Old 06-28-2020, 07:56 AM   #1
grumpysnapper
grumpysnapper's Avatar
Öhlins...dirt/mud/dust covers
Was a bit sceptical about how well they might fit (and then work).
But true to Öhlins quality...they fit and seal beautifully.
Fingers crossed I can stretch out the time between rebuilds...
grumpysnapper is offline   Reply With Quote
The Following 5 Users Say Thank You to grumpysnapper For This Useful Post:
cactus (11-14-2020), churchx (06-28-2020), Kiske (06-28-2020), Racecomp Engineering (06-28-2020), solidONE (06-28-2020)
Old 06-28-2020, 01:11 PM   #2
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Will this work in a similar inverted strut?
tintumz22 is offline   Reply With Quote
Old 06-28-2020, 02:46 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
these never seemed to catch on in the offroad world... i used to run a few lizard skins products on my mountain bike that worked very similar. i know they've had these for the car world for quite some time as well.
https://www.lizardskins.com/product-..._protector&v=0
i believe the main consensus against them was that they tend to trap dirt, debris, and moisture within the assembly, which doesn't exactly exacerbate wear(compared to a non-protected shock), but doesn't cut down wear enough to justify the product.
my impression is that it's led to being a 'feel good' product that has no significant mechanical benefit...
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
solidONE (07-02-2020), tintumz22 (06-28-2020)
Old 06-29-2020, 11:59 AM   #4
grumpysnapper
You could be right...
I'm really just going off the advice that the builder of the dampers gave me to try and extend the intervals between servicing the units (he also said to regularly take off the protectors give the dampers exposed areas a surface clean too) .... so fingers crossed.
Old 07-01-2020, 01:23 PM   #5
M0nk3y
I've had Eibach Spring Covers on my MCS since day 1. They work really, really well.
Great at keeping dirt, grime, OPR and everything else out. Especially if you have torrington bearings or thrust sheets
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
grumpysnapper (07-02-2020), solidONE (07-02-2020)
Old 11-12-2020, 06:07 PM   #6
soundman98
soundman98's Avatar
so, was i wrong? have the shocks required less maintenance with these?
Old 11-17-2020, 09:27 AM   #7
grumpysnapper
So far so good... but it's been very dry here, meaning that it has pretty much only been dust and dry dirt/grime. Haven't yet seen how well they work at keeping mud and slosh away from the sliding bits!
Ive also been a bit anal about the nice gold bits, so have protected them with thick clear acrylic to try and absorb rock strikes. (Sad, I admit )
The Following User Says Thank You to grumpysnapper For This Useful Post:
soundman98 (11-17-2020)
Old 11-17-2020, 02:08 PM   #8
M0nk3y
FWIW - My shocks were rebuilt 2 years ago (I've owned them for 4 years now). During the 2 year rebuild service, MCS commented how well the shocks were and really the front shaft guide had some wear but "Could go another year or 2 probably". We ended up replacing the front guides anyways because the shock was apart. With a McPherson strut, these will see wear regardless but I think keeping dirt out helps 100%
Considering dirt and grime could get on the shaft and potentially compromise the seal and accelerate wear, yeah I think these justify the cost when we're talking about $1000/rebuild cycle.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
[Belgium/France] FS: Öhlins Road and Track (MI20) Guillaume Brakes, Suspension, Chassis 1 02-07-2017 04:45 AM
Coilover options Bilstein/KW/Öhlins/RCE/Tein brzest Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 01-03-2016 05:35 AM
Brake dust or rail dust? Dealership bs? Muskokan Issues | Warranty | Recalls / TSB 12 12-21-2013 09:30 AM
Road & Track by Öhlins For the FR-S/BRZ! RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 05-13-2013 05:58 PM
Anybody have a lead on custom fitted car covers and seat covers for the FR-S? Grateful Dave Cosmetic Modification (Interior/Exterior/Lighting) 17 08-27-2012 09:41 AM
