| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: ZC6
Oil Drain Pan Reccomendations?
I have a Fumoto valve installed on my car and I only have ramps to drive up on to change the oil. Can anyone recommend an oil drain pan that will fit under and gets the oil transferred to milk jugs cleanly?
I bought a regular 7.1 quart pan, thinking it was enough but I'm guessing the volume spec is a lie because after draining from the engine, the oil was practically to the brim and oil spilled out as I was trying to move it -_-. I looked online but a lot of what sites are suggesting, the actual user reviews and experience on Amazon doesn't seem to be in line with what they are saying. So figured maybe there are better suggestions here. |
#2 |
ProCrastinationConsultant
why bother with a messy intermediate step? get the hose adapter to drain the oil directly into the jugs...
https://smile.amazon.com/HOSE-KIT-NI...2880820&sr=8-2
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#3 |
Drives: car
I use a FloTool oil drain pan. I have the 10-quart and a 16-quart. Both work great.
The FloTool Dispos-oil waste oil container is also a good buy. |
#4 | |
The Dictater
Drives: '13 Red Scion FRS
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Ohio Enthusiast (06-26-2020), Seiryuu (06-30-2020) |
#5 |
Oh, hell, just let the oil run out onto your gravel driveway.
* it keeps down the weeds in the middle of the driveway * it keeps down the dust * when it runs off into the ditch water, it suffocates the mosquito larvae And before you so called environmentalists starts squawking, where in the hell did you think the oil came from in the first place -
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#6 |
Drives: 2018 BRZ
Same here, although this poses a challenge - a 5 quart bottle isn't enough to fill the engine, so you use 2. But at the end of the oil change you have one empty bottle and one that's half full, so you don't have enough room for all the used oil (despite the deceptively large amount of air in the original bottle - ask me how I know). So you still need some extra jugs to store the left over oil. I use a 16 quart open drain pan with a decent drain spigot, it keeps the mess to the pan, which I store upright so no need to clean it (it's only used for oil, not coolent). The enclosed drain pans sound like a great idea (where the pan can serve as a container) but then you'd have to really clean the outside where the oil was.
#7 | |
#8 |
Drives: C450
I know you have the Fumoto drain valve but what about doing oil changes like this with an extractor?
Sent from my PH-1 using Tapatalk |
| The Following User Says Thank You to FTCLUB_USER_0086 For This Useful Post: | humfrz (06-30-2020) |
#9 | |
Drives: ZC6
That's literally what I did that lead me to asking here in the first place haha, figured any pan should work. The pan was supposed to be more than big enough but it barely held the oil and flexes all over when full. I guess a hose line to an empty bottle wouldn't be so bad but I prefer to walk away and come back instead of monitoring the flow. |
#10 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
The first 5 quarts fall out in a couple minutes.
Then swap out another container and you can walk off for a three martini lunch. Don't forget to put in new oil and tighten down the filter and 710 knob.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | soundman98 (06-30-2020) |
#11 | |
![]() Sucking the oil out is NOT natural NOR "right". I suppose you eat grapefruit the "wrong" way too - ![]()
| The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (06-30-2020) |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 08:36 PM |
| Kit install and paint, shop reccomendations | Goz | Northwest | 6 | 08-24-2015 03:52 PM |
| Suspension reccomendations | FR-S89 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 12-27-2014 07:50 PM |
| Reccomendations for clutch set-up. | ohnoitsthefuzz | Engine, Exhaust, Transmission | 21 | 11-14-2014 03:09 PM |
| Reccomendations for Led lights.. | _F-R-S_ | Mid-Atlantic | 22 | 02-08-2013 09:10 PM |
