Old 07-10-2020, 04:17 PM   #71401
I bought a little sailboat.
Congrats!
Didn't realize you needed a key to start a sailboat...
Dadhawk is offline
p1l0t (07-10-2020)
Old 07-10-2020, 04:26 PM   #71402
New Haven
Oh, OK. Be careful around the Pequonnock Yacht Club, there used to be some nasty girls hanging out there looking for a "ride". -
humfrz is offline
p1l0t (07-10-2020)
Old 07-10-2020, 06:35 PM   #71403
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Congrats!
Newer ones have push button start.
Sapphireho is offline
Dadhawk (07-10-2020)
Old 07-10-2020, 07:31 PM   #71404
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Buy a full face paint respirator and this stuff.
It is an acid, so gear up in throw-a-way clothes and don't do it on a nice garage floor. Spray on, let sit until your eyes water and then scrub it off. Afterwards rinse the fuck out of everything with soapy water.
Work amazing on cleaning up older boats that lived in the water and not dry docked.
Kiske is offline
The Following 2 Users Say Thank You to Kiske For This Useful Post:
p1l0t (07-10-2020), soundman98 (07-11-2020)
Old 07-10-2020, 07:45 PM   #71405
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
So, that's a no-go? Where the hell are you getting these from?
Nah, go. being that is one of the newer engines being swapped into a '13 car I already have to swap over almost every sensor and plug. A few more parts shouldn't be the end of the world.
I've had 2 engines that came with each car. I've had one built engine from MAPerformance in 2015. I put a low mileage junk yard engine in the 13 car after the MAP engine burned up. It lasted about 1300 miles. The following engine was bought and never received 'because covid19 45 days weren't enough time to ship it...' way back in February. It took forever for paypal to get the refund process. I then just bought another used low mileage engine with 20k on the clock which I just received.
I also have another engine being build by IAG Performance to put in my tS over winter. I consider it my final, final try. It is a full custom build using the HKS Stroker, overbored and closed deck. It will be a 2.3l Harrop Supercharged monster. It's currently held up by JE Pistons whom are backed up with no ETA...
I tell myself I cannot break my tS until I get the blue car out the door for good!
Kiske is offline
soundman98 (07-11-2020), Spuds (07-11-2020)
Old 07-10-2020, 08:38 PM   #71406
My home laser printer apparently won't print in black and white if one of the color cartridges is empty! How completely stupid is that? And, of course, all the stores are closed because COVID says you have to roll up the carpets at 8:00pm.
Out of frustration, I restarted the printer. Apparently if you queue up jobs to the printer, then restart it, it will print before it's logic bomb tells it that one of its cartridges are empty.
Take that, Michael Dell!
Oh, I should add, I have the replacement Magenta cartridge (I always keep a set at home), or at least I thought I did. turns out the wrong cartridge was shipped in the right box. It's for a completely different printer model.
Dadhawk is offline
humfrz (07-10-2020), soundman98 (07-11-2020), Spuds (07-11-2020)
Old 07-10-2020, 09:09 PM   #71407
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
For as eff’d as these friction rings look, they are still in spec
NoHaveMSG is offline
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Old 07-10-2020, 09:39 PM   #71408
My home laser printer apparently won't print in black and white ..........
I reckon you will have to go to the bank and get some real money -
humfrz is offline
Dadhawk (07-12-2020), soundman98 (07-11-2020)
Old 07-10-2020, 09:42 PM   #71409
By the time you turn them to get all the grooves out, they may not be within spec -
humfrz is offline
NoHaveMSG (07-10-2020), Spuds (07-11-2020)
Old 07-10-2020, 09:51 PM   #71410
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Top & middle are using 1084 steel vs bottom is 1080 steel.
There’s only 0.004 carbon difference between 1080 & 1084, but belt sander def saw the difference. Went through double of belts than 1080.
ichitaka05 is offline
The Following 4 Users Say Thank You to ichitaka05 For This Useful Post:
humfrz (07-11-2020), NoHaveMSG (07-10-2020), soundman98 (07-11-2020), Spuds (07-11-2020)
Old 07-10-2020, 10:29 PM   #71411
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Would you say it's wrong to get a VPN so you can watch things you're not supposed to?
MS, CSCS, TSAC-F, CPT
weederr33 is offline
The Following 4 Users Say Thank You to weederr33 For This Useful Post:
humfrz (07-11-2020), NoHaveMSG (07-11-2020), soundman98 (07-11-2020), Spuds (07-11-2020)
Old 07-11-2020, 12:37 AM   #71412
Even if they're ground down to the deepest groove on both sides?
Ultramaroon is offline
Old 07-11-2020, 12:38 AM   #71413
Isn't that the main reason?
Spuds (07-11-2020)
Old 07-11-2020, 12:54 AM   #71414
soundman98
ProCrastinationConsultant
soundman98's Avatar
it's par for the course in china.
soundman98 is offline
Spuds (07-11-2020)
