Old 06-30-2020, 12:28 PM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
Tracking with ABS fuse removed?
Me and a bud are considering this for next time trial event. Rules for classification give -1 point for disabling factory ABS, equivalent to -42 lb. IMO it's a stupid rule but thinking of taking advantage! He has a 2013 BRZ, mine is 2017 PP. Both have the same two ABS fuses. FWIW I ran without ABS (bad sensor) in my '01 S2000 for years and never had any problems. Only concern here is if brake bias without ABS is overly rearward...
What do the experts say?!
Old 06-30-2020, 01:00 PM   #2
M0nk3y
Find somewhere else to shave -42lbs
Kyle H. - #89 STX
Old 06-30-2020, 01:33 PM   #3
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Only one way to find out...
gkubed is offline   Reply With Quote
The Following User Says Thank You to gkubed For This Useful Post:
ZDan (07-01-2020)
Old 06-30-2020, 03:06 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Practice without it for a while first. It's not the same car to car.
Did you do HPDE with no abs in your s2000?
ZDan (07-01-2020)
Old 07-01-2020, 06:48 AM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yup, trying it should be straightforward enough. Would be nice to know what to expect in advance though, particularly if something simple like staggered pads might be required if there's too much rear bias without ABS. That's what some said about the S2k though and I had no problems with it at the track or on the street, even in the snow.
Old 07-01-2020, 07:06 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
Also be good to know whether to pull both fuses or just one...
Old 07-01-2020, 08:09 AM   #7
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
doesnt long press on the 2017+ disable abs?
Old 07-01-2020, 08:30 AM   #8
M0nk3y
I don't see in what way, if any, this is a good idea.
Intentionally removing ABS is asking for flat spotted tires, an off, something. Find somewhere else to remove an equivalent of -42 lbs.
I know while I don't intend to hit ABS, it happens, and it saves from a lockup. It's honestly such a bad idea...of all places to save -42 lbs this is the last place, IMO.
But, you do you
Kyle H. - #89 STX
Old 07-01-2020, 09:21 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
No.
Old 07-01-2020, 09:34 AM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
But, you do you
Don't worry, I will! I been doing myself for decades! I've also tracked plenty of cars without ABS and have recovered from lockups without major flatspots countless times.
Purpose isnt to save 42 lb. but rather to allow me fren to run in my TT class. But if it works out ok I might get a 5-lb Li battery to take advantage of admittedly dumb rule that rewards this...
soundman98 (07-01-2020)
Old 07-01-2020, 03:30 PM   #11
racingfool
racingfool's Avatar
Drives: Miata
There's no need to learn that with abs.
I've had abs intervene and ruin a lap when I had things under control.
racingfool is offline   Reply With Quote
Old 07-01-2020, 05:03 PM   #12
Breadman
Breadman's Avatar
No.
is long press not the same as pedal dance or does pedal dance not turn abs off?
Old 07-02-2020, 11:57 AM   #13
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Pedal dance doesn't turn ABS off.
You need to remove the fuse to turn ABS off (which also mess with electronic brake bias I think)
nico_rsx is offline   Reply With Quote
The Following 2 Users Say Thank You to nico_rsx For This Useful Post:
Breadman (07-03-2020), ZDan (07-06-2020)
Old 07-02-2020, 01:07 PM   #14
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Other way around
He either has to add 42 lbm of ballast, or disable the ABS. Running without ABS gives you one point back on classing, the same as adding 42 lbm of ballast.
gcranston is offline   Reply With Quote
The Following User Says Thank You to gcranston For This Useful Post:
ZDan (07-02-2020)
Dashboard fuse box - mini fuse removal airrick Electronics | Audio | NAV | Infotainment 0 10-25-2019 05:05 PM
Removed createluck Wheels and Tires 6 02-02-2016 11:37 AM
REMOVED Chimera Audio/Visual, Electronics, Infotainment, NAV 1 06-28-2014 10:48 AM
removed Fast_Freddy DIY (Do-It-Yourself) Guides 11 11-02-2013 06:46 PM
