Old 07-06-2020, 03:49 PM   #1
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Valve Cover Gaskets
Has anyone here had their valve covers done? Been trying to find threads but all i can find is timing cover post.
Curious if RTV is used in the process of replacing the gaskets. Getting my tube seals redone in a week or so and I'm nervous.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 07-06-2020, 04:29 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You put some in a few spots on the cover.
Old 07-06-2020, 05:07 PM   #3
e1_griego
e1_griego's Avatar
Drives: Many
Just did them a few weeks ago, followed that diagram^
e1_griego is offline   Reply With Quote
Old 07-07-2020, 02:38 AM   #4
Setgo
Setgo's Avatar
Drives: '13 Subaru BRZ Crystal Black Silica
Yeah follow the tech manual. Consider getting a gasket set too, to replace the spark plugs gaskets. I did mine like last month.
IG: setgo.moto
Setgo is offline   Reply With Quote
Old 07-07-2020, 02:52 AM   #5
VoltsFRS2013
I have the tube seals next to me i got from my job, gonna head to toyota for the VC Gaskets =)
Old 09-15-2020, 01:20 PM   #6
knucklehead
Drives: FRS
I think my valve covers are also leaking. Is it possible to remove said covers without having to removing the front timing cover? Can this also be done without pulling out / removing the whole engine from the engine bay? Also, does one have to drain the oil before removing the valve covers?
I need also to replace my spark plug tube seals and would be doing it at the same time as this.
knucklehead is offline   Reply With Quote
Old 09-15-2020, 02:01 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The valve covers are separate and can be removed without touching the timing cover. You can probably get the job done without pulling the engine, but it will be tight, I would recommend unbolting the lower engine mounts, and raising the engine. That way you can also push it from side to side to give yourself more room on the side you are working on. You do not have to drain the oil. Pulling the valve covers will give you access to the spark plug gaskets. The manual calls for a small amount of TB1217H sealant on the valve cover.
Old 12-20-2021, 04:28 PM   #8
BrZ_Good
Drives: '13 BRZ Ice Silver Metallic
What’s the valve cover torque spec?
BrZ_Good is offline   Reply With Quote
Old 12-20-2021, 07:22 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
57in·lbf
Tighten inside out in a crossing pattern.
Old 12-20-2021, 11:00 PM   #10
BrZ_Good
57in·lbf
Much appreciated!! Called two stealerships and couldn’t even get an answer.
Old 12-20-2021, 11:08 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
NP.
If you look in @Ultramaroon's sig he has the manuals linked.
Just don't beat him at Dejarik or he will rip your arms off.
Old 12-24-2021, 03:33 PM   #12
BrZ_Good
Here’s the factory seal on mine. Seems excessive, but effective. It was the plug tube that failed on me. Looks like even touched the cam, I put a smaller bead. Name:  F731E51A-4D7F-453A-B951-E2B2E48C8C42.jpg
Rocker put a hole in valve cover leets4uc3 Engine, Exhaust, Transmission 67 07-27-2018 02:14 PM
Other Oil leaks - Oil Pan gasket? - NOT Cam plate, valve cover, or Cam cover exE36M3 Issues | Warranty | Recalls / TSB 17 11-08-2017 10:15 AM
Hole in valve cover burdickjp Issues | Warranty | Recalls / TSB 25 11-29-2016 09:37 PM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 09:42 PM
