Old 06-27-2020, 05:01 AM   #1
86zn6
Drives: White GTS then Black GTS
Front right wheel is rubbing
After installing the coilover the front right wheel is rubbing against something when I have the wheel fully turned to right when in the parking lot. I thought something was dropping out from my undertray. Then when I look closely this area in the pic was rubbing. But it doesn’t happen to the front left wheel when I fully turning the wheel to the left. Anyone has idea how to fix? Coilover has about 20mm drops and -2.5c camber.
3rd pic shows front left doesn’t rub at all.
86zn6 is offline   Reply With Quote
Old 06-27-2020, 09:12 PM   #2
norcalpb
norcalpb's Avatar
Wheels specs? You may need the Verus steering rack limiters as a last resort.
Old 06-28-2020, 12:09 AM   #3
86zn6
235 40 18 8.5” rim
It’s doesn’t happen on the other side, does the mean my alignment issue or coilover fitting issue?
Old 06-28-2020, 01:15 AM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Did you do alignment?
Have the read out?
Old 06-28-2020, 01:43 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
stop turning.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (06-28-2020), norcalpb (06-28-2020)
Old 06-28-2020, 02:49 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it rubs plastic I don't worry about it, if it rubs metal I bust out the BFH and clearance it.
Old 06-28-2020, 10:18 AM   #7
86zn6
Have the read out?
The adjustment column is the final alignment result
Old 06-28-2020, 10:21 AM   #8
86zn6
I am trying to figure out why the other side has no problem.
Old 06-28-2020, 11:23 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Orbit direction of the Earth, Mercury is in retrograde, slight difference in camber, somebody keeps coincidentally jumping on the other side of the earth when you make a left turn..........
soundman98 (06-28-2020)
Old 06-30-2020, 07:05 AM   #10
86zn6
I will try reduce the camber slightly for the right side and see how it goes
Old 06-30-2020, 12:00 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’d have the alignment shop do it as changing camber will effect the toe.
86zn6 (07-01-2020)
Old 06-30-2020, 02:06 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
3mm wheel spacer
ineedyourdiddly
Old 07-01-2020, 09:22 AM   #13
86zn6
3mm wheel spacer
Probably not very keen use spacer when running it on the track.
Old 07-01-2020, 04:15 PM   #14
strat61caster
Shouldn't be an issue as long as there is proper thread engagement and torquing procedures. I've had slip on spacers for like 40k Street miles and a few dozen autox events.
ineedyourdiddly
86zn6 (07-02-2020)
Help with slight wheel rubbing. BEZO760 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-11-2019 11:37 AM
Front End Links Rubbing TheLowlyThird Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-31-2017 03:12 AM
will this wheel and tire combo fit with stock suspension without rubbing? Andreasbrz14 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-23-2017 05:25 PM
How to tell if front wheel is rubbing against strut? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-08-2013 10:54 AM
LIST: Non-rubbing 17" wheel & tyre packages ft_sjo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-28-2013 07:56 AM
