Old 04-21-2020, 11:50 PM   #1
RuyGuy2
Dysentery Enthusiast
RuyGuy2's Avatar
Drives: 2017 toyota 86
17' Eight Six - HDPE - AC -Touge - Light Duty Track - Daily Driveable Year Round
Here's the Mod List So far.
Engine and Performance
HKS Supercharger ATI Superdamper 10% under driven and 95mm Pulley on Supercharger
95mm Pulley 3.74" + ATI Circumference 11.75 * 9.888 Gear Ratio = 100,126 RPM@7500
(This is 5000 RPM more than Stock but 5000 Less than High Boost pulley from HKS)
K&N Drop In Air Filter - Greddy Air Scoop - Crawford Billet Power Blocks
Delicious Flex Fuel Kit and Tune - Injectors and Pump - Skunk2 Stepped Equal Length Header
Mid and Over Pipe (can't remember brand) Ark exhaust Modified to be single Exit
Suspension Brakes and Handling
St Suspensions X Coilovers - Wilwood Front brake Rotor Replacement - Sport Edition P4 Rims 16x7 +35 - 225/50R16 General AS-05
P2M Lower Front Control Arms Tie Rods End Links and Rear Tie Rods - Whiteline Adjustable Rear Control Arms - Whiteline Sway Bars
DC Tower Brace - Full Tom's chassis Bracing including sway bar braces
Aero Outside
Sard Style Spoiler - DIY Plywood Splitter - Cut Rear Bumper.
Diftech Adapters, Wilwood Calipers on Stock Rotors braided steel lines. https://www.ft86club.com/forums/showthread.php?t=139903
- modified to fit nicely
RuyGuy2 is offline   Reply With Quote
Old 04-23-2020, 07:21 PM   #2
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Interested in the ABS delete. Mainly how you will bypass the Computer. And have you considered the Chasebays brake booster delete
SuperTom is offline   Reply With Quote
Old 04-23-2020, 09:40 PM   #3
RuyGuy2
RuyGuy2's Avatar
I'm going to leave the computer hooked up and let the manifold sit above the abs unit put some internal plugs in to keep it clean. The idea is to make this easily reversible. I do intend on getting a chase bays booster delete Unit.
The Following User Says Thank You to RuyGuy2 For This Useful Post:
SuperTom (04-23-2020)
Old 04-24-2020, 02:41 PM   #4
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
What are your alignment specs?
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
Old 04-25-2020, 05:39 PM   #5
RuyGuy2
RuyGuy2's Avatar
Alignment is something I really should learn more about, I feel like this car would benefit from more castor?
I didn't want to be to aggressive, I don't want to wear out my tires too fast.
Front
2* camber
5* caster
0* toe
Rear
1.7* camber
0* toe
Old 06-12-2020, 10:12 PM   #6
overd0sed
Drives: 2016 FRS RS2, (sold) 2019 Raiu BRZ
Cool build. How long did it take to install the AutoBlip? Whats your review on it? Thanks
overd0sed is offline   Reply With Quote
Old 06-15-2020, 06:49 PM   #7
RuyGuy2
RuyGuy2's Avatar
Haven't installed the autoblip yet that is a future upgrade.
Transmission/Differential oil change interval daily + light track use GCFSA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 03-11-2020 05:44 PM
Functional, Double Duty Daily/HPDE with a BUDGET dattran86 Member's Car Journals 175 01-19-2019 08:32 AM
WTB: FRS/BRZ for HDPE/track days GrandSport Want-To-Buy Requests 2 10-30-2018 07:53 PM
BRZ Functional DD-AutoX-Light Track Duty Budget Build dattran86 Member's Car Journals 11 01-21-2018 12:35 PM
At what point is your car no longer daily driveable? unsurety Scion FR-S / Toyota 86 GT86 General Forum 42 04-04-2014 12:55 AM
