Old 07-10-2020, 08:12 PM   #43
norcalpb
norcalpb's Avatar
@Yoshoobaroo do you have any more tips on how to get the backing plate off? You mentioned there are 2 clips that need to be pried but I think there are 4? And I’m not even sure if the 4 I’m working with are even the correct ones.
I feel like if I apply anymore pressure on those clips I’ll break something.
Old 07-10-2020, 08:31 PM   #44
norcalpb
norcalpb's Avatar
Is this the clip I should be prying down on? It doesn’t seem to want to move in any direction.
Old 07-10-2020, 08:56 PM   #45
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That is indeed the catch that holds the back shell on. You can’t push it down, you have to pry the back shell up.
Here’s what’s underneath:
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
norcalpb (07-10-2020)
Old 07-10-2020, 09:03 PM   #46
HSC
Drives: Whiteout FR-S
When removing the two tabs (they are close to where the wires connect to the harness) make sure to cut the zip tie holding the wire to the harness. Once that’s cut off, and clip released, the backing comes off easily. Good luck!
Completed my install last week. Did a canyon run and very happy with the “track” mode. Not once did it kick in on my drive where it has always intervened before in Sport mode.
HSC is offline   Reply With Quote
The Following User Says Thank You to HSC For This Useful Post:
Yoshoobaroo (07-10-2020)
Old 07-10-2020, 09:07 PM   #47
norcalpb
norcalpb's Avatar
Oh ok, so small screwdriver in between the 2 halves and then pry it over the catch? Thank you so much.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
sroby (11-09-2020), Yoshoobaroo (07-10-2020)
Old 07-10-2020, 09:09 PM   #48
norcalpb
norcalpb's Avatar
Is this required for install though? I’d like to leave all factory zipties intact with this install it at all possible.
Old 07-10-2020, 09:11 PM   #49
HSC
I couldn’t get the backing to release until I cut that zip tie. Easy enough to just re-zip tie afterwards. Trust me, I was stuck on this step for a while too wondering if I was targeting the right clips.
The Following 2 Users Say Thank You to HSC For This Useful Post:
norcalpb (07-10-2020), Yoshoobaroo (07-10-2020)
Old 07-10-2020, 09:43 PM   #50
norcalpb
norcalpb's Avatar
Also, when you say “There is another lock for each individual pin, use a small pick to disengage and pull pins 27 (pink) and 32 (white).”, do you mean there is one lock for every pin, or there is one lock that controls all pins?
Are these lock(s) on the top or bottom (wire side) of the connector?
Old 07-10-2020, 10:15 PM   #51
HSC
Once you slide the pink tabs over and remove that back cover , it enables you to then detach each pin by sliding a needle or something similar into the holes above each of the pins (connector side, not wire side). Then you tug on the applicable wire to pull it out.
Old 07-10-2020, 10:25 PM   #52
Yoshoobaroo
TRACKBREAD
It’s a little catch that’s part of the metal pin. You should be able to see it and get at it with a small pick.
Old 07-10-2020, 10:29 PM   #53
Yoshoobaroo
TRACKBREAD
DIY: Track Mode on 2013-2016 cars
Thanks @HSC
If someone can upload some pics of the pin pulling I can add them to the DIY. I didn’t think to take pictures when I did the repin last year and my memory is fuzzy on the actual pin catch configuration.
Old 07-10-2020, 11:11 PM   #54
norcalpb
norcalpb's Avatar
Thanks for the help guys but I’m still having an extraordinary amount of trouble. I try to stick something into the hole above the pin, but the wire just won’t come out. Is there a clicking sound or something when the “catch” is released? How much force is needed to release the wires from their hold?
I’m starting to wear out the holes above the pins with the tools I’m using.
Thanks again
Old 07-10-2020, 11:16 PM   #55
norcalpb
norcalpb's Avatar
So am I pushing with the needle while pulling with my hand? I’ve inserted a few different tools but unfortunately the wire is stuck in there. I’ve probably tried about 25lbs of pressure on the wire to pull it out but I obviously don’t want to break it.
Old 07-10-2020, 11:17 PM   #56
norcalpb
norcalpb's Avatar
How deep does the tool need to go in before you hit said catch? I can’t see anything in there but what I assume are copper connectors. 2 of them in each hole.
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 09:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-20-2020 11:27 PM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 10:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
