262 02-04-2015 09:31 PM
The Boosted Exhaust Thread The Racers Line Forced Induction 49 06-05-2014 01:13 AM
cj's WRB boosted thread cjsporl1996 Member's Car Journals 3 05-12-2014 11:47 AM
Boosted BRZ mike the snake Member's Car Journals 3 12-28-2013 11:11 AM
