Old 05-24-2020, 05:51 PM   #5489
peaches
Drives: '14 BRZ Limited
Originally Posted by ML View Post
@peaches I have a Koyo rad.
I couldn't get the coupler to fit, ended up squished with an oval shape.
Took it for a drive, oil temps in the highway and city are down 20 degrees, steady in the 190 range. So is the coolant. Need to find some road to do some hard pulls but so far worth every bruise and cut from the install.
peaches is offline   Reply With Quote
The Following 2 Users Say Thank You to peaches For This Useful Post:
CSG Mike (05-26-2020), ML (05-25-2020)
Old 05-27-2020, 07:15 AM   #5490
stacyu18
Drives: 2014 subaru brz
i notice a noise in the engine compartment when i turn on the a/c in my car after i installed the SC only reason im posting it here is because its the belt tensor its much easier to replace when you do the SC just a FYI other wise everything else is going good im seeing oil temp around 215 and coolant the same and that was on a 85 degree day
stacyu18 is offline   Reply With Quote
Old 05-27-2020, 09:12 AM   #5491
peaches
215 doing what, highway driving? Those are the ranges I had for oil with the DROC, with the dedicated oil cooler I'm in the 194 range on the highway doing 80ish. This morning doing 70 it was steady at 185. Coolant with the DROC was in the 205 range, now it's in the 190 range.
Old 05-27-2020, 08:53 PM   #5492
CSG Mike
CSG Mike's Avatar
215 coolant is high for this car.
mrg666 (05-31-2020)
Old 05-31-2020, 06:06 PM   #5493
mrg666
pessimistic skeptic
mrg666's Avatar
I am enjoying the Jackson Racing Dual radiator since two weeks now. It made a big difference in the engine performance. There is no heat soak anymore. The oil temperature was spiking above 200 at every pull. It does not do those temperature spikes anymore. Engine is always happy now. I wish I had done this earlier.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
CSG Mike (05-31-2020), Side (06-16-2020)
Old 06-09-2020, 09:14 AM   #5494
ML
ML's Avatar
Drives: 13 White MT FR-S
Curious if anyone here has messed with meth injection in combination with the JRSC?
Old 06-09-2020, 05:29 PM   #5495
86TOYO2k17
Drives: 2017 toyota 86
Nothing really unique about running wmi with jrsc vs other FI. Lowers intake temps and has about half the gain as switching from pump to E85. With WMI and E40 I’m at about the same timing as is typical with E85 on my setup.
Old 06-09-2020, 08:22 PM   #5496
ML
ML's Avatar
Who’s/what kind of controller are you using, and where did you place the nozzle ?
Old 06-09-2020, 08:30 PM   #5497
86TOYO2k17
AEM V2 Water / Methanol Injection System w/ 1.15 Gallon Tank - Internal Map (trunk mounted)
AEM failsafe wired with xero limit cpc ecu harness
AEM filter
Snow Performance SNO-40060 Solenoid
TORQUE SOLUTIONS THROTTLE BODY SPACER
Using TB spacer for nozzle.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
ML (06-09-2020)
Old 06-11-2020, 11:52 AM   #5498
alphasaur
friendly
Drives: 17' 86
I'm starting to review forced induction options for this car as I'd like a bit more power, I really like the powerband of the jrsc for engine reliability. I also am not a huge fan of mounting a turbo near the radiator/fans and I do not want to deal with the possibility of a cracked exhaust manifold. Do people still have issues with rotrex unit failure? I haven't found anything recent.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
CSG Mike (06-11-2020), HachiRokuX (06-11-2020)
Old 06-11-2020, 03:08 PM   #5499
Z-Man
Drives: JRSC 2013 BRZ
New to the forums but wanted to share my experience after about a year with the JRSC. I got the C-30 factory tuned kit installed (by a reputable shop) on my '13 BRZ in April last year and after about 5k miles of mostly DD and weekly canyon runs, the rotrex unit failed on me. The unit started making a really high pitched noise that kept getting louder. Once I started hearing grinding noises and started feeling less power, I filed a warranty claim through JR. The customer service and helpfulness of JR was top notch! To avoid having the car sidelined for too long, I bought a new C-30 unit through JR so that my shop could replace the failed unit with the new unit in the same process. I got the refund for the new C-30 purchase within 4-5 weeks of me dropping off the failed unit at JR's office in SoCal. After 10k miles with the new unit, happy to report no issues! The JRSC is awesome and I have no regrets even with the failed unit experience. Driving the car is so much more fun, especially with better tires and a solid suspension setup.
Hope this helps
Z-Man is offline   Reply With Quote
The Following 4 Users Say Thank You to Z-Man For This Useful Post:
alphasaur (06-11-2020), CSG Mike (06-11-2020), HachiRokuX (06-11-2020), mrg666 (06-11-2020)
Old 06-11-2020, 08:06 PM   #5500
mrg666
pessimistic skeptic
mrg666's Avatar
I can also attest to JR customer service. When I was in the process of ordering from a JR reseller, I had several questions and doubts. Oscar Jackson Jr. called himself to answer my questions.
This was 3 years, 35k miles ago. I installed myself. Installation was an impressive experience. No cutting or drilling was required. Kit simply integrated with the engine as if it is a factory option.
The engine power continuously increases on a smooth and steep slope with increasing rev. It feels like there is still much more power beyond 7500 rpm. At low rpm normal driving, the car is close to stock NA experience and I get the same mileage which shows the efficiency.
In 3 years, my c30 did not have any problems. But I had to replace the recirculation valve and maf extension cable. Plus I highly recommend JR dual radiator oil cooler.
The Following 3 Users Say Thank You to mrg666 For This Useful Post:
alphasaur (06-11-2020), HachiRokuX (06-11-2020), sroby (06-13-2020)
Old 06-11-2020, 08:26 PM   #5501
jflogerzi
jflogerzi's Avatar
You can't beat JR kit. Power band is more built for higher rpm and track use so if you like ringing the car out in NA form this unit is the best for that. If your not a hardcore track junkie the dual rad with oil cooler is perfect. Do it right from the start. If you want a turbo style powerband but with a SC I would look at eddlebrock
2013 Series 10 FRS #553
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
alphasaur (06-11-2020), HachiRokuX (06-16-2020), mrg666 (06-16-2020)
Old 06-14-2020, 08:18 PM   #5502
AndreC
Drives: Fast track beast
What causes the "whine" to be louder, and is it a problem?
Since swapping a rebuilt FA20 recently, I've been told the SC whine is more noticeable.
My car has been stripped and caged over the winter so I just figured I was hearing it more, but others are mentioning that is louder than it used to be, but it's pretty cool.
Sent from my SM-G965W using Tapatalk
AndreC is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
