Old 07-23-2012, 09:37 PM   #15
ahausheer
Re-member
Drives: Toyota camry
So this is around 230 to the wheels without a tune at about 7,300 rpm? 115 hp per liter @ 7,300 rpm? Sounds to good to be true. Intrigued.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
The Following User Says Thank You to ahausheer For This Useful Post:
Panman (07-25-2012)
Old 07-23-2012, 09:46 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You mean 230 to the flywheel? The 194 is to the wheels..
Old 07-23-2012, 10:09 PM   #17
dabocx
dabocx's Avatar
Drives: Scion FRS
Originally Posted by vividracing View Post
Agency Power Crank Pulley / Clutch Masters Flywheel
  • Run#1 153whp 125wtq
  • Run#2 180whp 143wtq
  • Run#3 194whp 150wtq
Run#1 Was a BASE run. Bone stock!
Run#2 Was with the Flywheel and Crank Pulley.
Run#3 Was with Flywheel, Crank Pulley, Header, Crossover pipe, Catback exhaust system.
So adding the Header/Crossover pipe/ Catback only gained you 14hp and 7tq?
dabocx is offline   Reply With Quote
Old 07-23-2012, 10:12 PM   #18
Sportsguy83
Drives: Limited BRZ
Looking back at the original thread, it seems the Dyno posted there included all of the components on this new thread (i. e. full exhaust, LW pulley and flywheel).
Old 07-23-2012, 10:20 PM   #19
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Exactly, we were all right to be skeptical i wonder how many orders they got without posting full information.
Old 07-23-2012, 10:34 PM   #20
vividracing
vividracing's Avatar
Originally Posted by Calum View Post
Palm, face. Face, palm. Ah, I see you've already met.
Fuck me. How do you expect to have any creditably if you post a light weight part but don't show the weight difference?
Not even sure where to start with this.
Originally Posted by fenton View Post
The runs are two months apart so that could be some of the issue.
Car sat apart pretty much for the whole time. Car was run for 400 miles and then broken in on the dyno. At that time it made 154whp. Its only had a few miles put on it since. It broke in long ago.
stock at 153 is 23percent loss considering a perfect engine and mustang dyno.
Clutch flywheel and pulley result in 10 percent loss yes but i think alot is going to have to do with the car both breaking in and dyno conditions between the two months/calibration.
Just my 2 cents though
See above.
There is a exhaust thread. Please post in there.
Ah and so it was corrected. People are wrong once in a bit.
Once again bro. Take your B.S. and move on. Every time there is a Vivid post you bring nothing to the thread but negative. Its getting old and people are really getting tired of it.
And No systems where sold at least thru me and this website. So have no worries.
Now here is the exhaust thread.
http://www.ft86club.com/forums/showthread.php?t=12553
Please use it. This thread is for the pulley and Flywheel.
vividracing is offline   Reply With Quote
Old 07-23-2012, 10:38 PM   #21
dabocx
dabocx's Avatar
Drives: Scion FRS
Looking forward to see what you all do with the intake.
Old 07-23-2012, 10:57 PM   #22
Sportsguy83
Drives: Limited BRZ
No worries, just thinking out loud. My bad for posting this discussion here. I will now go to the exhaust thread.
Old 07-23-2012, 11:29 PM   #23
AkaJabari
Drives: Scion FR-S, Scion tC
What I'm saying is that a 14% recuperation in drivetrain loss from a flywheel and a lightened pulley is not mechanically possible. Maybe if the pulley in question was physically smaller in diameter and underdriving accessories. Maybe if you removed the A/C unit and were running a Carbon Fiber driveshaft as well. None of these things are happening on the car tested.
What the OP is implying from his post is that the products he will sell you will indeed net a 15% gain in HP across the entire powerband. There are no disclaimers in the OPs post that these pulls were done months apart. The car was not rebaselined before the parts were installed to give you a legitament sense of what power gains you could expect for these parts, if any. What the OP is selling you is snake oil.
What the mods WILL do are the following:
A lightened flywheel reduces the rotational mass of the engine. Same as a lightened crankpulley. With these mods, the engine will rev up and down the RPM range quicker. The net result is the car behaving like it's ~200 lbs lighter in 1st gear. Each gear thereafter the weight loss is exponentially lessened. It may net you 1-2 HP. MAYBE.
This is all I have to say about these claims. There will be no more posts from me on this vendor.
AkaJabari is offline   Reply With Quote
The Following 6 Users Say Thank You to AkaJabari For This Useful Post:
civicdrivr (07-24-2012), SkullWorks (07-25-2012), Swift Racing Technologies (07-24-2012), Tainen (07-23-2012), Tomzilla (07-25-2012), TwinscrollGT35R (07-23-2012)
Old 07-23-2012, 11:34 PM   #24
Dimman
Kuruma Otaku
Dimman's Avatar
^ Lightened rotating mass will show gains on acceleration runs. But not on steady state loading. Plus, compared to wheels, since they are rotating at engine speed they have a stronger effect.
Because titanium.
Old 07-23-2012, 11:36 PM   #25
Sportsguy83
Drives: Limited BRZ
Maybe the runs are in first gear?
Old 07-23-2012, 11:37 PM   #26
Mr. Sociable
Hombabe
Mr. Sociable's Avatar
Drives: 2014 BRZ
QFT. All I've seen are dishonest, misleading graphs with zero relation to what physics or other tuners are finding. Until I see Vivid or someone else post independently dyno'd results including baseline runs beforehand, I refuse to believe that every part they make is getting power that is 10-15whp more than every other mfg out there, including well known and respected companies.
Mr. Sociable is offline   Reply With Quote
Old 07-23-2012, 11:47 PM   #27
TwinscrollGT35R
Drives: 2006 Subaru
And I am thanking you for no more posts by you.
TwinscrollGT35R is offline   Reply With Quote
Old 07-24-2012, 12:01 AM   #28
JoeBoxer
JoeBoxer's Avatar
See above.
I'll take my BS and my hard earned dollars elsewhere don't worry won't see anything else from me either.
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
