Old 05-27-2019, 03:46 PM   #1
Impureclient
Drives: 2015 FR-S
Clicking when turning tight
When driving real slow and I'm turning left and the wheel is almost or all the way turned I get what sounds like a CV axle that has just started to go bad(faint ticking).
Doesn't do it turning right. Wheel bearing maybe? Shouldn't be brake pad since there is only 18k miles on them. When lifted up the click isn't there when turning the wheel
to the left and spinning it. Nothing is touching or rubbing at anything that I can see. If I grab the wheel while up in the air and push/pull or try to move side to side there's
no play to it or noise.
Old 05-27-2019, 11:43 PM   #2
Silverz
Drives: Black frs
Is your grill pushed in?
I got my bumper caught on a wheel stop and it pushed the grill in on one side when I pulled the car out of the parking spot and it caused a popping like sound when turning going slow.
Silverz is offline   Reply With Quote
Old 05-28-2019, 08:13 AM   #3
oaroyale
Drives: Black BRZ
I have the same issue on my Sienna. I am also wondering what it is. I just changed the struts, rotors and pads on it. The clicking is still there. I did see any cracked bushing or anything obvious under the car. Interested to see what everyone has to say.
oaroyale is offline   Reply With Quote
Old 05-28-2019, 04:24 PM   #4
Rocks in the hubcaps.
soundman98 (05-28-2019)
Old 05-28-2019, 11:57 PM   #5
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
i had this when i bought my car. dealership replaced the front strut.
here are some good links that may help:
https://www.ft86club.com/forums/showthread.php?t=107615
https://www.ft86club.com/forums/showthread.php?t=72378
nos145 is offline   Reply With Quote
The Following User Says Thank You to nos145 For This Useful Post:
Impureclient (05-29-2019)
Old 05-29-2019, 12:38 AM   #6
Impureclient
Drives: 2015 FR-S
Those two were more of a clunk, mine is a quieter clicking/clacking sound. Thanks for posting the video to rule that out though.
I haven't caught the bumper on anything that I can think of. Nothing is touching the wheel or tire. What was your grill touching, what caused the noise and how did you fix it?
Added videos:
Old 06-04-2019, 01:46 AM   #7
Impureclient
Drives: 2015 FR-S
Solved and the solution if anybody else has the same issue:
The metal center cap retainer clip that holds it tight inside was not on 100%. Put it on properly and the noise is gone.
These are 720Form GTF1 wheels so if a search is done this thread should hopefully come up if anybody suffers the same issue.
That retainer clip doesn't look too common for any other wheels that I see online so this may be only relevant to this manufacturer's wheels.
The Following User Says Thank You to Impureclient For This Useful Post:
humfrz (06-04-2019)
Old 06-23-2020, 06:36 AM   #8
Sudhir
Sudhir's Avatar
Drives: Toyota 86 High spec
Where exactly is this please?
Sudhir is offline   Reply With Quote
Clicking/cloncking from left front when turning wheels cawith Issues | Warranty | Recalls / TSB 14 02-08-2019 06:14 AM
Clicking noise when turning with the light signal on. Lifer1988 Issues | Warranty | Recalls / TSB 9 04-07-2018 12:03 AM
clicking while turning phatroksek Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-11-2017 10:34 AM
AP Sprint clicking noise when turning 1Cor10:23 Tracking / Autocross / HPDE / Drifting 14 02-14-2017 12:41 PM
Fuel Lid Tight or Loose? JiB Issues | Warranty | Recalls / TSB 18 09-20-2012 01:50 PM
