#5489 | |
Drives: '14 BRZ Limited
Took it for a drive, oil temps in the highway and city are down 20 degrees, steady in the 190 range. So is the coolant. Need to find some road to do some hard pulls but so far worth every bruise and cut from the install. |
#5490 |
Drives: 2014 subaru brz
i notice a noise in the engine compartment when i turn on the a/c in my car after i installed the SC only reason im posting it here is because its the belt tensor its much easier to replace when you do the SC just a FYI other wise everything else is going good im seeing oil temp around 215 and coolant the same and that was on a 85 degree day
#5491 | |
#5492 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | mrg666 (05-31-2020) |
#5493 |
pessimistic skeptic
I am enjoying the Jackson Racing Dual radiator since two weeks now. It made a big difference in the engine performance. There is no heat soak anymore. The oil temperature was spiking above 200 at every pull. It does not do those temperature spikes anymore. Engine is always happy now. I wish I had done this earlier.
#5494 |
Drives: 13 White MT FR-S
Curious if anyone here has messed with meth injection in combination with the JRSC?
#5495 |
Drives: 2017 toyota 86
Nothing really unique about running wmi with jrsc vs other FI. Lowers intake temps and has about half the gain as switching from pump to E85. With WMI and E40 I’m at about the same timing as is typical with E85 on my setup.
#5496 |
Who’s/what kind of controller are you using, and where did you place the nozzle ?
#5497 | |
AEM failsafe wired with xero limit cpc ecu harness AEM filter Snow Performance SNO-40060 Solenoid TORQUE SOLUTIONS THROTTLE BODY SPACER Using TB spacer for nozzle. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | ML (06-09-2020) |
#5498 |
friendly
Drives: 17' 86
I'm starting to review forced induction options for this car as I'd like a bit more power, I really like the powerband of the jrsc for engine reliability. I also am not a huge fan of mounting a turbo near the radiator/fans and I do not want to deal with the possibility of a cracked exhaust manifold. Do people still have issues with rotrex unit failure? I haven't found anything recent.
Seek comfort in discomfort.
| The Following 2 Users Say Thank You to alphasaur For This Useful Post: | CSG Mike (06-11-2020), HachiRokuX (06-11-2020) |
#5499 | |
Drives: JRSC 2013 BRZ
Hope this helps
| The Following 4 Users Say Thank You to Z-Man For This Useful Post: |
#5500 |
pessimistic skeptic
I can also attest to JR customer service. When I was in the process of ordering from a JR reseller, I had several questions and doubts. Oscar Jackson Jr. called himself to answer my questions.
This was 3 years, 35k miles ago. I installed myself. Installation was an impressive experience. No cutting or drilling was required. Kit simply integrated with the engine as if it is a factory option. The engine power continuously increases on a smooth and steep slope with increasing rev. It feels like there is still much more power beyond 7500 rpm. At low rpm normal driving, the car is close to stock NA experience and I get the same mileage which shows the efficiency. In 3 years, my c30 did not have any problems. But I had to replace the recirculation valve and maf extension cable. Plus I highly recommend JR dual radiator oil cooler. |
| The Following 3 Users Say Thank You to mrg666 For This Useful Post: |
#5501 |
You can't beat JR kit. Power band is more built for higher rpm and track use so if you like ringing the car out in NA form this unit is the best for that. If your not a hardcore track junkie the dual rad with oil cooler is perfect. Do it right from the start. If you want a turbo style powerband but with a SC I would look at eddlebrock
2013 Series 10 FRS #553
| The Following 3 Users Say Thank You to jflogerzi For This Useful Post: |
#5502 |
Drives: Fast track beast
What causes the "whine" to be louder, and is it a problem?
Since swapping a rebuilt FA20 recently, I've been told the SC whine is more noticeable. My car has been stripped and caged over the winter so I just figured I was hearing it more, but others are mentioning that is louder than it used to be, but it's pretty cool. Sent from my SM-G965W using Tapatalk |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
