Old 05-16-2020, 12:45 PM   #29
Copy
Copy's Avatar
Drives: GR Corolla CE
Looks good!
Copy is offline   Reply With Quote
Old 05-18-2020, 10:23 PM   #30
Silviacrazed
Drives: 2016 Scion FR-S
So today I installed the MTEC clutch spring that I got from @Tonrogs. I can't believe what a drastic difference it made in the peddle. I had hated how jerky and awful the clutch in this car felt. I had difficulty making smooth starts or shifts in this car. I've been driving a manual since I was 15 and this was by far the most annoying clutch to try to drive smoothly. I went for a drive after installing the spring and holy shit the difference. All my shifts feel normal again and you can actually feel where the clutch wants to engage. The factory spring didn't give enough feedback.
I also added a Cusco radiator cap I grabbed from @ka_titties. Figured why the heck not lol.
Sent from my SM-G960U using Tapatalk
Silviacrazed is offline   Reply With Quote
Old 06-10-2020, 12:50 PM   #31
Silviacrazed
Installed a mishimoto oil cooler this morning. Thanks @Louder for the cooler. Also put in a Fumoto drain valve.
Old 06-12-2020, 08:39 PM   #32
Louder
Oil cooler looks good! Glad it made it there safe.
Louder is offline   Reply With Quote
Old 06-13-2020, 01:33 AM   #33
Silviacrazed
Thanks again! I repainted the mount and the sides of the cooler where it was bare aluminum. Couple coats of 2000* rustoleum and it looks perfect. Nice kit.
Old 06-18-2020, 07:42 PM   #34
Silviacrazed
Over the last couple of weeks I've installed a few other things. Added the Cusco peddle I bought off of @fc3s_johnny. I also installed the Perrin transmission support and I modified the whiteline bushing to fit the Perrin support. I picked them up from @Kinda bored tbh. That added a good bit of NVH, but the transmission doesn't move nearly as much. Today I added the Cusco engine mounts. The NVH in the car is definitely noticeable, it's honestly quite loud, but the rewards of the setup outweigh the noise for me. The car is not a DD, so I don't mind the noise. When shifting hard from first to second, the traction control light no longer flashes. Feels tighter on inputs going into corners on backroads as well. It really cleaned up the driveline slop.
Old 06-22-2020, 07:41 PM   #35
Silviacrazed
Going to do a high mount third brake light. Decided to wrap the rear deck lid with black felt to give it a nice clean look.
Old 06-29-2020, 01:43 PM   #36
Silviacrazed
Just installed the Racer X master cylinder brace that I picked up from @Sukisuki.
Old 06-29-2020, 04:56 PM   #37
Code Monkey
Drives: Subaru BRZ
Did you meet in person? Are you going to leave seller feedback?
Code Monkey is offline   Reply With Quote
Old 06-29-2020, 06:16 PM   #38
Silviacrazed
Smart ass
Old 06-30-2020, 10:39 AM   #39
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Originally Posted by Silviacrazed View Post
Going to do a high mount third brake light. Decided to wrap the rear deck lid with black felt to give it a nice clean look. https://uploads.tapatalk-cdn.com/202...9db267fda9.jpg
https://uploads.tapatalk-cdn.com/202...b67ecff48e.jpg
https://uploads.tapatalk-cdn.com/202...a20148af3b.jpg
Did you remove the existing fabric? What did you use to fill the dips?
tehShirt is offline   Reply With Quote
Old 06-30-2020, 10:46 AM   #40
Silviacrazed
I did not remove the existing fabric. I used this and this to adhere the new fabric to the old. I used black felt I bought at hobby lobby. As far as the holes, I didn't fill them. There's 3d printer files on here to make plugs, but I don't have a 3d printer. I just wrapped it really tight. If you get right up on it and look close, you can tell there's a slight void, but from the rear view mirror, or glancing back there from inside the car, you don't see it. It's about 98% perfect, so I'm satisfied.
Old 07-03-2020, 05:24 PM   #41
Silviacrazed
Installed a torque solutions rear shifter bushing and mtec shifter springs today.
Old 11-18-2020, 07:00 PM   #42
Silviacrazed
Installed a Raceseng slammer knob and reverse lockout that I picked up from @ . It all looks brand new. The additional weight makes the shift from 1st to 2nd feel less notchy. I'll have to get used to the size of the knob, but first impression is I like it.Name:  IMG_3457.jpg
SubieBuis BRZ Adventure subiebui Member's Car Journals 13 12-06-2015 04:57 PM
Off The Grid Adventure m.box.design Northwest 8 03-22-2014 12:05 PM
Guru's Ultramarine FR-S Adventure HillCountryGuru Member's Car Journals 10 05-01-2013 07:31 PM
What was your single biggest adventure? whaap Off-Topic Lounge [WARNING: NO POLITICS] 26 04-16-2013 02:21 PM
What would you consider an adventure trip in your FRS/BRZ? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 47 04-07-2013 05:54 PM
