Old 06-21-2020, 01:16 PM   #18523
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Changed wheel setup and installed springs this weekend. Just needs an alignment now but I'm really happy with the results. I was skeptical with the high offset on 245 but my calculations were correct and it's basically equivalent to a 17x9 +38 or +35 setup. Plenty of space between the perch and enough for a BBK.
Eibach Sportline on factory struts
SPC Front bolts and Rear LCA
ESR SR07 17x8.5 +30
245/40 Federal ST-1
Project Kics hardware: Hub rings, valve stems and R40 Iconix lug nuts
04 Scion xA > 13 FR-S stg 2 UEL E85 > 16 WRX stg 1.5 > 15 Audi S3 > 18 BRZ Limited UEL E85
JonAvalon is offline   Reply With Quote
The Following 3 Users Say Thank You to JonAvalon For This Useful Post:
BRZ_88 (07-01-2020), JD001 (06-21-2020), MJones_RB (06-22-2020)
Old 06-21-2020, 04:12 PM   #18524
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
That fitment looks really good
NaturallyAspirated is offline   Reply With Quote
The Following User Says Thank You to NaturallyAspirated For This Useful Post:
JonAvalon (06-21-2020)
Old 06-21-2020, 09:00 PM   #18525
BRZ_88
Imperator
Drives: Supercharged 2013 BRZ Limited
Installed a new rear wing.
BRZ_88 is offline   Reply With Quote
The Following 6 Users Say Thank You to BRZ_88 For This Useful Post:
BA9092 (06-21-2020), juenedgi (06-22-2020), MJones_RB (06-22-2020), MotoX16 (06-22-2020), norcalpb (06-21-2020), weederr33 (06-23-2020)
Old 06-22-2020, 10:54 AM   #18526
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
Spent the evening making her look pretty again. Did a wash, clay bar, polished with a scratch and swirl remover, then did a presealant polish, and applied a paint sealant
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17
MotoX16 is offline   Reply With Quote
Old 06-22-2020, 01:57 PM   #18527
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
WHAT DID YOU DO TO YOUR BRZ TODAY?
HERESY
Now the only logo in the engine bay is a TRD logo. I quite enjoy that in some twisted way.
Edit: pictures do not do justice to how much bigger the airbox and filter are than stock:
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post:
MJones_RB (06-22-2020), NoHaveMSG (06-24-2020), norcalpb (06-22-2020), soundman98 (06-22-2020)
Old 06-24-2020, 06:08 PM   #18528
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Getting ready for the weekend.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
MJones_RB (06-25-2020), NoHaveMSG (06-24-2020)
Old 06-24-2020, 09:58 PM   #18529
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Now I just gotta play the waiting game for the paint to cure...
MS, CSCS, TSAC-F, CPT
The Following 3 Users Say Thank You to weederr33 For This Useful Post:
MJones_RB (06-25-2020), new2subaru (06-25-2020), NoHaveMSG (06-24-2020)
Old 06-27-2020, 01:35 AM   #18530
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Started the STX build.
Breezio is offline   Reply With Quote
The Following 4 Users Say Thank You to Breezio For This Useful Post:
Husker BRZ (06-28-2020), JonAvalon (06-29-2020), new2subaru (06-27-2020), norcalpb (06-27-2020)
Old 06-28-2020, 11:14 PM   #18531
Breezio
Breezio's Avatar
Nearly finished the STX build. All parts installed and roughly dialed in.
RCE T2's
Vorshlag plates
Verus LCA's
Hotchkis 1" hollow front bar
Hotchkis adjustable endlinks
Openflash UEL header
HKS Hi-Power Spec-L catback
Openflash tune
949 6UL 17x9 wheels
Yokohama A052's, 255/40
-4 camber in front, 0 toe
-2.5 camber in rear, currently 0 toe
Still need to raise the rear about 1/2" and then corner balance.
Old 06-29-2020, 09:44 PM   #18532
JonAvalon
SCBYD0
JonAvalon's Avatar
Mod Monday!
Gruppe-S UEL arrived, the ceramic coating is just lovely! Also installed a Mishimoto PCV catch can and did an oil change with a new Fumoto valve.
The Following 4 Users Say Thank You to JonAvalon For This Useful Post:
BRZ_88 (07-01-2020), Husker BRZ (06-29-2020), MJones_RB (07-02-2020), wolffbite (07-03-2020)
Old 07-03-2020, 05:02 PM   #18533
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Washed, clayed, polished, and waxed.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
JonAvalon (07-03-2020)
Old 07-04-2020, 11:20 PM   #18534
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Finally got around to a thorough detail... weather was not cooperating on weekends!
Did the interior last weekend, but today I did:
Wheels off wash to get at the wheel wells
Iron-x Decon
Polished a few oxidized areas and swirls out
Wolfgang Exterior Trim sealant to all plastic
Coat of Soft99 Fusso Coat Dark
Installed paint-matched mudguards (I applied PPF to the inside face beforehand)
This was after getting out for 2 hours of kayaking and getting a nasty sunburn. I'm completely spent and I can tell I will be sore tomorrow, but it sure looks killer!
wolffbite is offline   Reply With Quote
The Following 3 Users Say Thank You to wolffbite For This Useful Post:
BA9092 (07-05-2020), CBR600RR (07-05-2020), JonAvalon (07-14-2020)
Old 07-05-2020, 11:48 AM   #18535
CBR600RR
Drives: Raven Black
^ that wheel and tire set up looks amazing on your BRZ!
The Following User Says Thank You to CBR600RR For This Useful Post:
wolffbite (07-05-2020)
Old 07-05-2020, 05:15 PM   #18536
norcalpb
norcalpb's Avatar
ESR SR07 17x8.5 +30
245/40 Federal ST-1
Have you noticed any vibrations with the project kics hub adapters? I want to buy them, but the “Subaru” version lists a 56mm bore instead of the 56.1mm that we actually have. I’m sure it can’t make too crazy of a difference, but I am paranoid about that kinda stuff
The Following User Says Thank You to norcalpb For This Useful Post:
MJones_RB (07-06-2020)
