Old 06-14-2020, 02:32 PM   #22023
jflogerzi
jflogerzi's Avatar
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
humfrz (06-14-2020)
Old 06-14-2020, 07:59 PM   #22024
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
tough decision, but a truck is a lot better all-arounder than the car. i hope it works out for you!
I had a 1st gen '98 Tacoma (2.4L, 5spd manual, 2WD, Extended Cab) in the past for my daily for quite a while and really enjoyed it. I like the Nissan 2nd gen Frontier (4.0L, 6spd manual, 2WD, King Cab) even better than that Tacoma though, much more sold on midsize trucks over the 'minitrucks'. I'd love to do a long travel setup on it eventually, but more than like the current OME lift I have on it now (~2"). Now that the FR-S is gone I have garage space and incentive to do the things I've been procrastinating on with the Frontier - like fabbing seat bracket/mount for the Recaro Sportster GT thats been in my living room for nearly 9 months, installing the XTP intake manifold spacer thats been sitting similarly as long in my room (and doing spark plug change and internal secondary intake butterfly valve replacement at same time), and custom Morimoto M LED 2.0 based headlight retrofit using parts I recently got in from TRS along with some used OEM headlights off ebay.
I'm more than content in giving up the FR-S and keeping the Frontier. Much easier to find another manual 86 down the line than a 2nd gen 2WD, King Cab, 6speed manual Frontier. I had to fly to North Carolina to get my Frontier...only one of a few in the country I could find specced as wanted and within my budget at the time I was looking some 3 1/2 years ago. I will miss the FR-S, but I like how I don't need to worry about a lift to do basically anything under a truck for maintenance.... just go right under it and do whatever maintenance work needs to be done. FR-S with a front lip is so freaking low a regular jack won't even fit under it... had to drive up on pieces of wood to fit a jack under it just for doing an oil change. And rear has to be lifted for differential fluid change, where with the truck you can do it as is on the ground.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
soundman98 (06-14-2020)
Old 06-14-2020, 08:36 PM   #22025
jflogerzi
jflogerzi's Avatar
Sounds logical to me. Our family car is a 2014 ford flex we bought used and paid cash. I love it. The amount of stuff I can put in this is crazy with the seats down. I am thinking of getting a used truck as a tow/daily when the frs gets converted to pure track duty.
Old 06-14-2020, 09:34 PM   #22026
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
changed spark plugs last weekend but didnt drive it
this weekend replaced my leaking rear strut with a new OEM one (used the spring compressor tool to keep the same spring as they still had little milage on them)
also did an on oil change.
while doing the spark plugs i removed the stupid sound tube and plugged the hole in the passenger compartment
absolutely love driving this car, felt amazing today after all that work
also rewarded myself with a milwaukee 1/2 inch impact for future tire rotations/swaps
RickyRacer is offline   Reply With Quote
The Following 2 Users Say Thank You to RickyRacer For This Useful Post:
humfrz (06-15-2020), MJones_RB (06-15-2020)
Old 06-16-2020, 11:44 AM   #22027
FRS_ing
FRS_ing's Avatar
Drives: Scion FRS
Stay-at-Home...to install car parts
In this past month, installed TRD lowering springs, Konig Hypergrams 17x8 +40, VLand Headlights, replaced a broken wheel stud in the rear, and added duckbill spoiler.
Just smile and wave.......
FRS_ing is offline   Reply With Quote
The Following 3 Users Say Thank You to FRS_ing For This Useful Post:
humfrz (06-16-2020), JesseG (06-19-2020), MJones_RB (06-16-2020)
Old 06-16-2020, 03:31 PM   #22028
WOW! Busy boy. Your car looks great!
Old 06-18-2020, 10:37 PM   #22029
Silviacrazed
Drives: 2016 Scion FR-S
Installed Cusco motor mounts today. About a week ago I installed the Perrin transmission support and also modified a whiteline transmission bushing to fit the Perrin support. Shit ton of NVH, but the car handles great and the driveline lash is gone. And the extra noise makes me smile like an idiot as it runs towards redline. I also installed a Fumoto drain valve and Cusco pedal about a week ago.
Sent from my SM-G960U using Tapatalk
Silviacrazed is offline   Reply With Quote
The Following 3 Users Say Thank You to Silviacrazed For This Useful Post:
DarkPira7e (06-19-2020), humfrz (06-19-2020), JesseG (06-19-2020)
Old 06-19-2020, 01:38 AM   #22030
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
After having dealt with the horrendous brake squealing these past couple of weeks since installing Hawk HP+ pads, I'm happy to finally drive the car with extended studs and not-as-horrendous squealing after having added some lubrication all around! (not on the pads or the rotor themselves of course)
So now all that's left is to finally give the car a proper wash and start thinking about more mods.
The Following User Says Thank You to KR-S For This Useful Post:
humfrz (06-19-2020)
Old 06-19-2020, 01:51 AM   #22031
What did you lub to reduce the brake squealing?
Old 06-19-2020, 02:31 AM   #22032
Kaotic Lazagna
Drives: GR Corolla
Started daily driving the FRS again.
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
JesseG (06-19-2020), MJones_RB (06-19-2020)
Old 06-19-2020, 02:28 PM   #22033
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I did the same thing with the Perrin transmission support, the Whiteline bushing, the Perrin shifter mount bushing and the Cusco solid shift lever retainer bushings. Massive NVH but you really feel connected to the action. I can actually hear the syncros and the main drive shaft.
MJones_RB is offline   Reply With Quote
Old 06-19-2020, 03:29 PM   #22034
Silviacrazed
I have a rear shifter bushing coming and I thought about the cusco lever bushings. It makes me grin as I get higher in the rev range. It's loud, but it's fun.
The Following User Says Thank You to Silviacrazed For This Useful Post:
MJones_RB (06-22-2020)
Old 06-19-2020, 04:21 PM   #22035
Why don't you folks just weld the engine to the frame (body), weld the transmission to the engine, and weld all the other parts of the drive train together then weld that all up to the transmission? -
Silviacrazed (06-20-2020)
Old 06-19-2020, 07:22 PM   #22036
Ohio Enthusiast
Drives: 2018 BRZ
Strange, I have a very similar setup (no Perrin trans support, just the Whiteline and Torque Solutions shifter carrier bushings instead of Cusco) and didn't notice any added NVH, but shifting while accelerating/braking is much more solid.
Ohio Enthusiast is online now   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
