Northern California NorCal
Old 06-29-2020, 10:17 PM   #15
MyRx
MyRx's Avatar
Originally Posted by Wally86 View Post
Recommended steamer?
Depends on your budget and how often you will use it. There’s industrial Mytee/Dupray in the upper hundreds and more or 100-200 ones for personal use. I’m currently using a McCulloch mc1275 from HF. Inexpensive, small, versatile, and very mobile friendly. Bissell has some recommended multi use machines as well. More importantly than what brand, follow factory instructions like only use distilled water and depressurize it when not in use.
I’m on my 2nd mc1275 because I loaned the first one to my sister. She didn’t follow the instructions haha. Gotta love HF warranty 👍
The Following User Says Thank You to MyRx For This Useful Post:
Wally86 (06-30-2020)
Old 07-20-2020, 01:02 AM   #16
daviddgaf21
daviddgaf21's Avatar
Drives: 2014 Scion FR-S
Originally Posted by MyRx View Post
This is always fun! I tend to add an engine clean on cars I detail. I use an engine cleaner or apc and a medium detail brush. For deep engine bays like the MR2 pictured, I used a heavy duty degreaser and steam in areas the brush and I can’t get to. It’s a rewarding outcome.
Always the comment of “...I’m afraid of the electrical...”. My response is “well that’s good, you should be. Because you are, you’ll avoid flooding those electrical areas with cleaner/water.” I don’t cover anything but I always inspect what is and what shouldn’t be. For example, a stereo ghetto wiring and any other drive-thru wiring job will be addressed before cleaning. Final dress-up of any engine bay is with a silicone-free dressing.
Just take my money already!! My car sat out for like a year or two, during some family situations and It’s so damn horrible man.
daviddgaf21 is offline   Reply With Quote
Old 07-20-2020, 02:12 AM   #17
dpfarr
Drives: BRZ ts
Is there any product to use on alcantara/micro fiber crap?
dpfarr is offline   Reply With Quote
Old 07-20-2020, 11:32 AM   #18
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
A damp microfiber towel works best in my experience. You do not want any residue in the fibers, that will make them stick together and make the alcantara look worn down.
There are products for it, but water and elbow grease should do it.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
dpfarr (07-20-2020), MyRx (07-30-2020)
Old 07-20-2020, 05:30 PM   #19
dpfarr
Drives: BRZ ts
My old is had alcantara and when totaled they noted ‘sweat stains’. Very bothered by getting into my car after perspiring in the summer heat because of the shame that insurance agent bestowed.
The Following User Says Thank You to dpfarr For This Useful Post:
Yoshoobaroo (07-20-2020)
Old 07-30-2020, 02:41 AM   #20
MyRx
MyRx's Avatar
And to add, if you have upholstery cleaner, use it lightly. Trick is to use a small amount of the cleaner and a mf towel. Gently wipe dry, softly vacuum to remove more moisture, use a clean dry mf towel to stand the fibers again.
Old 07-30-2020, 02:43 AM   #21
MyRx
MyRx's Avatar
I have to see it to believe it lol. But I’m glad the car’s back to driving mode. Family first, that’s for sure
Old 07-30-2020, 03:07 AM   #22
MyRx
MyRx's Avatar
PFA and detail oriented, a BMW experience polishing this! Ceramic coated including calipers, wheelwells, glass, and engine compartment.
The Following 2 Users Say Thank You to MyRx For This Useful Post:
Clipdat (07-30-2020), PMok (08-13-2020)
Old 07-30-2020, 03:19 AM   #23
MyRx
MyRx's Avatar
Last post I promise haha.
Been successful helping a few people out offline. Basically, if you’ve never clay’ed your car, you should. A hint when you should clay, after a wash and the car still feels like sandpaper, it’s time for clay. +30 min max after a wash. Google/YouTube how to claybar a car. I prefer a clay bar vs a clay mit/glove/block/towel/etc.
soundman98 (07-30-2020), Wally86 (07-30-2020)
Old 07-30-2020, 03:51 AM   #24
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Supra looks so good in red! Nice job detailing it.
A little piece of my heart dies though every time I realize it only comes in automatic in the US.
Originally Posted by humfrz
I'm old and lazy
Old 08-01-2020, 11:03 PM   #25
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Is there any way to get good results buffing headlights from a drill attachment?
humfrz (08-02-2020)
Old 08-01-2020, 11:46 PM   #26
soundman98
ProCrastinationConsultant
soundman98's Avatar
yes. i would look specifically for a 3-step process method though.
1st step should involve a compound that strips/sands the headlamp to remove the oxidized layer.
2nd step should involve polishing it smooth/clear.
3rd step should be some sort of protective coating to keep it looking spiffy for years to come.
personally, i do them by hand(rubbing compound, polish, and a wax sealant do all of the things mentioned). but if they're so oxidized that hand rubbing would take a significant amount of time, i get new housings..
on the cars in my past, it's been a $70-200 cost, which is cheaper in the long run... on this car, the oem housings can run upwards of $400-800/ea for the brz, so it's a little more worthwhile to put some elbow grease into them!
finch1750 (08-02-2020)
Old 08-01-2020, 11:55 PM   #27
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I've done the method soundman98 has used.
I also found sanding the lights down, then working to about 600 grit and applying a clear coat with UV inhibitors. Wet sand and polish for perfect finish.
You'll typically get longer lasting results vs polish + wax/sealant, but its more labor intensive.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 08-02-2020, 12:11 AM   #28
Yep, but ya gotta be quick -
Where ya been, there, finch1750 - haven't seen much out of you lately?
MTEC Shifter Spring Questions & Comments JohnAyySays Engine, Exhaust, Transmission 19 06-11-2018 09:09 AM
My S2000 vs GT86 Steering feel comments/questions. Anybody else own both? GreenLightGo FR-S / BRZ vs.... 57 01-27-2018 02:37 AM
I joined the club! A few questions & comments... Protege13 Scion FR-S / Toyota 86 GT86 General Forum 27 03-27-2017 04:12 AM
Crickets be gone! lucas oil deep clean fuel system cleaner SliverBrz Issues | Warranty | Recalls / TSB 15 09-23-2013 09:22 PM
Getting questions and good comments sweetfrs Scion FR-S / Toyota 86 GT86 General Forum 26 04-15-2013 08:03 PM
