Old 06-18-2020, 01:51 AM   #1
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Relocating MAF
Im working on a custom build currently the set up has the mass air flow sensor sitting pre-turbo and with the new set up I will need to relocate the sensor to sit post-turbo. My question is can I continue to run on the current tune even though the MAF is now in a different location. Or will I need a new tune before going full throttle again.
BlOody_BoOger is offline   Reply With Quote
Old 06-18-2020, 01:56 AM   #2
tomm.brz
Drives: brz 2017 hksv2
will be similar but still requires a maf scaling
also, with a turbo you shouldp probably take advance of hybrid speed density and not use maf at all during full throttle
Old 06-18-2020, 01:59 AM   #3
BlOody_BoOger
I don't know what that means I'm not a tuner I just want to be sure that I can still boost despite moving the sensor.
Old 06-18-2020, 02:01 AM   #4
tomm.brz
you certanly want your tuner to tune it again after you change the maf from Draw through to Blow through
or at least ask him, he did the tune
DarkPira7e (06-18-2020)
Old 06-18-2020, 02:03 AM   #5
BlOody_BoOger
Currently its on a shelf tune. But I will be getting the car tuned hopefully soon. I guess in the meantime I'll just have to drive it easy.
The Following User Says Thank You to BlOody_BoOger For This Useful Post:
solidsnake11 (06-26-2020)
Old 06-26-2020, 09:17 PM   #6
solidsnake11
Drives: brz
I have had these thoughts, then the next thing I know I'm rebuilding the engine.
solidsnake11 is offline   Reply With Quote
The Following 2 Users Say Thank You to solidsnake11 For This Useful Post:
DarkPira7e (06-27-2020), Spuds (06-28-2020)
Old 06-27-2020, 01:41 AM   #7
tomm.brz
if he stays out of boost and wot he shoulfn t have any problem
anyway in open loop turbo benefits so much from speed density and then maf position is irrelevant
best way would be have your tuner ntroduce and scale speed density while your maf is in old position pre charger and then switch position
solidsnake11 (06-27-2020)
Old 06-27-2020, 10:07 AM   #8
solidsnake11
Drives: brz
True.
That what I was saying, I will say "If I drive it easy" and then I'm wide open, full boost and then cabin fills up with blow by smoke.
Old 06-27-2020, 11:57 AM   #9
tomm.brz
lol,
i did it too, the smoke in cabin in the worst experience ever
Old 06-29-2020, 08:16 PM   #10
steve99
Drives: FT86
just be aware that the MAF sensor is also the intake air temp sensor, so chaging it from pre to post turbo will not only likely chage its maf scaling but also the measured intake air temps will be vastly different pre to post turbo
BlOody_BoOger (06-30-2020)
Old 06-30-2020, 12:30 AM   #11
BlOody_BoOger
The set up i plan on having will have a bypass valve that sits right before the throttle body. This bypass valve will allow me to have an extra intake pipe so that when I'm not boosting the car can freely suck in air with no restriction. So not untill I get the car tuned would I have to worry about the charged temps affecting the MAF. But I will have to worry about the location since it will sit that much closer to the throttle body.
Old 07-01-2020, 05:35 PM   #12
steve99
Drives: FT86
intake temps wont be a huge issue to get car running,
Considering relocating In San Diego, opinions please!!! brzadmir Southern California 12 10-16-2013 12:42 AM
Relocating to Irvine from Atlanta 10/25 mad_sb Southern California 10 10-15-2013 01:50 PM
Relocating the o2 sensor Tkalz Engine, Exhaust, Transmission 6 06-24-2013 02:40 AM
Relocating from Hawaii BrzRacer Northwest 48 04-14-2013 04:15 AM
Relocating battery to trunk Ess Vee Engine, Exhaust, Transmission 17 10-02-2012 04:32 PM
