#295 | |
Sounds like you need either a roll center adjuster for the front, a wisefab front, or a long rear shock base mount to get you to the height you want. I find it difficult to believe someone at CSG would recommend you something like the Wisefab, especially for the rear only, unless you had a specific requirement, such as wanting to go full spherical, in which case the Wisefab is absolutely more cost effective. Looks like I should assume nothing here. Is your front also full spherical? |
#296 | ||||||
Drives: 2017 Subaru BRZ PP
Honestly though, if you want to help me, you have my FB. You can DM me instead of muddying the waters of this thread, which is for discussing the CSG Flex A coilovers. |
#297 | |||
It appears to me David's team provided you with exactly that: a complete rear end. The issue that I can identify, is not that the Wisefab caused more problems, but rather that the rear doesn't match your front. On a technical level, with the CSG FLA's 1.4" recommended drop (35mm), you *should* have roll center correction but most folks, myself included, choose to forego the roll center correction for budgetary reasons. With the wisefab, you can stay at the 35mm drop, or go lower without compromising RC. The 1.4" recommended drop for the CSG FLA is based around stock geometry and stock stroke range. With the Wisefab, you can now go lower without RC penalty. The email conversation also shows David and/or his team recommending a SPL/Cusco setup, complete for both the front and rear, but that you elected ONLY to go with the rear system. Additionally, you've pressed Delrin into the front arms, rather than going spherical. While Delrin is certainly less compliant than stock rubber, the issue is that now, the only non-spherical component in your suspension is your front lower control arm inner bushings. That delrin is going to be seeing a lot of deflection which causes permanent deformation. This is not as complete of a setup as your rear. Remember, you messaged me on my personal account, and I specifically told you that mixed bushings will have unpredictable results, due to variable deflection which can result in asymmetrical articulation and possible binding. It sounds to me like it's now time to complete the front to match the rear, and you're going to have one hell of a car! If you wanted to go the cheapest one-shot fix, go with the SPL FLCA, and use the provided spacers to also effectively turn the stock front knuckle into a drop knuckle, drop your car, and enjoy the true 1:1 articulation of both your front and rear suspension. The SPL FLCA will have anti-dive adjustment, as well as roll center adjustment and spherical inners, allowing you to have both a complete front and rear. I love the Wisefab rear, but don't recommend the front due to the mandatory low wheel offset, eliminating the ability to run wider tires without wider fenders. Drop the front and rear both back down to recommended or even lower, to take full advantage of the SPL FLCA and Wisefab rear. |
#298 | |
I appreciate the out of context comments, and I will make sure to tell David that this is the best solution. I was willing to settle for a cheaper one |
#299 | ||
Drives: 2022 GR86
Having minimal preload and setting up the desired ride height by changing the damper length contradicts the settings / dimensions recommended in the manual that comes with CSG FLAs. And it is a good way to run into HBS all the time when driving on a highway — see the discussion we had earlier on this thread. Quote:
Are these available for purchase anywhere? Curious just in case I decide to get a RC kit myself. |
#300 | |
With the Wisefab kit, damper stroke is not affected by the natural drop, so compression travel is not affected. You would actually be able to increase some compression travel without losing droop, to delay HBS engagement if preferred. |
#301 | |
Drives: 2022 GR86
As you probably know, many coilovers only have the top collar / preload adjustments, and surely you can change the ride height with them. When the preload is less than the car's load at ride height, more preload will raise the ride height. When considering the static ride height, any change in the position of the top collar (which controls preload) offsets where the bottom of the spring seats relative to the suspension, which certainly affects the ride height (as the compressed length of the spring is determined primarily by the weight at this point, and the top of the spring is fixed relative to the car body). When there's more preload than load at ride height, adding even more preload will not affect the ride height anymore. Hopefully this fact is not applicable to anyone — I can imagine how much resistance there will be on the top collar if you try to do that ![]() Are you saying the wheel well has enough space to accommodate the wheel if it goes 2" deeper under compression than with the recommended CSG FLA settings? At least in the front, with such amount of extra drop you'll have a ton of problems. |
#302 |
Drives: 2014 GT86
timurrrr: it will change only after preload adjustment will pass spring compression under car's load (and which is certainly way too much). please, watch this video.
#303 | |
#304 | |
Drives: 2022 GR86
I certainly have watched that video before, and you can even see me linking to that video in one of the earlier posts.
How about tire vs rest of the car? Fender? Fender liner? Bodywork inside the wheel well? Let's say we're talking about 245/40R17 SX2 and –2º...-2.5º of camber. |
#305 | |
Front? HBS prevents bottoming out. Did you notice at Laguna, that almost every car without HBS bottoms out coming out of the corkscrew, but you didnt?
#306 | |
Drives: 2022 GR86
Gotcha, nice!
I certainly do bottom out the HBSes regularly, just by driving on a highway. As far as I understand how HBSs work, the difference from regular bump stop is just that when a HBS bottoms out it doesn't bounce back (it absorbs the energy through viscosity and converts into heat) as a rubber bump stop (which releases the potential energy back to the car body). See
. Basically it's like dropping a sandbag on a hard floor vs basketball. It's not some magic pill to prevent a damper from bottoming out though. Please correct me if I'm misunderstanding how HBS works, preferably with references to TEIN public technical info. |
#307 |
#308 | |
Drives: 2022 GR86
If you have a damper length designed for lowering with stock arms and then use it with an RC kit, you get double the lowering. You need to actually make the damper longer to work with an RC kit to get the optimal control arm angles. |
| WTB Tein Flex Z | HachiRo | Want-To-Buy Requests | 1 | 09-19-2016 01:13 PM |
| tein flex z | mclovin85 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-14-2016 06:27 PM |
| TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day | CounterSpace Garage | Groupbuys | 47 | 02-18-2016 12:33 AM |
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 09:33 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 01:10 PM |
