#71401 |
Congrats!
Didn't realize you needed a key to start a sailboat...
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | p1l0t (07-10-2020) |
#71402 |
Oh, OK. Be careful around the Pequonnock Yacht Club, there used to be some nasty girls hanging out there looking for a "ride". -
| The Following User Says Thank You to humfrz For This Useful Post: | p1l0t (07-10-2020) |
#71404 |
Drives: RX-7 / BRZ
Buy a full face paint respirator and this stuff. ![]() It is an acid, so gear up in throw-a-way clothes and don't do it on a nice garage floor. Spray on, let sit until your eyes water and then scrub it off. Afterwards rinse the fuck out of everything with soapy water. Work amazing on cleaning up older boats that lived in the water and not dry docked.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following 2 Users Say Thank You to Kiske For This Useful Post: | p1l0t (07-10-2020), soundman98 (07-11-2020) |
#71405 |
Drives: RX-7 / BRZ
Nah, go. being that is one of the newer engines being swapped into a '13 car I already have to swap over almost every sensor and plug. A few more parts shouldn't be the end of the world. I've had 2 engines that came with each car. I've had one built engine from MAPerformance in 2015. I put a low mileage junk yard engine in the 13 car after the MAP engine burned up. It lasted about 1300 miles. The following engine was bought and never received 'because covid19 45 days weren't enough time to ship it...' way back in February. It took forever for paypal to get the refund process. I then just bought another used low mileage engine with 20k on the clock which I just received. I also have another engine being build by IAG Performance to put in my tS over winter. I consider it my final, final try. It is a full custom build using the HKS Stroker, overbored and closed deck. It will be a 2.3l Harrop Supercharged monster. It's currently held up by JE Pistons whom are backed up with no ETA... I tell myself I cannot break my tS until I get the blue car out the door for good!
| The Following 2 Users Say Thank You to Kiske For This Useful Post: | soundman98 (07-11-2020), Spuds (07-11-2020) |
#71406 |
My home laser printer apparently won't print in black and white if one of the color cartridges is empty! How completely stupid is that? And, of course, all the stores are closed because COVID says you have to roll up the carpets at 8:00pm.
Out of frustration, I restarted the printer. Apparently if you queue up jobs to the printer, then restart it, it will print before it's logic bomb tells it that one of its cartridges are empty. Take that, Michael Dell! Oh, I should add, I have the replacement Magenta cartridge (I always keep a set at home), or at least I thought I did. turns out the wrong cartridge was shipped in the right box. It's for a completely different printer model.
| The Following 3 Users Say Thank You to Dadhawk For This Useful Post: |
#71407 |
Drives: Crapcan
For as eff’d as these friction rings look, they are still in spec
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#71408 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Dadhawk (07-12-2020), soundman98 (07-11-2020) |
#71409 |
#71410 |
Site Moderator
Drives: ichi 86 Project
Top & middle are using 1084 steel vs bottom is 1080 steel.
There’s only 0.004 carbon difference between 1080 & 1084, but belt sander def saw the difference. Went through double of belts than 1080. |
| The Following 4 Users Say Thank You to ichitaka05 For This Useful Post: |
#71411 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Would you say it's wrong to get a VPN so you can watch things you're not supposed to?
| The Following 4 Users Say Thank You to weederr33 For This Useful Post: |
#71412 |
Even if they're ground down to the deepest groove on both sides?
#71413 |
Isn't that the main reason?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (07-11-2020) |
#71414 |
ProCrastinationConsultant
it's par for the course in china.
| The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (07-11-2020) |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
